Drivetrain How is this bypass valve different that what WayMotorWorks sells?
Old Jan 22, 2013 | 12:52 PM
Mindspin311's Avatar
Mindspin311
While doing some research, I came across this on ECS's website
http://www.ecstuning.com/Mini-2010-C...alve/ES253297/
It looks exactly the same as the valve WMW sells. All the VAG 710D bypass valves look different than this unit.
Can anyone shed some light?
Old Jan 22, 2013 | 02:44 PM
bmwr606's Avatar
bmwr606
the ecs tuning diverter is the mini oem stock piece
scott
Old Jan 22, 2013 | 02:45 PM
Mindspin311
Then, how is Way's different?
Old Jan 22, 2013 | 03:02 PM
bmwr606's Avatar
bmwr606
i believe Way's is sourced from audi or vw, functions the same as the mini, but has stronger spring and actuator coil to work faster and with more boost if you have mods
scott
Old Jan 22, 2013 | 03:29 PM
MyYellow 07's Avatar
MyYellow 07
I have the WMW one, and my seat o pants ometer, says that the WMW description would make sense. I did this with the noise maker and boost resonater delete, and the complete combo seems to be snappier to my waste band. But then again, I have no data to back any of it up.
Old Jan 22, 2013 | 04:21 PM
Porthos's Avatar
Porthos
Spend the extra $$$$ and get the Forge one. It is the best on the market.
Old Jan 22, 2013 | 07:12 PM
MinMin2010's Avatar
MinMin2010
I second that motion.
I got mine from Way and installed it myself. I do not know why BMW does not use something like this from the beginning.
Old Jan 22, 2013 | 10:15 PM
Hujan's Avatar
Hujan
You're talking about the recirculation valve or the blow-off valve?
Old Jan 24, 2013 | 05:45 AM
TerminalVelocity's Avatar
TerminalVelocity
Alta CRV. Does away with stupidly relying on the ECU for actuation and works like a DV should.
Old Jan 24, 2013 | 11:19 AM
Sacred Disorder's Avatar
Sacred Disorder
The Forge is a good DV. I had it installed ofr a while and switched to the Alta. I do like the the Alta better but either will be a good improvement.
Old Jan 24, 2013 | 03:34 PM
RobMuntean's Avatar
RobMuntean
Yeah I heard the alta was better(people that have it), definitely getting it right before I get my tune.
wkp1219
Nov 13, 2015 07:52 AM
flredmini
Sep 3, 2015 07:15 PM
minicoclub
Aug 25, 2015 09:07 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
quickquest88
Aug 8, 2015 08:45 PM
