Drivetrain noise (video included). what is it?
Old Oct 11, 2010 | 07:16 AM
djomlas's Avatar
djomlas
hey guys,
this has been happening lately, i think it def sonds like a belt.
its not an old belt tho as its been installed along with the pulley....kinda goes away when engine warms up.
why is it making this noise?
http://tinypic.com/r/2cqcq3d/7
Old Oct 11, 2010 | 07:28 AM
dutch2081's Avatar
dutch2081
belt...or bad bearing in a pulley
Old Oct 11, 2010 | 07:50 AM
Helix13mini's Avatar
Helix13mini
It sounds like a belt squeal, but probably due to a bad idler or tensioner pulley.
Old Oct 11, 2010 | 08:16 AM
kb30's Avatar
kb30
mine has that same noise when it's cold out.
Old Oct 11, 2010 | 09:34 AM
ggcadc's Avatar
ggcadc
Is the belt wearing? How does it look? If you rev does it turn into a squeal? Or just get faster.
What mods are on your car? What size belt? When was it changed?
These are all important questions.
Old Oct 11, 2010 | 10:06 AM
djomlas's Avatar
djomlas
belt has about 6-7k on it, changed along with te Alta 15% pully.
when i rev it the ticking just increases/gets faster, it doesnt turn into a squeal...once the car warms up it goes away.
i dont remember seing any wear on the belt, but honestly i dont remember, i will check once i drive it again later on today and report back...
Old Oct 11, 2010 | 04:32 PM
djomlas's Avatar
djomlas
belt looks new, no cracks or anything...
Old Oct 11, 2010 | 07:17 PM
ggcadc's Avatar
ggcadc
Looking at the belt more for a glazed look, but doesn't sound like that's it. Have you brought it anywhere, these things are hard to locate when not in person, could easily be the idler going out, but needs personal inspection
Old Oct 11, 2010 | 08:03 PM
djomlas's Avatar
djomlas
no i havent taken it anywhere to be honest, i havent driven it in a few days so it was extra loud and i just recorded it to see if its something simple...
ill get an opinion somewhere soon hopefully...
Old Oct 27, 2010 | 07:35 PM
ggcadc's Avatar
ggcadc
lol, hey! i figured it out for you, if you ahvent already, cause my car makes the same noise now too... it's the pulley on the tensioner... not sure if it's bad casue it goes away once it warms up...
KB30- how long has your car made the noise, any other problems from it???
Old Oct 28, 2010 | 11:18 AM
kb30's Avatar
kb30
mines been since i have owned it over three years. No other problems from the car at all. Ineresting though!
Old Oct 28, 2010 | 10:03 PM
ClintTheMiniOwner's Avatar
ClintTheMiniOwner
see what happens when you turn your AC on and off
Old Oct 30, 2010 | 09:30 AM
cultgti's Avatar
cultgti
You should do some research on here for alta. Not saying its Alta's part but there is very intensive thread that goes over this same issue and IRC the issue ended up being the tensioner/idler pulley alignment issues with the rest of the pulleys. Do a search for Alta pulley issues (ONCE again IM not saying its Alta just that the thread Im talking about was with Alta product)
Old Oct 30, 2010 | 10:12 AM
CRoth's Avatar
CRoth
When your car is idling, does your tensioner pulley bounce up and down quite a bit? If so, you need to replace your tensioner pulley assembly. I went through the same situation. Hopefully this will help you come to a conclusion if you haven't already.
Old Oct 30, 2010 | 10:19 AM
djomlas's Avatar
djomlas
when the AC or heat is on, there is no difference. it only gets faster ticking(or whatever the sound you wanna call) once i give it some gas.
i will search up a bit on ALTA, wasnt aware of that
kb30, does your car have an alta unit installed?
and as far as tensioner pulley bouncing, i don't recall it...but i will doublecheck.
Old Nov 21, 2010 | 08:47 AM
djomlas's Avatar
djomlas
went out to NAPA and got the recommended belt from here for 15%, put it on, and noise is gone.
weird that it only lasted so many miles...
Kimolaoha
Jul 5, 2023 01:04 PM
Melvinyip
Apr 17, 2020 09:28 AM
Spank
11
Apr 9, 2020 02:23 PM
thebordella
Aug 31, 2015 01:37 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
