Drivetrain So the teardown begins
Old Mar 2, 2013 | 10:33 PM
  #151
MNIPWR's Avatar
MNIPWR
Crappy deal.
Old Mar 3, 2013 | 12:08 AM
  #152
ThePenl's Avatar
ThePenl
Why don't you try Evolve for your mapping?
They have boost cut free maps you know...and you can upload their tune by yourself very easily.
Old Mar 3, 2013 | 07:42 AM
  #153
MNIPWR's Avatar
MNIPWR
Nice to see your input in this neck of the woods
Old Mar 3, 2013 | 09:56 AM
  #154
countryboyshane's Avatar
countryboyshane
Originally Posted by Porthos
Sorry I have not updated this thread. I really haven't seen the car until Friday. I took it to my local mechanic the week after I last posted to have them install my KWV2s and Vorshlag camber plates. Also I asked if they good figure out why it is boost cutting and throwing a check engine light. Well as they were road testing it the hood flew up and busted the windshield out. So the shop replaced both the hood and the windshield free of charge.They disconnected my meth kit (which I am now going to have to reattach once it is tuned) to find out if that might have been causing the problem. It was not the problem. I put them in contact with Jan which they got a hold of him once and not a whole lot was really worked out. I repeatedly called Jan with no answer and no return call. So I decide to go elsewhere. I talked to my friend Dez who works with a gentlemen by the name of Huby who has been tuning MINIs for about 10 years now. Huby and I thought it would be in my best interest to flash the car back to stock. Well I had the shop do it and they placed on the most up to date software on my MINI. Well with some coordination I met with Huby last night for a street tune. The bad part was that Dimsport did not have the software update to be able to tune my car. So Huby copied it and sent it off in hopes of having it today or tomorrow. In the mean time I took it out to an Auto Cross event put on by the local BMW chapter and had a blast. I ran a faster lap with my car going into limp mode then with it running normal. If I did not do this I would have probably lit my MINI on fire today because I am completely wore out over this whole boost cut and tune issues. Though I do know now why it does it and that is another whole conversation for another day.
I had this same problem three years ago with Mynes tuning. Dealer flashed the most up to date software onto my ECU about a month before a tuning party in my hometown and I couldn't get a tune when I got to the party. Talk about a buzz kill. I eventually just went with Evolve and have been very happy.
Old Mar 3, 2013 | 10:04 AM
  #155
Porthos's Avatar
Porthos
Okay but, I do not want a canned tune. I have been trying now for 2 years to get a dyno tune to fit what I have done to the car. And no data logging is not the same.
Old Mar 3, 2013 | 01:44 PM
  #156
MNIPWR's Avatar
MNIPWR
I believe evolve can do a distant dyno tune. You record your run with there software then send it to them and they send it back. Then repeat till done.
Old Mar 3, 2013 | 02:10 PM
  #157
Porthos's Avatar
Porthos
That sounds like a lot of coordination.
Old Mar 4, 2013 | 09:52 PM
  #158
Mkpoto's Avatar
Mkpoto
easiest way to do it is setup a dyno time with Evolve. The earlier in the day you can do the better (they are about 6 hours ahead) If you have any questions you can email alex@evolveautomotive.com he can coordinate it for you
Old Mar 5, 2013 | 07:09 AM
  #159
Porthos's Avatar
Porthos
Hubie is going to be calling me today to let me know if Firday will be a good day becuase he got all the stuff back from Dimsport. Evolve would be great but, that is a back up if Hubie falls through. Also here is a photo from Auto cross over the weekend.
Old Mar 5, 2013 | 10:49 AM
  #160
MNIPWR's Avatar
MNIPWR
What is on your roof
Old Mar 5, 2013 | 11:22 AM
  #161
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
A big sticker?
Old Mar 19, 2013 | 05:07 AM
  #162
Braminator's Avatar
Braminator
Old Mar 19, 2013 | 07:11 AM
  #163
Porthos's Avatar
Porthos
Yeah still waiting on the tune.
Old Mar 19, 2013 | 07:48 AM
  #164
IzzyG's Avatar
IzzyG
Question: When your latest mechanic(the one that busted up your windshield) disconnected your meth kit to see if it was the cause of the boost cut/CEL, did they resolder the ECU wastegate wire? Simply disconnecting the brown/white wire from the meth kit isn't sufficient(as I found out from Richard) to get rid of the boost cut/CEL.
Old Mar 19, 2013 | 07:19 PM
  #165
Porthos's Avatar
Porthos
They completely disconnected the kit completely. I found out that the MAF and I want to say the MAP sensor have an algorithm that are suppose to read certain information, that being the amount of air coming into the intake, and they are suppose to rise at the same rate and what is happening is that the MAF is reading a certain amount of air coming and the turbo is reading another level. This is causing me to under boost in 1st-3rd and the boost to about normal levels in 4th-6th but that is when it is reading different levels boost cutting and going into limp mode. The guy that is tuning it knows what to do because is being a PITA right now and pushing me off.
Old Mar 20, 2013 | 08:00 PM
  #166
Agbullet25's Avatar
Agbullet25
I can certainly understand your frustration, but just remember, all good things come to those who wait
Old Mar 20, 2013 | 08:39 PM
  #167
Porthos's Avatar
Porthos
It is still aggravating and can get very stressful,
Old Mar 20, 2013 | 08:45 PM
  #168
DICKS GARAGE R53
Tell me about it!
Old May 20, 2013 | 08:21 PM
  #169
Porthos's Avatar
Porthos
So I figure it has been a little too long since I have updated. I am finishing having the carbon cleaned out and the water/meth hooked up. I am going to do a track day Saturday at Streets of Willow. I test drove it at the shop about 2 weeks ago with no boost cut issues. That includes putting it into 6th at 30ish and flooring it. After the track day I am pulling the ECU and mailing it to PAW in Miami to have it tuned. I realized that MINI tuners(the popular ones) can be a bunch of jack asses and now I after being blown off several times I can no longer back certain parts or companies, namely RMW.
Old May 21, 2013 | 06:48 AM
  #170
countryboyshane
I am currently trying to set a customer remote tune up with Evolve. My biggest hurdle is finding someone local in Michigan with a Bavarian Technic tool or similar to read boost & ignition parameters from my car. All I would need to do from there is find a Dynojet facility, set up a morning live meeting with Evolve and away we go. I think i'm just going to buy the tool since I'm obviously in with this car for the long term. I'd be a bloody fool to get rid of my toy after so many hours making it my own. Good thing my mid-life crisis is a very long ways away.
Old May 21, 2013 | 03:47 PM
  #171
Porthos's Avatar
Porthos
Yeah I am going to try one more time with PAW tomorrow and Evolve is going to be the one I call if PAW falls through.
Old May 22, 2013 | 07:11 PM
  #172
Porthos's Avatar
Porthos
Got my MINI back today. Did the carbon cleaning and now I just need to button a couple things up and tune and I will golden.
Old May 22, 2013 | 07:17 PM
  #173
Braminator's Avatar
Braminator
Old May 22, 2013 | 08:39 PM
  #174
Porthos's Avatar
Porthos
Old May 22, 2013 | 08:58 PM
  #175
RobMuntean's Avatar
RobMuntean
Why would PAW not follow through? I'm going with them since they're basically the same as RennTech.
