Drivetrain Need new upper engine mount - VibraTechnics?
Old Jan 23, 2013 | 04:10 PM
  #76
ntn125's Avatar
ntn125
Send ColinGreene a message. I got my VT mount from Colin and like it very much.
Old Jan 23, 2013 | 06:25 PM
  #77
jplants1's Avatar
jplants1
I too am very pleased with the customer service Colin provided. The VT mount is an outstanding unit. Just give Colin a try.
Old Jan 26, 2013 | 06:04 AM
  #78
BoostCzaR53's Avatar
BoostCzaR53
Are the 02 mcs upper mounts different? If so do you offer one for me mr colin
Old Jan 26, 2013 | 06:20 AM
  #79
Braminator's Avatar
Braminator
Yes they are different.
Old Jan 26, 2013 | 10:25 AM
  #80
FredoinSF's Avatar
FredoinSF
Originally Posted by FredoinSF
Found the telltale thick blue goop in the garage in a familiar spot. That means my 06 R53 blew its 4th OEM mount at 85k miles. The current one was installed last summer and only has 5k miles on it. Time to look for an alternative to OEM.
Anyone know where to procure these in the States?
Found the receipt for the one installed last summer. It was Aug 2nd and it has 3,300 miles on it. I wonder if it's a record for the lowest miles on the OE mount.
Ordering the VT mount since the R53 is a keeper.
Old Jan 26, 2013 | 10:42 AM
  #81
ColinGreene's Avatar
ColinGreene
Yes they are different, and Yes their is a replacement.
For you to have killed one that fast it leads me to think that your lower mount is potentially also trashed.
id check the webbing for tears.
Old Jan 27, 2013 | 09:31 AM
  #82
JCWSLAYER's Avatar
JCWSLAYER
How much does one for a 10/03 build MCS cost ? PM please.
Old Jan 27, 2013 | 12:55 PM
  #83
FredoinSF's Avatar
FredoinSF
Thanks Collin, I will do that.
I found replacement instructions in another thread and it seems like it can be done with one special tool, and a little common sense. I usually do fluid and brake changes myself, did shocks on a Jeep GC once, so I'm tempted to tackle this on my own. Thoughts on DIY?
Old Jan 28, 2013 | 12:07 PM
  #84
CubanoPete's Avatar
CubanoPete
I replaced mine when I changed out my pulley and it was not too hard to do. I bought mine from Pelican Parts pretty cheap and have not had any problems so far. I only have like 2000 miles on it.
Old Jan 28, 2013 | 09:11 PM
  #85
willieboy's Avatar
willieboy
Installed the Vibra-Technics mount today. Took the GP out for about 50 miles and I really feel a positive difference in responsiveness. Might be in my head though The vibration at idle is slightly noticeable but no problem for me. After all, I'm mostly on the gas. I would recommend it as a positive alternative to stock. Nice looking too.
Old Jan 30, 2013 | 08:42 PM
  #86
ColinGreene
Cubano, you bought a stock one or a VT one?
Willie, Give it about a week to settle in.
Old Feb 6, 2013 | 10:56 AM
  #87
spirit16's Avatar
spirit16
Vibra Technics engine mount sources in the US
to all -
Like previous posters, I turned 78k miles on my 04 MCS and noticed that my right engine mount is leaking fluid. I am looking for a U.S. source of the Vibra Technics engine mount. Does anyone have any recommendation on where I can get this besides the VibraTechnics website??? I am located in northern Virginia
Would appreciate any input...
PS - I have an email to ColinGreene, but have not received a response
Old Feb 6, 2013 | 05:01 PM
  #88
drdave's Avatar
drdave
I have just joined the leaky engine mount club (at 37k miles) and will be replacing mine with the Vibra Technics version as soon as Colin gets back to me (I sent a PM). Is there any detailed instructions on the installation?
Old Feb 6, 2013 | 08:29 PM
  #89
ntn125's Avatar
ntn125
It's not too hard to install. I remember seeing instructions for TSW mount and it goes on basically the same. Also check Pelican, they have instructions as well.
Old Feb 12, 2013 | 03:28 PM
  #90
drdave's Avatar
drdave
Excuse my ignorance but what is "Pelican"? (except for the obvious bird)
Old Feb 12, 2013 | 03:39 PM
  #91
tlr1000's Avatar
tlr1000
Lol. Pelican refers to Pelican Parts, which is a parts supplier selling Mini parts. Generally when I come across a word on this forum I don't get I Google it along with "Mini Cooper" and more often than not I get my answer.
Old Feb 12, 2013 | 06:50 PM
  #92
ntn125's Avatar
ntn125
^Yep, they have many good install instructions under the Tech Info Center.
http://www.pelicanparts.com
Old Feb 12, 2013 | 06:58 PM
  #93
Cease's Avatar
Cease
Just got the OEM replacement Rein brand made in Spain from Pelican Parts today. It was 75 bucks or so so I figured I'll give it a shot since anymore vibrations and noises would just make me go crazy with the felt trying to find each and every rattle!!
Ill give this OEM a shot, see how long it lasts. If its not very long it's time to go aftermarket but if it lasts another 70k then at $75 I wouldn't be upset. Install is tomorrow
Old Feb 13, 2013 | 04:05 PM
  #94
drdave's Avatar
drdave
Thanks guys. I found the tech article at Pelican Parts. I am assuming that I will need to find an E12 Torx tool to complete this.
Old Feb 13, 2013 | 11:50 PM
  #95
ColinGreene
Yes you will, and a long'ish extension since its on the bottom of the frame rail and theirs plenty in the way. usually if its never been replaced its easy enough to get out with out taking the wheel and liner out.
just keep in mind brown oily goo will run down your tools and onto you as you pull the lower bolt.
Old Feb 14, 2013 | 06:58 AM
  #96
tlr1000's Avatar
tlr1000
Mmmmm....brown gooo...
You can get cheap e12 torx sockets from harbor freight.
Old Feb 16, 2013 | 09:52 AM
  #97
ashchuckton's Avatar
ashchuckton
Wish I had seen this thread earlier. I just replaced my second leaking motor mount. The VT one seems to be very well made & I'll buy it when my oem replacement dies. LOve the fact NVH seems well controlled. In comparison the TSW one looks like a cobbled together HS shop project to me, no thanks.
Old Feb 17, 2013 | 10:28 AM
  #98
ThumperMCS's Avatar
ThumperMCS
I recently switched my lower mount out to the VT and it is much much better than the stock mount with the powerflex poly inserts. I honestly thought the car was going to rattle itself apart eventually with the powerflex inserts. The VT is much smoother! Not to mention, it provides even less motor movement than the stock+powerflex, makes driving so much more enjoyable.
Old Feb 17, 2013 | 06:50 PM
  #99
ColinGreene
And you got Free Install to boot!
Such a clean car though.
Old Mar 14, 2013 | 04:47 PM
  #100
drdave's Avatar
drdave
Finally received my Vibra Technics mount and tackled the install yesterday.
A few observations:
Had to move a small wiring bundle away from the mount so that the lateral mounting point could be obtained.
The VT mount is taller than the OEM by 1/4" - 1/2" neccessitating raising the engine higher to get the mount bracket to mate to the engine block.
After driving today I noticed vibration in the steering wheel and interior when at idle but the vibration at speed seems to have smoothed a little.
