Drivetrain Larger OEM Intercooler - JCW R60
Old May 12, 2013 | 04:38 PM
chrunck's Avatar
chrunck
Interesting post over on the Countryman forums. Someone with an R60 JCW said his MINI came with a larger than normal OEM FMIC. He said it has plastic end caps, but is much larger than the standard FMIC. His measured dimensions are:
11" high
23" wide
2" thick
R60 JCW part number: 17517632764
R60/R56 Cooper S is 17512751277
Thread here: https://www.northamericanmotoring.co...-question.html
There aren't a lot of details, but I thought some of you with non-R60s may be interested in a factory part vs aftermarket. I may have gotten one instead of the Helix if I had known about it. Can't say for sure about fitment on a non-R60, but it's an interesting development.
Old May 12, 2013 | 04:46 PM
Porthos's Avatar
Porthos
You do realize this is the Hardtop section, right?
Old May 12, 2013 | 05:57 PM
MNIPWR's Avatar
MNIPWR
Obviously he does. He was pointing out that it might be able to fit our cars as a factory replacement, instead of buying aftermarket. But that would of required reading to figure out
Old May 12, 2013 | 09:57 PM
Bakerbrdz's Avatar
Bakerbrdz
I believe mine has plastic end tanks as well. But good find!
Old May 12, 2013 | 10:36 PM
Porthos's Avatar
Porthos
From the thread.
I am not sure that will fit. Some one who is near one should do a test fit.
Also at $298 on Realoem without a dealer mark up you might as well just go aftermarket unless you are one of those die hard "my warranty" people.
Old May 13, 2013 | 06:21 AM
chrunck's Avatar
chrunck
Actually, this is the 2nd Gen section, which includes more than hardtops.
Old May 13, 2013 | 07:54 AM
Porthos's Avatar
Porthos
The hardtop is the only one that matters.
Old May 13, 2013 | 02:23 PM
RobMuntean's Avatar
RobMuntean
Lmfao!
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
blackie
Oct 2, 2015 07:41 PM
FLYM1N1
Aug 16, 2015 01:15 PM
Aug 13, 2015 12:57 PM
