Drivetrain Does anyone make a boost gauge setup that matchs the factory stuff?
Old Jun 5, 2014 | 09:58 AM
TEEZY's Avatar
TEEZY
Cant seem to find anything.
Old Jun 5, 2014 | 10:18 AM
broncobuddha's Avatar
broncobuddha
I want to know where to get these gauges:
Go to 1:15 in. Drool.
Old Jun 5, 2014 | 05:07 PM
jabbr's Avatar
jabbr
That was a factory Chrono package.
Have you looked at the Cravenspeed gauges?
Old Jun 5, 2014 | 05:09 PM
broncobuddha
I haven't but I will.
Those looked factory but I'm surprised that I haven't seen more cars with them.
Guessing they're a bear to install or insanely expensive.
Old Jun 5, 2014 | 06:22 PM
wrnchhd's Avatar
wrnchhd
The Marshall MINI Cooper Gauges (boost on left; oil pressure on right) are a very good match to OE.
Old Jun 5, 2014 | 06:46 PM
MaxGSeeker's Avatar
MaxGSeeker
My favorite is the Autometer with a boost limit warning and peak memory recording:
http://www.autometer.com/cat_gaugede...=color_tab-tab
It matches well, you will hardly notice the lack of a silver center. The only downside is the nighttime lighting is somewhat poor, although with the right color LED from Superbrite LEDs you can match the dash very lighting rather well.
Autometer even has a custom shop now that might be able to add some unique features for those inclined.
The alternative needle lit movement may have better lighting:
But that series doesn't have the peak and memory feature. For me if I'm going to the trouble and expense I want it more useful by having the peak warning. When mine goes into overboost the warning lets me know how hard the turbo is pushing.
Old Jun 5, 2014 | 11:06 PM
luigi90210's Avatar
luigi90210
cravenspeed gauges are another id suggest, they are $599 for 2 gauges and easy to install(plug into your OBD2 port and hide the wires)
Old Jun 6, 2014 | 05:43 AM
igzekyativ's Avatar
+1 on cravenspeed
Old Jun 6, 2014 | 05:54 AM
6000pounds's Avatar
6000pounds
You guessed it. Try two MINI monthly payments expensive(close to it).
Old Jun 6, 2014 | 06:08 AM
astroBlackMetallic_Mini's Avatar
a few key things here.
1. thats an R53, not an R56
2. that is the chrono package. a factory option, only avail in R53 models. sorry.
3. there ARE other gauges that were made (boost, volts) that said Cooper S on them that were made by steward warner in conjunction with Mini (i managed to find a pair for a Steal on ebay. one in a million chance)
but again, only for R53, although i supposed you could use them maybe for R56; IF you can find them.... but thats like finding a leprechaun riding a unicorn these days; and the boost only goes to 18psi, and no idea if that steering column piece will fit an R56 (prolly not).
so your best bet is probably the autometer / marshal gauges at this point. although i have to be honest, i have little knowledge on R56 parts. so there may be something blatant i am missing
Old Jun 6, 2014 | 06:14 AM
TEEZY's Avatar
TEEZY
I like the marshall!!
Old Jun 6, 2014 | 06:23 AM
elchilo4ever's Avatar
elchilo4ever
There Nice To Have The Boost Gauge To Mash
You Other Gauges.
I Have One N' My Mini R53
Old Jun 6, 2014 | 06:28 AM
elchilo4ever
Does anyone make a boost gauge setup that matchs the factory stuff?-forumrunner_20140606_062818.jpg
Does anyone make a boost gauge setup that matchs the factory stuff?-forumrunner_20140606_062836.jpg
Does anyone make a boost gauge setup that matchs the factory stuff?-forumrunner_20140606_062848.jpg
Old Jun 6, 2014 | 07:57 AM
broncobuddha
Astro, thanks for the info. Mines a R55 so dont know if that complicates it any more.
Elchilo, which gauges are those?
Old Jun 6, 2014 | 08:11 AM
elchilo4ever
Marshall Gauge.
I Have One Boost Gauge
For Sale If You Want?
Brand New W / The Kit To Install
But Not The Pod.
I'm N' Vegas.
Does anyone make a boost gauge setup that matchs the factory stuff?-forumrunner_20140606_081042.jpg
Does anyone make a boost gauge setup that matchs the factory stuff?-forumrunner_20140606_081056.jpg
Old Jun 6, 2014 | 08:31 AM
broncobuddha
Appreciate it. Just looking and weighing my options. Just got the car so wife hasn't cleared me to start playing yet.
Old Jun 6, 2014 | 09:51 AM
TEEZY's Avatar
TEEZY
Might be a stupid question. What size is the stock "TOP TIMER" gauge in the convertible? 60mm
Old Jun 6, 2014 | 12:05 PM
elchilo4ever
Ok Buddy! ☺
Old Jun 6, 2014 | 02:12 PM
DneprDave's Avatar
DneprDave
I have Marshal gages they are the ones that Cravenspeed sells. They were made to match the MINI gages. The instrument lighting matches exactly.
http://www.marshallinstruments.com/c...per_gauges.cfm
I used the Cravenspeed adaptors for the oil pressure and water temperature. I made the gage pods myself out of 2" ABS drain pipe, I made the mount out of sheet aluminum.
Old Jun 6, 2014 | 02:19 PM
MarioKart's Avatar
MarioKart
Vendor
Originally Posted by DneprDave
I have Marshal gages they are the ones that Cravenspeed sells. They were made to match the MINI gages. The instrument lighting matches exactly. http://www.marshallinstruments.com/c...per_gauges.cfm I used the Cravenspeed adaptors for the oil pressure and water temperature. I made the gage pods myself out of 2" ABS drain pipe, I made the mount out of sheet aluminum.
Very impressive! Do you have any pix of the aluminum plate?
Old Jun 6, 2014 | 04:55 PM
DneprDave's Avatar
DneprDave
Here you go.
Old Jun 6, 2014 | 04:59 PM
broncobuddha
Wow. Nicely done sir.
Old Jun 6, 2014 | 06:17 PM
MarioKart's Avatar
MarioKart
Vendor
I love it. Would you happen to have specs or a diagram to follow. I would like to make this ASAP.
Mario
Old Jun 6, 2014 | 06:57 PM
cerenkov's Avatar
cerenkov
The "top timer" found on the convertibles is molded into the tach and is one piece. You can NOT put a aftermarket gauge in it if that is what you are thinking.
Old Jun 6, 2014 | 07:57 PM
DneprDave's Avatar
DneprDave
Mario
I've tossed the cardboard pattern I made. It took four tries before I got it right.
But, it was just corrugated cardboard with the gages attached to it, I traced it out on the aluminum with a sharpie and cut it out with a scroll saw.
The longest part was waiting for the paint to dry. Be sure to use primer for aluminum before painting it black or the paint will peel.
I had all the material in my scrap pile, so I can't tell you how much it cost.
Dave
silence2-38554
98
Sep 21, 2016 02:52 PM
wkp1219
Nov 13, 2015 07:52 AM
theblackfalcon
Oct 11, 2015 09:49 AM
flredmini
Aug 12, 2015 06:35 PM
