Drivetrain Downpipe with 200 cpsi
Old Oct 25, 2010 | 01:48 AM
Demi's Avatar
Demi
Hi Mini Fan's
1 week ago, I let a specialist install a new downpipe with a 200cpsi catalytic converter to my factory works.
During the weekend and several kilometers after, I connected my Bavarian Technics OBD Tool to have a look if there are some fault codes.
I've found this 4 codes:
2A77:
DME: Oxygen sensor behind catalytic converter, ageing
Error will cause a warning light
Error is not currently present
Test conditions have been completed
Timeout
2A7F:
DME: Oxygen sensor behind catalytic converter, electric
Error is currently present
Timeout
2A74:
Short circuit or signal interruption
2A56:
DME: Oxygen-sensor heater behind catalytic converter, function
After that I've deleted them and am started to a test drive of arround 100 kilometers.
I've checked again if there are some new codes are stored inside and see again 2 of them:
2A56:
2A7F:
Timeout
Unfortunately I can't imagine the problem, because there is no lamp active in the tachometer. I've allready heard that there can be a problem with the lambda sensor, but these includes a light in the tachometer?! Just for info, it is a high quality catalytic converter, not a cheap one.
Maybe someone have an idea what these fault codes wanna tell me???
(sorry englisch is not my native language, hope u understand it anyway)
Thanks in advance!!
Old Oct 25, 2010 | 01:29 PM
countryboyshane's Avatar
countryboyshane
I'm sorry to not even help but there is almost no hope for a catted downpipe that will make more power than the OEM issued one. The ECU is too sensitive.
Old Oct 25, 2010 | 01:36 PM
ThumperMCS's Avatar
ThumperMCS
You change the downpipe, catted or not....you're going to get codes. Plain and simple
Old Oct 25, 2010 | 05:16 PM
slinger688's Avatar
slinger688
Is this an US specfication car?
Old Oct 25, 2010 | 07:35 PM
richi0207's Avatar
richi0207
If you have an 07 and an 08, the only DP you can run without getting a CEL would be Exhaust Depot's
Old Oct 26, 2010 | 09:59 AM
tintman718's Avatar
tintman718
That's a lot of codes.....check if O2 sensor #2 is connected properly.
Old Oct 26, 2010 | 11:40 PM
Demi's Avatar
Demi
Hi,
Thanks for all replys!
The DP is manufactured by a renowned little company here in switzerland. (so my JCW is EU) They use the best materials and the cat. converter has a special coating.
So normally the car didn't show something in the tachometer...just for info: My JCW is programmed by MTH.
@tintman718
I've thought the same. Especially "Short circuit or signal interruption" are an indication for connections problems.
Hope they can fix it fast
Old Jun 13, 2011 | 05:58 PM
turtle343's Avatar
turtle343
did you try getting a new o2 seneor?
Ovrclck
Oct 5, 2015 09:45 AM
GAT
Oct 4, 2015 07:27 PM
Island maser
General Discussion
Oct 1, 2015 01:09 PM
potterstein
Oct 1, 2015 07:10 AM
Nick Royer
Sep 29, 2015 03:01 PM
