Drivetrain Twincharged MCS
so will a front mount intercooler work with this one i was thinking of getting a front mount intercooler with this setup
also is the trans really gonna take all that horse power?
and i wonder if its possible to retrofit an srt neon trans with this engine since its rated much higher in hp numbers
im getting anywho
im getting anywho
im getting anywho
im getting anywho
Originally Posted by Bisch
How will a port & polished head with a Schrick cam work with this set-up?
He has over 10k miles on 20lbs of boost with no problems. Pistons would be my first change to handle higher boost pressures that will come with the 15% pulley and engine mods. 25lbs of boost is reasonable but with the stock pistons you might as well buy a lotto ticket.
Hubie and Jann-Michael at SPI have done many turbo cars in the past and seem to be the most knowledgeable about turbos that I have talked to.
just noticed you have a 19% pulley on your setup... I would talk to them but I think he will tell you not to run over a 15%.
he ran those numbers on a stock pulley
...and they run an OEM headgasket too?
scary good kit if you ask me
the best part is it comes with all the hardware to install it. you don't have to go fishing for parts to put it together
so lets say for instance with new head, cam, intake, header and exhust what kinda numbers are we talking, pluse any future ecu mapping!!!!!!
the downpipe is 3" and runs all the way out the back
it sounds great
so wheres the drive by vidio!!!!!
mmmmmmmmmmmm i want it
one queschine is im worried about my high milage i have over 80,000 miles on mine and im worried since its high milage do you think the chances of breakage are higher!!!!
btw... anyone know how to shrink this pic in my sig????
Any Warrenty on tires your going to burn through... I can't keep tires good for 10K miles with only 195 Wheel HP.... lol These are nice setups. from both companies. Can't wait to try one with my pistons....
well i just figured with enjines running so much better nowadays and oils being so much better the ware would be minimul
pluse their all higway miles for the most part
