Drivetrain The Always Up-to-Date Thread on Tuning 2011+ (N18) MINIs
Old Jul 24, 2013 | 07:21 AM
  #1726
borderwave2's Avatar
borderwave2
As a side note, the BMS CAN tool is on sale now. This tool lets you hijack the speedo and fuel gauge to display boost, timing, temps etc. It also reads codes and will silence codes for those with catless downpipes.
Also the clutch stop is a must for everyone with a manual.
Old Jul 24, 2013 | 07:48 AM
  #1727
Mindspin311's Avatar
Mindspin311
It claims 2008+, is there a reason the 07 isnt included?
Old Jul 24, 2013 | 08:38 AM
  #1728
Sly Cooper's Avatar
Sly Cooper
Originally Posted by wzabrouski
Also just confirmed that the brake sensor update will rewrite the whole ECU so I can return to stock when this releases.
What's the brake sensor update?
Old Jul 24, 2013 | 09:35 AM
  #1729
chrunck's Avatar
chrunck
I think it's related to an inaccurate countdown for brake pad replacement. My CM has said I need brakes in 1100 miles for about 6 months now.
Old Jul 24, 2013 | 10:15 AM
  #1730
Sly Cooper's Avatar
Sly Cooper
That's based on some kind of timer or use pattern logging? I thought BMWs just use an electrical connector in the pad that grounds out when it gets worn down enough.
Old Jul 24, 2013 | 11:08 AM
  #1731
wzabrouski's Avatar
wzabrouski
You got it!! I purposely held off on this last time I was in for service.
Old Jul 24, 2013 | 12:47 PM
  #1732
evilc66's Avatar
evilc66
I'm pretty sure that the newer ones have a sensor that actually measures the distance, and aren't sacrificial, hence the calibration change to adjust the distance for pad wear. I had this done on mine a few months ago. Be prepared to lose your trip meter from the main display (meaning that you no longer have the odometer, trip, and whatever your auxiliary info was, like temperature).
Old Jul 24, 2013 | 02:31 PM
  #1733
pyrrhusmj's Avatar
pyrrhusmj
Can you program all of the info back in?
Old Jul 24, 2013 | 03:37 PM
  #1734
Terry @ BMS's Avatar
Terry @ BMS
It requires CAN communications at the OBDII port. Honestly no idea what year MINI added CAN there. With BMW it was 2008.
Old Jul 24, 2013 | 03:38 PM
  #1735
Terry @ BMS
Originally Posted by RoyalCooper
Can we stop worrying about Rob's credibility and get back to discussing all the pros and cons for the tunes out there. Especially for the post Feb 2012 N18 which is the real reason and topic for this thread.
How about you drive over to Simi and we install one so you can give us your feedback? I need a few local early adopters for the JB+.
Old Jul 24, 2013 | 07:03 PM
  #1736
jomama's Avatar
jomama
hey terry,
i emailed you via your profile about early adoption. not sure if you got it or not. i may be able to drive up that way. feel free to email me at sfmoy29@gmail.com.
Old Jul 24, 2013 | 07:43 PM
  #1737
Terry @ BMS
Originally Posted by jomama
hey terry,
Nothing in my inbox. My email address is terry@burgertuning.com
Old Jul 24, 2013 | 09:19 PM
  #1738
jomama's Avatar
jomama
email sent!
Old Jul 24, 2013 | 09:29 PM
  #1739
JonsR56's Avatar
JonsR56
Got the JB+ installed by Terry himself. It took less than 10 seconds to put it on. It's my very first mod so i can't compare it to anything. We drove around for a bit and all i can say is that my stock MCS pulls much harder and it doesn't take long to get up to speed. I definitely like the way my car drives now compared to stock. This is how the car should have come in the first place. Thanks Terry!
Old Jul 25, 2013 | 07:07 AM
  #1740
evilc66's Avatar
evilc66
Nope. The newer software only puts the odometer on the bottom, and your choice of secondary info up top, with the trip meter being one of the options now. I personally find it to be a step backwards. The bottom right side of the display is now just for warning lights.
Old Jul 25, 2013 | 10:56 AM
  #1741
korre07's Avatar
korre07
soooo in a few weeks imma be getting the nm engineering tune. should i wait for a more viable tune or is the nm tune good regardless of what might be coming out.
Old Jul 25, 2013 | 10:59 AM
  #1742
pidge1114's Avatar
pidge1114
yes, that's correct.
Old Jul 25, 2013 | 11:06 AM
  #1743
korre07's Avatar
korre07
what is correct? the nm tune is good regardless or i should wait. lol
Old Jul 25, 2013 | 11:07 AM
  #1744
pidge1114's Avatar
pidge1114
Old Jul 25, 2013 | 11:20 AM
  #1745
korre07's Avatar
korre07
Fantastic!
-__- hate you....
Old Jul 25, 2013 | 11:34 AM
  #1746
borderwave2
NM is good for a canned tune, but they require the physical ECU to tune. If you go to the dealer they can detect your tune and possibly void your warranty or at the least, overwrite it when a software update comes out. Personally I would wait for JB+ as it offers the same power gains at much cheaper price. Also you can unplug the JB+ piggyback when going to the dealer, or even sell it when you decide to.
Old Jul 25, 2013 | 11:35 AM
  #1747
Coop-a-Loop's Avatar
Coop-a-Loop
Ya, so how is it for you?
Old Jul 25, 2013 | 11:54 AM
  #1748
korre07's Avatar
korre07
any ETA on the JB+?
Old Jul 25, 2013 | 12:35 PM
  #1749
pidge1114's Avatar
pidge1114
Old Jul 25, 2013 | 12:39 PM
  #1750
iminir56's Avatar
iminir56
Troll
