Drivetrain Spot compact car exhaust
Old Apr 13, 2004 | 03:56 PM
Miniracer_03's Avatar
Miniracer_03
well i was thinking and im going to do the same thing that SCC did with there mini. ive got a muffler on the way from ebay and a frind is fabbing up a aluminium plat for the battery box. should have it done by the end of the month. has anyone else here tried this? i bet it is really loud and im to cheep to pay $600 for a complete exhaust where i can build one for under a hundered. thanks keep motoring
Old Apr 13, 2004 | 04:05 PM
Storer's Avatar
Storer
I think Peter @ M7 swapped the stock battery for a smaller aftermarket battery and moved it up into the boot, not sure if he changed to exhuast to a striaght back pipe, though. Sounds like a great idea to me.
Old Apr 13, 2004 | 04:41 PM
Sweetmini_03's Avatar
Sweetmini_03
good luck and post picts when your done. if you can post a sound clip i wana hear how loud it is.
Old Apr 13, 2004 | 04:48 PM
TonyB's Avatar
TonyB
This link should take you to page 12 of this thread. If so, scroll down to post 168 to see mine in it's preliminary/prototype stages:
http://www.mini2.com/forum/showthrea...muffler+choice
With a delivery today or tomorrow, I should have it complete by the weekend...
Old Apr 13, 2004 | 04:50 PM
M7's Avatar
M7
Hi there...
It's a great idea and very easy to accomplish, here's the break down what needs to be done.
1. remove the original exhaust box(2) this will leave you with the more or less straight pipe
leading from the catalytic converter.
2. Remove the battery and asociated wiring,the orange fuse box needs a good tug uppwards to release.
3. Get a hold of either a plasma cutter, or a sawzall. Cut the battery box out...
4. meassure out how big of a aluminum plate you need. have it cut on a shear so it looks good.
5. get construction adhesive, steel rivets and a rivet gun.
6. spread the adhesive on the parameters of the opening, drill holes and rivet in the plate
it will look totally FAB.......
For the exhaust remember back pressure is a must so you could lose hp very easily. My recomendation
would be to go with a 24" Supertrapp exhaust that you can change the BP just by changing the amount of rings.
If you need some images of my installation or more help with the project, feel free to call me any time.
peter horvath
562-712-3270
Old Apr 13, 2004 | 05:21 PM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Have you done some comparisons with different numbers of disks? I believe that Garfield posted that he had the best numbers using all 8 of his disks (hence the lowest backpressure):
http://www.mini2.com/forum/showthread.php?t=13156
In another thread, he tried 6, 8, 10, and 12 disks and the 12 disks made the most power but slightly less torque than 10 disks.
http://www.mini2.com/forum/showthread.php?t=26074
In each of the above cases, the greatest number of disks (the least backpressure) made the most power.
_________________
SHOW ME THE NUMBERS!
...How Fast is Your MINI?...My Mods...
Old Apr 13, 2004 | 05:31 PM
Trippy's Avatar
Trippy
Andy, thanks for posting those two links.
It's great to read the results of actual experiments.
Otherwise, it's an opinion, and I'd like to make decisions on experiments, not opinions.
Old Apr 13, 2004 | 06:03 PM
TonyB's Avatar
TonyB
Miniracer, I hope that your soon to arrive muffler is not a center/center type. If so, it will require a bend upward for a proper exit out the valence. If I recall correctly, you will need to go up about 3". My Borla Turbo center/offset got me in the ballpark, and from there the hangers got me properly centered...
One way to create more back-pressure is to pump more air :smile: As the engine gets more powerful, the desire for more backpressure will be less and less, at least from what I have read. When I'm done with my engine mods, I'll dyno to see how I can optimize the hp/torque, give & take combo. If more back pressure is disirable, I'll do so at the cat to strike that fine balance. Adding back pressure afterwards is not that bad, adding more flow though requires planning from the beginning. If you go 2.5" and avoid the radical bends of the stock system, like with this "straight" approach, you'll have plenty of "room" to push this engine's output.
Good luck!
_________________
2003 IB MCS
Old Apr 13, 2004 | 09:44 PM
DancesWithCones's Avatar
DancesWithCones
You need to read the SCC article carefully. They gained very little torque and lost 4 peak HP. You may wish to choose your components carefully. Frankly, the one-ball may be a better solution. Either way, good to see someone willing to try something different and unproven.
Old Apr 14, 2004 | 04:56 AM
Miniracer_03
thanks for the feedback, if this does not work out i guess i shell out the cash for like a uuc or something.....but heck if it does then great. will post picts as soon as im done.
ASRman
Aug 13, 2015 09:33 AM
papawhiskey
Aug 10, 2015 09:31 PM
bctf1
Aug 6, 2015 12:55 PM
PatrikKN
Aug 5, 2015 09:10 PM
