Drivetrain R53 to R56 Front Brake Conversion aka Poor Mans JCW Brakes Kit
Thinner stick on weights can be found, they are like 2mm high or something and very wide. Some tire places have them.
Cool!! I'll need to check this out. I currently have a set of 15" 7 holey's (I planned to use for snow tires) and a set of 16" : (don't know their designation- wonder if there is a site that catalogs the rims offered like BMW's have)
I hate to dump perfectly good lightweight rims but this car likes to go and is less inclined to stop when I want it to. SO I think I need an upgrade...
If I have the R84 x-lite rim and the R56 brake upgrade will swap and work with these rims, what should I look at for winter tires?
I purchased the 15" holeys for winter tires. Now I'm wondering if I should sell the holeys, and use the 16" x84's for the winter tires so I can maybe move up a size to 17" - Something light, inexpensive and able to handle a wide grippy tire.
My plan is a Quaife LSD, new clutch (maybe flywheel) assembly, maybe some shock/spring work, maybe a sway bar and the brake upgrade. Does this sound right or am I missing something?
https://www.northamericanmotoring.co...w-upgrade.html
Ok bud, so the R56 s rear rotors fit fine, but the guy at auto parts store says the part is different between the R56 s and R53 's rear rotors?? So are they different but the r53 caliper will fit fine?
Also (sorry), the break wear sensor. If I'm doing all four rotors from the R56 s, what sensors do I get? All R56 s? R56 s front and R53 's rear? The parts guy confirmed that the wear sensor part is different from R56 s and R53 's rear.
And I need all four new ones if the working light has been tripped right?
So to be clear, my endgame is full front R56 s conversion, back just want R56 s rotors because they come in the package, and would look better to do all four.
Thanks man
Thanks man
If I can get the R52 sensor to fit the R56 pads, I'll let you know that too. For now it's sleep time, tomorrow I have to figure out how to separate the hard line connection without destroying or rounding off the nuts. It's totally rusted shut and I can feel how bad it really wants to just snap.
sorry for the necrobump. I did this swap years ago but the r56 soft lines appear to have a different threaded flange (for chassis side). They work fine but I could not use the original clip to hold them to the chassis. Does anyone have a solution? I think (by memory) the r53's were smooth round while the r56 have some tabs. I can either drill the hole bigger on chassis or grind off the tabs.
this is the clip I'm talking about:
