Drivetrain Aquamist HFS Methanol Injection Systems
Old Feb 19, 2019 | 09:04 AM
  #601
BigBoost's Avatar
BigBoost
hmm..
yeh never had that issue with my math tank
Old Feb 19, 2019 | 09:11 AM
  #602
Oldboy Speedwell's Avatar
Oldboy Speedwell
Originally Posted by scotty_r56s
A baffled tank would be amazing. My 1.15 gallon AEM tank has occasional starvation issues when accelerating out of a turn.
The search continues 😂
They make a baffled variant:
http://www.aquamist-direct.com/806-6...ffled-drilled/
Nice video demonstration:
Old Feb 19, 2019 | 09:40 AM
  #603
scotty_r56s's Avatar
scotty_r56s
My unicorn is a baffled tank that fits in the battery box on the R56. I think that would be the best place to put it to meet the "must be separated from the passanger compartment by a bulkhead" rule.
@bigboost I've had it happen on track and on some freeway onramps.
Old Feb 19, 2019 | 09:55 AM
  #604
BigBoost's Avatar
BigBoost
wired
luckily I guess I haven't
Old Feb 19, 2019 | 10:37 AM
  #605
ridinDirty's Avatar
ridinDirty
Yes tank , gauge, fav etc come with it. Just like howerton website minus hoses
Old Feb 19, 2019 | 01:27 PM
  #606
blue al's Avatar
blue al
The aquamist tank will fit in the boot of a roadster
if your buying the rest of the kit you may s well add the tank option?
i have the twin tank, only a dry installation at the moment
Old Feb 19, 2019 | 02:23 PM
  #607
oldbrokenwind's Avatar
oldbrokenwind
My Howerton tank came "baffled" --- full of ping-pong size *****, each one full of holes --- like "swiffle" *****. He told me his illuminated version (another option) wasn't compatible with the baffle version --- one or the other, or neither. No reason a bunch of swiffle ***** can't be added --- AFTER a good cleaning. Tank still holds almost a full gallon.
Old Feb 19, 2019 | 02:26 PM
  #608
scotty_r56s
Interesting. I'll give that a shot.
Old Feb 21, 2019 | 02:23 PM
  #609
oldbrokenwind
I don't know how many of these ***** it takes to fill the tank, but here's a couple pics of what they look like ---
Each ball is just slightly smaller than the cap opening.
Looks like a 6-hole pattern repeated a few times around the ball surface.
Old Feb 22, 2019 | 08:22 AM
  #610
thebombardier's Avatar
thebombardier
Lol those are ***** you use for practicing golf. Literally wiffle golf *****.
Amazon Amazon
Old Feb 22, 2019 | 10:51 AM
  #611
ridinDirty's Avatar
ridinDirty
Just what we need, some guy showing pictures of his ***** !!!
Old Feb 22, 2019 | 11:22 AM
  #612
Tigger2011's Avatar
Tigger2011
Alliance Member
Good idea. Its a terrible thing having dirty *****.
Old Feb 22, 2019 | 12:05 PM
  #613
Oldboy Speedwell
MUST TAKE THEM TO THE BALL WASHER IMMEDIATELY!!!!
Old Feb 22, 2019 | 02:31 PM
  #614
Kalibdor's Avatar
Kalibdor
Finally got a chance to look into my flow issue. Not sure about the condition of the FAV tee itself, but all this crap was built up against the screen to the flow sensor assembly. Replaced the assembly and fav tee as I had new ones anyway, going to soak the old parts in methanol overnight and test them later. System is back to working without issue. Now, what exactly is this stuff? Looks like ice, is not ice. Calling it meth poop for the time being. How can I avoid future issues, or must I just run pure methanol? Nothing has been run through the system but VP M1 and distilled water @ 80/20 mix. Or is this the water/hydrocarbon contamination issue some of you mentioned? Thanks again for everyone's help.
Old Mar 3, 2019 | 05:08 PM
  #615
Goldsmithy's Avatar
Goldsmithy
MINI Alliance Ambassador
Originally Posted by BigBoost
was there any particular reason
why you think you need a baffle tank
Just my research on the' net'. The reason was to prevent a mixture 'starvation' during acceleration...IIRC.
Old Mar 3, 2019 | 05:13 PM
  #616
scotty_r56s
You are not handling methanol without wearing chemical protective gloves and eye protection, right?
Old Mar 3, 2019 | 05:20 PM
  #617
thebombardier
I just put the outlet on the tank towards the rear, so when I'm accelerating it all goes towards the outlet. Works fine for me. *shrug*
Old Mar 3, 2019 | 05:32 PM
  #618
Kalibdor's Avatar
Kalibdor
Took the gloves off to take the pictures.
Old Aug 12, 2019 | 11:13 AM
  #619
dez's Avatar
dez
Trying to purge my system have the SYS jumper on but nothing is happening. Any help appreciated.
Old Aug 12, 2019 | 11:26 AM
  #620
Tigger2011's Avatar
Tigger2011
Alliance Member
Power on at the gauge?
Old Aug 12, 2019 | 11:36 AM
  #621
dez's Avatar
dez
Yes power is on. Pump sounds like it working but nothing coming out of the hose
water/ meth level is not the issue just topped of with water.
working on purging for long term storage
Old Aug 13, 2019 | 10:59 AM
  #622
dez's Avatar
dez
Problem resolved... had a DUH moment was trying to purge post FAV once I started pre FAV everything worked properly
Old Aug 16, 2019 | 11:16 AM
  #623
Tigger2011's Avatar
Tigger2011
Alliance Member
With the ignition on (engine not running) and the SYS jumper on the controller activates the pump and also the FAV at full duty cycle. There is an alternate purge procedure that calls for doing exactly what you did. However, I would still verify FAV operation. With the nozzle out of the inlet plumbing put the SYS jumper back and turn ignition on. You should get spray.
Another way to verify is install blanking plug in inlet tube, tape the nozzle to the windshield, turn the THRESH pot all the way counter clockwise to about the 7:00 position and start the engine. Blip the throttle a few times and you should see it spray. If not I would suspect the FAV of being bad.
Old Aug 25, 2019 | 08:11 PM
  #624
snbder4life's Avatar
snbder4life
Mini instructions
Can someone email me a copy of the mini specific instructions
cant get mine to work with throttle hfs3v1
Old Aug 26, 2019 | 11:39 AM
  #625
Tigger2011's Avatar
Tigger2011
Alliance Member
Can't email it from my phone but maybe this will help.
