Drivetrain injectors stuck
Old Dec 22, 2010 | 02:05 PM
freeskier's Avatar
freeskier
injectors stuck
hate to start another thred but i cudent find this in the DIY section. im swapping injectors, fuel rail is out, clips are off. is there a trick for pulling the injectors out of the IM, they seeem real stuck. thanks
Old Dec 22, 2010 | 06:21 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Leave injectors attached to the rail, remove the whole unit.
The Injector O-rings get brick hard and brittle making them quite snug.
Be sure to use a shop vac in that area before removing them to keep sand and other debris from going in.
Old Dec 22, 2010 | 07:11 PM
freeskier's Avatar
freeskier
number 2 injector tore in half leacing the nosr stuck into the manifold. now i need to somehow remove the broken half. will my mini delaership have injector clips and valve cover bolts?
NYMADMINI
Dec 14, 2016 02:33 PM
randeez
Oct 5, 2015 09:23 AM
MINI Stupor
Oct 1, 2015 11:36 AM
WhinyR53
Sep 30, 2015 07:36 AM
dutchhome
Sep 30, 2015 07:17 AM
