Drivetrain Exhaust options / advice
Old Aug 18, 2012 | 09:53 AM
DVS DEA's Avatar
DVS DEA
So i currently have a one ball mod and was thinking about upgrading the exhaust but am going cheap the two are on ebay, one being by obx and the other is just a clone. Both are within $250 shipped. Will the exhaust from ebay be an improvement over the one baller I have now? Thanks for the help. Also not looking at the overpriced ($400+) exhaust.
Old Aug 18, 2012 | 10:21 AM
leaf_fan_1988's Avatar
leaf_fan_1988
Wow, be glad you live where you are. An exhaust in Canada for a standard cooper starts at $600. The cooper s ones are in the $1,200 and up range. The stock S exhaust is 8-1200 at the dealer I think.
Old Aug 18, 2012 | 07:49 PM
ERIK06MCS's Avatar
ERIK06MCS
Honestly isnt going to help you. Gains from one ball have been debates but shouldnt be more than a couple ponies. What you mostly get is weight savings which youd give back up adding a dual muffler exhaust like obx or similar.
Why not go for obx header. One ball exhaust is fine as it is. Add a header and weld your oem cat onto the test pipe flanges and now you've got a good budget exhaust worth roughly 10 ponies.
The header will also add extra exhaust sound if thats what you're goimg for.
Old Aug 22, 2012 | 12:21 AM
dubstepsteve's Avatar
dubstepsteve
agreed
unless your just looking for a different sound theres no gains. stick with the one ball since its already done and your on a budget. save for the header
Old Aug 23, 2012 | 11:40 PM
DVS DEA's Avatar
DVS DEA
Great advice!!! I am looking into OBX headers!!
Old Aug 24, 2012 | 02:50 AM
Blackbomber's Avatar
Blackbomber
Originally Posted by DVS DEA
...one being by obx and the other is just a clone.
I find that statement a tad ironic, as OBX is, itself, a SuperSprint copy. I'm not sure if OBX are still producing headers without the flex joint, but don't cheap out on that. There have been many reports of cracking on the non-flex joint models, for obvious reasons.
Good luck, and let us know how you like it.
Old Aug 24, 2012 | 06:35 AM
DVS DEA's Avatar
DVS DEA
I meant that the other exhaust didnt have a name linked to it. They are both clones.
There are other headers that have the flex part on ebay but they are 4 into 1 where obx is 4-2-1 piping. Which would be better? Anyone have problems with the other one?
Old Aug 29, 2012 | 11:05 AM
tremperj's Avatar
tremperj
I see a lot of exhausts go up for sale out in CA. Hang on to some money, be patient, and a worthwhile exhaust will be found. Go for good names– Borla, Magnaflow, Milltek, Stratmosphere/Invidia... you know what I mean. Worth the time/energy versus poor quality eBay specials.
Old Aug 29, 2012 | 07:27 PM
Blackbomber
You were pretty clear, I was just being a wisenheimer.
I believe the answer to which header design is better is subjective. I think it depends on the RPM range in which you are looking to maximize power. I could very well be backwards, but I think I recall the 4 into 1 designs will outperform the tri-Ys at high RPM, and the tri-Y will scavenge and create more torque at lower (midrange) RPMs. But I don't know the exact ranges, and I'm sure it varies between manufacturer. It would probably be counter productive to mate a low RPM header to a high RPM camshaft. The factory is 4 into 1 but has shorter primary runners than the aftermarket (catless) offerings. Long runners will boost low end, so the factory piece could be considered a loose / loose from the above perspective.
Teh
Aug 22, 2022 04:37 AM
Mr Wiggles
Aug 20, 2015 07:52 PM
Aug 12, 2015 01:24 PM
massmini03
Aug 12, 2015 11:19 AM
papawhiskey
Aug 10, 2015 09:31 PM
