Drivetrain Clutch opinion
Old Jun 11, 2013 | 04:34 PM
jmgpr7's Avatar
jmgpr7
Clutch opinion
My OEM clutch is burned out. I'm upgrading to a Hybrid turbo and adding stage 4 with the AP. I know i need a performance clutch that will hold at least 275lb. tq. What clutch can i buy that will hold the torque. I don't want to buy the kit with the flywheel. I heard that you can lose tq. and gain RPM but i prefer tq.
What about SPEC ?
other suggestions?
thanks
MOD: Alta intake and turbo inlet tube, Hot and Cold side Tubes, Alta FMIC,3" catless DP and 3"catless exhaust, Upgraded BOV, Stage 3 AP.
Old Jun 11, 2013 | 05:12 PM
MNIPWR's Avatar
MNIPWR
275, haha. The stock clutch will be fine. But I bet your flywheel will need replacing once they take it out.
Old Jun 12, 2013 | 06:44 AM
solskjaer1999's Avatar
solskjaer1999
If you go with a Spec Stage 2 or 3 clutch I would recommend getting a new flywheel even if it is OEM. Generally speaking when a clutch goes out the flywheel also needs to be replaced as well.
Old Jun 12, 2013 | 07:02 AM
countryboyshane's Avatar
countryboyshane
Factory JCW spec flywheel and clutch or go all out and go for OS Giken.
Old Jun 12, 2013 | 08:05 AM
Helix13mini's Avatar
Helix13mini
Go stock. You'll thank me in the long run.
Old Jun 12, 2013 | 08:09 AM
jmgpr7's Avatar
jmgpr7
Thank.
Old Jun 12, 2013 | 08:12 AM
jmgpr7's Avatar
jmgpr7
I have a friend that has a JCW and started using AP STAGE 3 and the clutch went out in less than 20k miles. Is the JCW better than the MCS?
Old Jun 12, 2013 | 08:22 AM
jmgpr7's Avatar
jmgpr7
Well i think stock will be. I'l keep researching on the stock JCW CLUTCH vs. performance aftermarket Clutch.
All the people that are saying to go stock. Are you running stock cars or modified car with tuning?
Old Jun 12, 2013 | 08:50 AM
countryboyshane
Failures on the mighty OS Giken Eric? Or are you saying this from a cost standpoint?
Old Jun 12, 2013 | 02:46 PM
MNIPWR's Avatar
MNIPWR
If your friends clutch went out in 20k it was probably his fault. The standard MCS clutch will be able to hold the power.
Old Jun 12, 2013 | 02:57 PM
jmgpr7's Avatar
jmgpr7
Old Jun 15, 2013 | 04:40 AM
tommydh's Avatar
tommydh
IMO Idon know if it was the clutch or a bad bleeding after installation but I had a Spec stage 2 + installed when factory went up. The warranty is 120 days mine took a dump at 133 only 10k miles on it only mods were BOV spring and intake. I just had the dealer put in stock JCW clutch Im not sure if the S is same I may haqve paid more for nothing beter but Stock clutches have 2 year warranty. Unfortunately the other option is the Giken clutch but you cant drive that on the street its a race item. I have had Spec clutches in other vehicles w/o problems but I have seen alot of people with the issues with the Spec clutches.
Old Jun 15, 2013 | 04:42 AM
tommydh's Avatar
tommydh
Thank.
I AGREE and the freakin idiots both times I had replaced I asked about flywheeresponse well check it out of course needed replacing instead of ordering when I said it took an extra wek or so.
Old Jun 15, 2013 | 05:46 AM
countryboyshane
OS Giken sells the GTR version, which is a touring version. The price is still terrible though!
Old Jul 19, 2013 | 10:44 AM
MOLr50's Avatar
MOLr50
buy my stuff its cheap and good quality...
Sep 23, 2015 12:59 PM
Sep 23, 2015 12:52 PM
Sep 23, 2015 12:39 PM
Sep 22, 2015 02:05 PM
Sep 16, 2015 06:22 AM
