Drivetrain Standard motor 380CC injectors
Old Jun 8, 2022 | 03:51 AM
  #576
mrtutz's Avatar
mrtutz
Originally Posted by dmath
I installed a set of Bosch 380cc injectors that are recommended by adriancl. They are made for an Audi TT but have the same specs as Mini JCW injectors and do not require an adapter. So far they are running very well. FCPEuro had them for about $140/set when I bought them a few months ago.
I’ve just done the same and I’m waiting on the programming bits / injectors arriving.
for reference, the VAG / BAM 225hp engine uses Bosch part number 0280156063
Old Jul 11, 2022 | 09:44 PM
  #577
gb25jr's Avatar
gb25jr
how are these Injectors running? About to order the Bosch 380s from rock auto as well...any info?
Old Jul 11, 2022 | 09:45 PM
  #578
gb25jr's Avatar
gb25jr
380cc
Old Jul 11, 2022 | 11:25 PM
  #579
mrtutz's Avatar
mrtutz
They run fine. They’re the right size and have the same connection as the originals, so you don’t need to fit pigtail adaptors to the wiring loom
Old Jul 12, 2022 | 06:09 PM
  #580
dmath's Avatar
dmath
They're running great in my car as well. My car had the 2003 JCW kit which didn't include the airbox or injectors. Since I added both of those, I recently installed a facelift ECU with the 210 tune. A really good upgrade.
Old Jul 12, 2022 | 09:21 PM
  #581
mini_me123's Avatar
mini_me123
210 tune is factory sw/hw version? Plug & play? immobi?
Old Jul 13, 2022 | 02:19 AM
  #582
dmath's Avatar
dmath
Yes, it's the factory tune and is plug & play. Literally, I dropped in the new ECU, the car started right up and ran like a champ. I don't know about the immobilizer but I suspect it is disabled. Based on how I use my car, it doesn't matter to me. MrBlah (NAM user name) is my dealer for this particular bit of crack. You can check with him. In my opinion, it's well worth it.
Old Jul 16, 2022 | 05:39 AM
  #583
daviday's Avatar
daviday
I saw these as well different part# it seems?
Old Jul 17, 2022 | 06:58 AM
  #584
mini_me123's Avatar
mini_me123
​​​​​​​06A906031BC per link.
Originally Posted by euromakx
im running 380cc bosh injector from audi tt225 direct bolt on no adapters same o-ring... work perfectly.
per original poster who brought them to our attention.
Old Jul 17, 2022 | 07:00 AM
  #585
mini_me123's Avatar
mini_me123
so you still needed the tune flashed onto an ECU? I guess I'm asking if you just bought an ECU off wrecker/ebay and dropped it into your car (sounds like MrBlah) flashed it for you. How much for reflash?
Old Jul 17, 2022 | 09:10 AM
  #586
daviday's Avatar
daviday
Wondering the same.
Old Jul 17, 2022 | 07:16 PM
  #587
dmath's Avatar
dmath
I wouldn't say I needed the tune but rather that I wanted it. My 2003 has the JCW kit. At that time, the kit did not include the airbox or 380cc injectors and the tune was 200 hp. Once I added the airbox and injectors that appeared in the later kit, I thought I might as well get the tune that went with that kit.
Yes, my new ECU is the work of MrBlah. Very straightforward transaction.
Cooper Springs
Apr 27, 2020 05:36 AM
Mrfoca
Dec 16, 2016 08:52 PM
03EmCeeS
Feb 20, 2012 01:42 PM
PinesMini
Apr 24, 2010 02:59 PM
Tom2112
Mar 22, 2010 10:34 PM
