Drivetrain Looking to buy a new clutch what do you recommend?
Old Nov 11, 2010 | 03:51 PM
Josue.Rodz's Avatar
Josue.Rodz
I bought my MCS '05 secondhand and the previous owner didn't gave much maintenance to the car so i had to. i spent some money on my MINI but now the clutch is making an annoying noise and i'm looking for a clutch. first i thought on getting the SPEC stage 1 but since i'm not a street racer or anything i decided to do some research and i came to the conclusion that valeo, luk or sachs could do the same. i'm looking for a OEM feel. need recommendations!!!!
Old Nov 12, 2010 | 11:29 AM
slapshot591's Avatar
slapshot591
I've been looking into getting a new clutch soon for my 05 S and I've came to the conclusion that it seems the OEM clutch is very capable. If you don't have any modifications, stick with OEM, since you wanted that "OEM feel." Even with simple mods, ~220hp the OEM clutch can carry it. However I have talked to a few people and they stated that 250hp is where the OEMs start to burn out.
Old Nov 12, 2010 | 01:02 PM
wrh3's Avatar
wrh3
SPEC clutches are not known for quality/durability and their customer service seems to be lacking as well- this based on other car forums I have been a part of and other peoples' experiences. I still have a SPEC gift certificate I won and have not used for this reason.
Pricey, but I think I am going to go with OS Giken when my clutch finally dies:
http://www.waymotorworks.com/os-giken-clutch-kit.html
Replaces everything (including the flywheel) and the components seem to be top quality and made to last- I think this is the only Mini clutch kit out there that comes with a metal throwout bearing?
Old Nov 12, 2010 | 07:39 PM
jeffreyevens's Avatar
jeffreyevens
Look into valeo's new solid flywheel clutch setup. It may holdup better than oem? I tried the lightweight setup' did'nt like them went back to stock.
Jeff
Old Nov 12, 2010 | 07:51 PM
jimz68's Avatar
jimz68
My original clutch lasted 153,000 miles.
Replaced it with a Clutchmasters FX200. Lasted 15,000 miles.
Went back to OEM.
Jim
Old Nov 13, 2010 | 08:02 AM
Ammi's Avatar
Ammi
I had good experiences w/ both Spec and Clutchmaster clutches in the past. OEM feel and held up 400+hp just fine
Old Nov 13, 2010 | 11:48 PM
luseboy's Avatar
luseboy
Personally, when i get my new clutch (in the next year or so, i learned stick on this car), i am gonna go for a clutchmasters fx200 with the lighter flywheel. @jimz68- did you follow the break in procedure? I've heard of this happening to people when they don't follow the procedure for the break in period. Its supposedly, very important for making the clutch last long enough...
Old Nov 14, 2010 | 01:10 AM
jimz68's Avatar
jimz68
Yes. It was a problem with the pressure plate. Must have been one built on a Monday or a Friday.
I realize it was a freak thing. Not going to bad mouth the product as there are plenty of them out there working fine. Just didn't work for me.
Jim
Old Nov 14, 2010 | 07:22 PM
KC Jr 54's Avatar
KC Jr 54
IMO Valeo all the way. The cheapest option out there hands down, too. wamotorworks.com carries them, and i believe has a few in stock.
Old Nov 14, 2010 | 11:53 PM
Luys's Avatar
Luys
I have used OS Giken and ClutchMaster (stage 1) and they are not like an OEM clutch!!
Old Nov 15, 2010 | 06:13 AM
Josue.Rodz's Avatar
Josue.Rodz
what's the difference between solid flywheel and stock. many clutch kits replaces the flywheel. it's a good practice to change the clutch master cylinder and slave cylinder when replacing the clutch?
Old Nov 15, 2010 | 06:21 AM
Josue.Rodz's Avatar
Josue.Rodz
Dude this this cost $1689.00... do you know how many things i can get for my MINI with that kind of money.
Old Nov 15, 2010 | 12:48 PM
Trickle X's Avatar
Trickle X
I've had spec, clutchmasters and now I am running ACT flywheel and clutch setup. IT is the closest feel to stock and it just plain works.
here is a link from where I purchased mine. You will need to use their solid flywheel, which these guys also offer.
http://performance.importrp.com/act/...s/i-46403.aspx
It is quiet unlike all the other ones I ran. If it is holding my power, it will work well for anything you can thow at it.
Old Nov 15, 2010 | 03:14 PM
ZippyNH's Avatar
ZippyNH
If you want oem feel, get the oem...
The oem flywheel is a dualmass one, kinda $$, but it reduces noise, vibration and harshness at idle. Going to a traditional flywheel will change the feel of the car....
Same for a lightweight flywheel...will make it harder to launch smoothly, or drive in traffic and on hills....
For the clutch, oem for oem feel...the valeo one might save you a few $$ for basicly the same item...LUK also makes one that, and a dualmass flywheel that may also be oem ones.... Not sure, but might worth looking into.
Old Nov 15, 2010 | 06:22 PM
R53Warrior's Avatar
R53Warrior
Have you seen how much it is for a new OEM dual mass flywheel and clutch? So actually that price is not horrible. I have used their clutches in a couple of modified cars and have had nothing but good experiences.
I had a clutchmasters FX100 in my SVT Focus, same transmission as our cars. It started slipping at less than 10k miles and was worthless by 15k. Total piece of junk. I will not be buying from them again.
Old Nov 15, 2010 | 07:07 PM
ZippyNH's Avatar
ZippyNH
If you DIY it...it would be cheaper than paying somebody to install an OEM!!
Pricey....but you do get ONE major thing that improves reliability that NO OTHER CLUTCH HAS!!
A re-desgined Throw-Out bearing...metal one at that!!
My mini guy says many of the clutches he replaces are due to the plastic OEM/OEM equivalent bearing getting galled/melted.....
This would not be an issue with this clutch!
It is a bit noisy at idle...like any single mass clutch....but it is a max performance racing clutch......
Old Nov 16, 2010 | 07:51 AM
FlzRider's Avatar
FlzRider
I'm really intrigued by the Valeo kit that WMW and Detroit Tuned sell (http://www.waymotorworks.com/valeo-c...l-kit-r53.html and http://www.detroittuned.com/shop/?productID=492).
Does anyone have experience with this kit? I know this is a solid (single mass) flywheel, but does having a sprung hub clutch make up for that? Any additional noise at idle? Is the feel similar to OEM?
Old Nov 16, 2010 | 10:30 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We haven't sold many of the valeo kits, but the few we did sell the customers reported back they were happy with the feel and it worked well.
Old Dec 16, 2010 | 02:18 PM
purephase's Avatar
purephase
Does anyone have a link for the best OEM resellers? I've got an 06 Cooper that's slipping pretty badly and I'd like to bring in the clutch (and probably the flywheel) to wherever I get it installed.
Thanks in advance,
Kevin
Old Dec 16, 2010 | 07:43 PM
WayMotorWorks
Vendor
Thanks in advance,
Kevin
We carry all the OEM parts, just give us a call I don't have every part on the site. But I do have clutches in stock.
WAY
317.201.8670
Markbett
Jul 3, 2016 04:28 PM
L3Mix
Aug 26, 2015 07:00 PM
DiGiPiMP
Aug 24, 2015 11:04 AM
PrimePower
Aug 16, 2015 06:29 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
