Drivetrain Which intake has the coolest sound?
Old Jan 22, 2004 | 09:31 AM
d2mini's Avatar
d2mini
Yeah, I've seen the hp numbers, now down to what's most important....SOUND!
Which is you fave for sound and why?
Old Jan 22, 2004 | 09:37 AM
Ryephile's Avatar
Ryephile
the Madness/Rouge/Pilo design sounds quite nice - a basic amplification of the stock intake, with a touch more throttle body wooshing.
The ALTA intake sounds great, excellent tone and "sucking for air" with that high flowing UNI filter. However the real kicker is when you put on the ALTA silicone tube. Then, during WOT - it's loud!. This smooth but raunchy growl that just sings like a really ticked-off Electric pool vacuum (hey, it IS an MCS afterall, lol).
What I love about all of them, however, is the loudness is proportional to your right foot. During cruising, none of them are audible above stock. The question begs, how loud do you want it when you mash the throttle?
Old Jan 22, 2004 | 09:39 AM
05JCWS's Avatar
05JCWS
I personally like the Pilo Intake's sound.
Old Jan 22, 2004 | 10:26 AM
ZAMIRZ's Avatar
ZAMIRZ
I own the Alta, but Pipercross sounds the best IMHO.
Old Jan 22, 2004 | 10:44 AM
d2mini's Avatar
d2mini
Ryephile gave a really good description of the Alta...how would you describe the pipercross in comparison? :smile:
Old Jan 22, 2004 | 11:01 AM
sanddan's Avatar
sanddan
Mine is a combination of the Alta and Maddness, maddness type air box, cowl mod (extra holes) and a larger intake tube. I was following a corvette through the twistes( @ about 90 mph) and he later said he could hear the supercharger whine over his exhaust! Very cool at WOT but quiet during normal driving.
Old Jan 22, 2004 | 11:03 AM
BFP's Avatar
BFP
Our intake will be available in about 4 weeks and sounds WICKED! It's also got Carbon Fiber (We're coming out with a matching intercooler cover as well in CF).
More on the kit later
-Dan
http://www.benferperformance.com
Old Jan 22, 2004 | 11:14 AM
d2mini's Avatar
d2mini
Hey Dan?
Do you know an Audi guy named Kash from SoCal?
He sent me your site a month ago when i got my MCS.
He said one of you guys is a buddy of his. :smile:
_________________
Old Jan 22, 2004 | 11:37 AM
ZAMIRZ's Avatar
ZAMIRZ
Yep, I have the hose as well. He's spot on when he says it sounds like an electric pool vacuum at WOT. The thing about the Alta that I don't like is that it makes a sort of queefing/whistling sound (sorry, I can't think of any other way to describe it) when you are at part throttle and when you let off after taking up through the revs. The pipercross in comparison sounds like it's sucking and just becomes louder the faster you go, there isn't any other noises or whistling.
Old Jan 22, 2004 | 11:42 AM
d2mini's Avatar
d2mini
OMG! bahahaha......err...thanks.
Old Jan 22, 2004 | 11:43 AM
BFP's Avatar
BFP
>>Hey Dan?
>>_________________
Yeah! I hung out with Kash at the LA auto show! He's a good guy, very knowledgable about the automotive aftermarket.
-Dan
Old Jan 22, 2004 | 02:06 PM
d-mini-ero's Avatar
d-mini-ero
cool..is relative ...:smile:.
but...
I personally like the madness/rogue...
It's quiet at idle... and comes to life when ya mash on da gas :smile:
Peace,
D
Old Jan 22, 2004 | 08:53 PM
F15EWeapon's Avatar
F15EWeapon
I can't speak on any other intake systems, but I installed my Alta intake with RED silicone hose 2 weeks ago. (My Christmas present!)
What a fantastic difference in noise! I would buy it again just for that purpose alone, not to mention the little extra kick and throttle smoothness I percieve.
One thing is for sure, an Alta equipped MINI has the most unique sound on the road... enough that every riceboy honda that might even THINK about trying to run you, will reconsider what he's getting into when he hears you blip the throttle.
Old Jan 22, 2004 | 09:56 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
I'd say the Alta intake with HOSE and reduction pulley.
You WILL easily hear it over your aftermarket exhaust.
The sound is more than half the fun.
Old Jan 22, 2004 | 10:04 PM
rb905678's Avatar
rb905678
I would have to agree about the ALTA - I have that and the hose on a JCW. The intake is louder than the exhuast but keep in mind where you sit....
If you did want to eliminate some of the noise you can always replace just the firewall cover - it will fit - but unless you are on the gas it is almost like stock...
Old Jan 23, 2004 | 05:20 AM
ukbyoung's Avatar
ukbyoung
I would say the ALTA also. I love the way it sounds WOT and also I like the ssssss sound of air when you barely hit the gas. The difference between stock or something like the rogue and the ALTA is very different. IMHO ALTA is the only way to go.
B
Old Jan 23, 2004 | 08:07 AM
d2mini's Avatar
d2mini
Thanks guys! :smile:
How about the differences between BMP/Promini and Alta? I've narrowed it down to those two but leaning towards Alta.
Old Jan 24, 2004 | 09:56 AM
1cleancooper's Avatar
1cleancooper
The best soundsing intake BY FAR is the modded stock intake that cost you nothing to do except about an hours worth of time. What to do: pull out the plastic divider behind the air box just like the alta intake makes you do, and pull out your entire airbox. Cut a 5"x3" square hole into the bottom half of the airbox (the side of it that faces the drivers seat), then make a matching hole in the plastic divider that came on the car. Then go to discount autoparts and buy some of the generic seals that they sell for car doors and either CA glue or epoxy the seal onto the outside of the airbox and onto the inside of the plastic divider. Then install it, and WOW you have an oficial cold air intake that the dealer will not be able to see, that is perfectly sealed off to any and all hot air, and it only cost you a few bucks. The only thing you'll have to add to get the most performance out of the system is a K&N air filter. But if all you're looking for is sound then keep the factory airfilter for now and enjoy the sweet whine of the supercharger when you get on the gas
If you want pics of the mods up close email me for them at Onecleancooper@hotmail.com happy motoring!
Old Jan 24, 2004 | 10:35 AM
d2mini's Avatar
d2mini
1cleancooper, tried to send you mail, but it got sent back. :smile:
Mine is d2mini@houston.rr.com
Anyone else have any experience or thoughts about this DIY mod?
Any hp gained from it if using the K&N?
_________________
Old Jan 24, 2004 | 01:48 PM
orthomini's Avatar
orthomini
same here, my email got sent back as well, mine is bobwaugh@earthlink.net
Old Jan 24, 2004 | 02:32 PM
1cleancooper
hey sorry about that guys, i have another email thats working correctly
it is: Cabbyracer@hotmail.com again sorry about the email thing...
Old Jan 24, 2004 | 02:38 PM
RLmini's Avatar
RLmini
Has anyone tried the K&N Typhoon? If so, how does it sound?
Old Jan 24, 2004 | 09:15 PM
1cleancooper
All of the intakes have a similar sound, some are just a little bit louder. ANY of the intakes on the market now can be made to be just as loud as the alta intake if you just remove the plastic peice behind the airbox. HTH
Old Jan 24, 2004 | 09:57 PM
speltzer's Avatar
speltzer
Curious if anybody has installed this new intake from bavarian auto? It sure looks great with the chrome and all. About $180 on the website. I found it surfing the web the other day.
Old Jan 24, 2004 | 10:03 PM
Ryephile's Avatar
Ryephile
it's not actually new - it's a rebadging of the BMP unit (sshhhh! don't tell anyone)
