Drivetrain Water to air intercooler
Old Jul 6, 2004 | 06:34 AM
  #51
clevy's Avatar
clevy
This is in response to the grassroots comment. I have found the belts I need, the problem is that I am pushing much more power than any other mini race car out there, especially the grassroots car.
Old Jul 6, 2004 | 08:11 AM
  #52
Bisch's Avatar
Bisch
Can anyone tell what belts were used? Were they all NAPA's? Was anyone using a Goodyear GatorBack?
Old Jul 6, 2004 | 08:15 AM
  #53
MOTORN's Avatar
MOTORN
Originally Posted by mars31971
I did not attend Phil Wicks accademy while running the practice sessions, I also pushed the car very hard during these sessions to see if I could have any failures of any type. As I said before I pushed every shift point to red line at 7200 RPM's. Not saying that racing wouldn't make a difference but I feal I pushed it as hard as you would in a race during my practice sessions.
If you drove on the track, you were driving at the Phil Wicks Academy (his
insurance) :smile:
I think you are missing the point:
19% needs more testing before it is ready for the track
You drove well and your car was fine, but it was not the same as race conditions.
Christian, Don and Randy all lost belts under race conditions. Some lost more than others. The intercooler (FMD) worked great, the cars (all) were fast, and the belts(all) broke.
The Classic Mini's won.
Old Jul 6, 2004 | 08:45 AM
  #54
andy@ross-tech.com's Avatar
andy@ross-tech.com
All data is from the OBD II port, the cars computer system, so the numbers are real world numbers as is found in the engine itself. I will be doing outlet and inlet temp readings of the intercooler itself this weekend. These numbers will be even lower temps after intercooler because of the air has not reached the intake. The intake temp is the most important because this is what the engine sees not the temp just after the intercooler. The system that Kenne Bell uses for the Miata is bassically the same, the core is the same as is the pump running the system. The cores are proven to be 86% efficient and thusly the system can be no less efficient. Again I will do air temps before and after intercooler soon and will post results, again these numbers are not real world numbers though but I will be glad to post them for you.
I'm looking forward to seeing actual efficiency numbers, compared to the stock intercooler. Your assumption that the system can be no less efficient than the rating of the cores is wrong. Please review the thread I linked for instructions on calculating intercooler efficiency.
Old Jul 6, 2004 | 09:12 AM
  #55
Trippy's Avatar
Trippy
What is the normal MCS ignition advance?
Does the MCS REALLY run 7-degrees ATDC ignition timing? I can't imagine that's correct, but I read it that way from:
I have some info on engine timing, if you retard ignition timing by 4 degrees you loose 16 HP. With the stock intercooler temp readings we were getting we saw a 7 degree retard in ignition timing. So that would give a 28 HP loss with stock intercooler. We are seeing approx. 14 degrees of advance timing.
I'm probably misunderstanding something here, so I thought I'd check.
Here is a 2002 MINI Cooper 5-speed showing up to a 30-degree ignition advance.
That means I should get 30 degrees times 4 HP-per-degree = 120 HP increase!!! (Of course I'm just joshing)
Old Jul 6, 2004 | 09:54 AM
  #56
jlm's Avatar
jlm
what is needed is a timing advance vs engine temp (coolant temp?) curve and then a hp vs rpm for several settings of timing advance.
The implication would seem to be that highest hp would be at full 30 degree advance; if the advanced gets reduced by 4 degrees due to engine temp (to 26 degrees total advance), the hp gets reduced by 16hp, according to mars.
but some confusion about this statement from mars: "With the stock intercooler temp readings we were getting we saw a 7 degree retard in ignition timing. So that would give a 28 HP loss with stock intercooler. We are seeing approx. 14 degrees of advance timing. So that should help put into perspective what the FMD intercooler is doing for you in terms of more HP."
this part is clear: when things heat up, the stock intercooler can only reduce temps so much, but not enough to maintain full advance. the result is a reduction of advance by 7 degrees, to 23 degrees for a hp loss of (16)*7/4=28hp. the "we are seeing 14 degrees of advance" is the murky part.
does mars mean stock literally is showing 7 degrees retarded? and the new unit cools enough to run literally 14 degrees advanced, but not the full 30 degrees advanced?
Old Jul 6, 2004 | 10:00 AM
  #57
Arly's Avatar
Arly
air to water intercooler
Are these Lamanova cores being used??:smile:
Old Jul 6, 2004 | 10:21 AM
  #58
TonyB's Avatar
TonyB
With re to jlm's request, Trippy, didn't the data I sent to you for the thermostat thread contain info about timing as well? I'm too busy to go dig it up now... jlm, if I find it later, I'll send it over to you via email.
Old Jul 6, 2004 | 10:33 AM
  #59
andy@ross-tech.com
In a WOT run in 2nd gear, I have seen ignition timing climb from about 15* BTDC to over 25* BTDC at 6500 rpm.
Old Jul 6, 2004 | 10:39 AM
  #60
Trippy's Avatar
Trippy
TonyB, you are correct sir....
Here it is
Just look at that ignition timing!!!!!!!
It looks like the MCS idles at 14 to 16 degrees AFTER TDC!!!
I see a range of (-16.5) to +38.5 degrees for a total range of 55 degrees!!!
WOW! I'm impressed the engine can run over such a wide range of ignition timing.
Old Jul 6, 2004 | 11:34 AM
  #61
Trippy's Avatar
Trippy
Ask and ye-shall receive...
TonyB did actually send me this information.
Is does look like the range of ignition advance is restricted to a narrower range while the engine is warming up.
Somewhere right in the 180-degree-F range, they get to their full range.
So, it's not clear to me why running a colder thermostat would help performance. (Sorry, that's a differen thread)
Old Jul 6, 2004 | 01:10 PM
  #62
mars31971's Avatar
mars31971
Yes they are Laminova cores.
Old Jul 6, 2004 | 01:18 PM
  #63
Bisch's Avatar
Bisch
Cool stuff! (pun intended)
http://www.laminova.se/
Old Jul 6, 2004 | 01:19 PM
  #64
mars31971's Avatar
mars31971
Honestly I may have misinterpereted some numbers myself that were given to me by my engineer. I will have him look at the forum and see if he can not clarify some things for me and everyone else. The last thing I would want would be to misrepresent myself.
Old Jul 6, 2004 | 01:23 PM
  #65
mars31971's Avatar
mars31971
Here are a few more pics as the others were a little dark.
Old Jul 6, 2004 | 01:24 PM
  #66
mars31971's Avatar
mars31971
And a couple more.
Old Jul 6, 2004 | 01:25 PM
  #67
clevy's Avatar
clevy
edit
Old Jul 6, 2004 | 01:28 PM
  #68
andy@ross-tech.com
Originally Posted by clevy
Andy@rosstech why do you have to bash everyone's product? FMD has put many hours of developement into this intercooler just so that they would be sure that it is the best intercooler available. It is people like you who hide behind the anonymity of the internet and ruin other peoples ideas and products by bashing them. Just because you think you know more than everyone else on this site doesnt mean that you do.
Excuse me? What bashing have I done?
Old Jul 6, 2004 | 01:34 PM
  #69
clevy's Avatar
clevy
Old Jul 6, 2004 | 01:37 PM
  #70
clevy's Avatar
clevy
Old Jul 6, 2004 | 01:38 PM
  #71
andy@ross-tech.com
I just dont like how you demand more and more numbers when the most realistic figures are right in front of you. When they tap into the plenum they will see even better numbers than what they have already posted.
I am flattered that you have chosen to devote a sizeable portion of your total posts to complaining about me. But, instead of complaining, you may wish to read through my posts. Intercooler efficiency is a fairly simple thing to calculate and something that every intercooler manufacturer should do. Please explain to me how the data already presented in this thread shows what the intercooler will do in a variety of different running conditions.
Feel free to ignore posts from me if you don't want to hear what I have to say.
Old Jul 6, 2004 | 01:57 PM
  #72
Bisch's Avatar
Bisch
clevy, why are you erasing your posts?
Old Jul 6, 2004 | 02:00 PM
  #73
friedduck's Avatar
friedduck
mars and Andy seem to be getting along, so I don't see what the problem is.
I'm enjoying this one, it looks promising.
--Jeff
Old Jul 6, 2004 | 02:04 PM
  #74
Bisch's Avatar
Bisch
The radiator for the system is in front of the car so not possible. The only way it would be possible is if the intercooler itself were to leak. There are several high temp, high pressure gaskets being used and the unit is put together with high temp, high pressure sealant as well. These unit are being used by Kenne Bell with zero failures to date.
I think he meant if the exchanger core or the seals around it leaked...that would cause a problem. Hopefully, if it ever did happen, it would be a small enough leak that the white smoke out the exhaust would signal a problem.
Old Jul 6, 2004 | 02:07 PM
  #75
Bisch's Avatar
Bisch
--Jeff
Me too! I don't see what clevy's issue is. Maybe he doesn't have enough experience with Andy to understand how he operates. We're all just looking for more info. This looks very promising so far...
