Drivetrain My build thread.
Old Jan 5, 2013 | 05:10 PM
  #126
ThumperMCS's Avatar
ThumperMCS
Originally Posted by Cone Assassin
My understanding was that the ceramic coatings deflect heat evenly, preventing hot spots on the pistons where detonation may occur. I've disassembled many engines with pockmarks around broken ring lands which I suspected were areas of high temp within the combustion chamber.
Instead of meth, do you have E85 in your area? That would give you a cooling effect similar to water/meth in addition to higher octane.
Also I am waiting for the day that someone runs an N12 head without DI (back to pulsed injectors on a fuel rail). Might be more tuning potential that way, as well as eliminating the carbon problem altogether. Just a side thought that came to mind looking over this thread.
Will be following to see how it turns out!
Until someone develops a full standalone ECU, good luck trying to convert the car to port fuel injection. Even with a fully built motor, the N14 will never be able to reach its full potential without a standalone.
I am excited to see MNIPWR's results though, I applaud him for keeping us all updated on his build. MNIPWR...let me know when you're gonna have Jan tune it, I'd like to be there...I'm right by the shop. It will bring back memories of when we spent countless hours tuning my MCS w/ JCW turbo
Old Jan 5, 2013 | 05:21 PM
  #127
MNIPWR's Avatar
MNIPWR
Unfortunately I am no longer in Socal. The mini club here is getting him to do a tune day.
Old Jan 5, 2013 | 05:22 PM
  #128
ThumperMCS's Avatar
ThumperMCS
Oh that's right...I forgot you are in AK!
Old Jan 5, 2013 | 05:58 PM
  #129
Cone Assassin's Avatar
Cone Assassin
The beauty of the N12 is that it is port fuel injected (and can be coded into his R56 S). An AEM piggypack on the N12 ecu can surely handle the job. If anything, that unlocks any limits on the DI injectors as far as flow and HP.
I don't want to hijack, so on with the show .
Old Jan 6, 2013 | 03:52 AM
  #130
Stage3GTI's Avatar
Stage3GTI
Stand-alone is not necessary for big power and imho is not the way to go.
The MED17 ECU can be made to sing and dance if necessary. If you need more fuel than the stock system can provide when fully tuned there are a few ways to solve that problem while retaining the stock ECU.
Like anything, it depends on your intended use, power goals, and budget.
The OP should speak with his tuner about what, if any, additional changes need to be made in order to reach his goals.
Good luck and have fun.
Old Jan 7, 2013 | 12:13 PM
  #131
ThePenl's Avatar
ThePenl
Bosch Motorsport produces some aftermarket ECU options for the DI configuration...ECUs for controlling DI engines, DI drivers for each injector, larger injectors, HPFPs etc...
Not a cheap option though...not to mention that these will only drive the motor, not the cabin!
Port injection has been succeeded indeed in the UK by a company called MiniCraft. They converted the MTR car into port injection with a standalone ECU, aluminum intake manifold, injectors, fuel pumps, large turbo etc...
Sadly it didn't end up well..it caught fire twice while racing and no further info was shared!
There is info about this in www.minitorque.com
Old Jan 8, 2013 | 03:24 PM
  #132
MNIPWR's Avatar
MNIPWR
If they can build a WRC engine out of our block and run it with motech electronics i'm sure its fully possible to do anything we want with enough money.
Old Jan 9, 2013 | 05:27 AM
  #133
countryboyshane's Avatar
countryboyshane
Everytime i watch those WRC videos I say, "Man, that engine sounds NASTY! How can I get that engine in my car?!"
Then I remembered that I chose to be an engineer instead of a surgeon for a career choice
Old Jan 9, 2013 | 05:53 AM
  #134
TazMinianDevil's Avatar
TazMinianDevil
With money and time, all things are possible!
Old Jan 9, 2013 | 01:57 PM
  #135
MNIPWR's Avatar
MNIPWR
I decided to spruce up my under hood look a bit. Got the intake back today.
Old Jan 9, 2013 | 02:26 PM
  #136
TazMinianDevil
That will be easy to locate. Even in the dark. Blindfolded. With the hood closed... ;-)
Old Jan 9, 2013 | 02:48 PM
  #137
TerminalVelocity's Avatar
TerminalVelocity
Very much like!!
Old Jan 9, 2013 | 03:41 PM
  #138
MNIPWR's Avatar
MNIPWR
Got my turbo back!
Old
New
Compressor
Exhaust
Old Jan 9, 2013 | 05:53 PM
  #139
llewellyn's Avatar
llewellyn
I'm excited. That looks pretty nice!
Old Jan 11, 2013 | 12:27 AM
  #140
p8ntbollr's Avatar
p8ntbollr
Got my turbo back!
Old
New
Compressor
Exhaust
looks GORGEOUS. is that from gpop?
Old Jan 11, 2013 | 12:43 AM
  #141
MNIPWR's Avatar
MNIPWR
Yeah, they do good work.
Old Jan 11, 2013 | 12:54 AM
  #142
MNIPWR's Avatar
MNIPWR
For shitzingiggles here are a couple more pics.
Downpipe- with cat removed.
Heat Shield
Old Jan 11, 2013 | 01:36 AM
  #143
p8ntbollr's Avatar
p8ntbollr
What all services did you have them do? And can you give us a ballpark figure as to how much it was? If you don't mind of course
Old Jan 11, 2013 | 01:55 AM
  #144
MNIPWR's Avatar
MNIPWR
They cleaned everything, rebuilt everything, modified the exhaust wheel, put in a larger compressor wheel, and balanced it. It's $695+$25 for shipping.
Old Jan 11, 2013 | 12:19 PM
  #145
countryboyshane
That's a great deal for a rebuilt (and modified) turbo considering a new one is +$1800!!
Old Jan 11, 2013 | 12:55 PM
  #146
MattyKHZ's Avatar
MattyKHZ
1st I've seen of this thread. Looking forward to seeing the results.
I will probably have to do mine once all my work is complete.
Old Jan 11, 2013 | 04:43 PM
  #147
ra2fanatic's Avatar
ra2fanatic
so much win in this thread already
Old Jan 12, 2013 | 12:44 AM
  #148
Ch28Kid's Avatar
Ch28Kid
I subscribed to this thread! Keep on posting! =D
Old Jan 12, 2013 | 09:57 PM
  #149
Porthos's Avatar
Porthos
Sweet! I should have my turbo back Thursday. What did you do to your DP and heat shield?
Old Jan 14, 2013 | 12:24 AM
  #150
MNIPWR's Avatar
MNIPWR
Just high temp paint to resist rust and clean up the hideous heat shield.
