Drivetrain Looking for a quietest intake. Dinan?
Old Jul 28, 2010 | 01:23 PM
YMINI's Avatar
YMINI
Looking for quietest aftermarket intake.
I'm considering Dinan. JCW is too pricey. Any other intakes which are not too loud?
Old Jul 28, 2010 | 01:51 PM
ZippyNH's Avatar
ZippyNH
There are many used JCW intakes around...as long as it still has the flap on the back, it is the quietest...
I have the Dinan....I like it....just enough sound to make you smile, quiet for a longer drive!! It is elegant, and OEM looking...not blinngly..some love the look, some don't!!
Install is moderately easy, if you can cut plastic!!
They have been on sale recently (and the price is a-lot less than it was a few years ago)....and Dinan is no longer making parts for the r53..so if you want one...I'd buy it fast!!
Old Jul 28, 2010 | 01:52 PM
Agarwaen's Avatar
Agarwaen
Yes Dinan is the quietest, aside from JCW. Also JCW and Dinan are the best to combat heat soak, since they are plastic.
Past that anything with a top is the next best bet.
That being said, screw quiet, Loud is the way to go.
Old Jul 28, 2010 | 03:55 PM
Dinan604's Avatar
Dinan604
JCW is quieter than the DINAN I used to have, even with the flap kept open. I might re-install the Dinan one later this year.
Old Jul 29, 2010 | 07:12 AM
2mD's Avatar
2mD
why not stay stock ?
the louder intake noise is the only real + point of another intake... you dont really gain any power...
its like asking for a smaller pulley that gives the lowest HP gains
Old Jul 29, 2010 | 07:17 AM
YMINI's Avatar
YMINI
I thought all intakes give approximately same gains over stock.
Old Jul 29, 2010 | 07:23 AM
2mD's Avatar
2mD
the best you can hope for is not loosing power
thats my experience at least...
Old Jul 29, 2010 | 07:49 AM
BlimeyCabrio's Avatar
BlimeyCabrio
I had a Dinan and switched to JCW because my car had pronounced throttle whistle at part throttle (not all cars do). With the JCW it's bliss. Deals can often be found on the JCW intake if you shop around for a while.
Another option is to add a better flowing filter to the stock airbox, and remove the lower grommet from the rear of the box to allow more airflow from the cowl area. Will yield nearly the same results as a Dinan for a fraction of the price.
Old Jul 29, 2010 | 07:55 AM
TimL's Avatar
TimL
Interesting thought, Paul; would you be able to provide any specifics (which filters, how-to, etc.)?
I've been wanting a JCW intake for some time, but really can't justify the expense. This mod sounds like it might be more up my alley anyway.
Old Jul 29, 2010 | 08:05 AM
Helix13mini's Avatar
Helix13mini
Find a used JCW, and then put a new, lifetime filter on it, like, say, here :
http://helix13.com/mini/products/engine-intake
Old Jul 29, 2010 | 08:57 AM
BlimeyCabrio
The grommet I'm talking about is the rubber plug in the rear of the bottom half of the airbox. You can pull or cut center out of it to provide an open path to the cowl area for a little more air and sound.
Alta used to make a foam filter element. I think there is a K&N filter available. There may be others. I'm a big fan of the AMSoil nanofilters because they breathe very well, filter very efficiently, last forever and are dead simple to maintain (blow it out, it's clean). That's what I run in my JCW box - they have a wide range of panel filters, but I haven't tried to find one that fits the stock airbox - they don't list one in the product selector for "Mini" but that doesn't mean they don't have something that will fit - somebody needs to check the dimensions.
Old Jul 29, 2010 | 09:15 AM
TimL's Avatar
TimL
Excellent, Paul; thanks!
Old Jul 29, 2010 | 09:55 AM
TimL's Avatar
TimL
I'm a big fan of the AMSoil nanofilters because they breathe very well, filter very efficiently, last forever and are dead simple to maintain (blow it out, it's clean).... I haven't tried to find one that fits the stock airbox - they don't list one in the product selector for "Mini" but that doesn't mean they don't have something that will fit - somebody needs to check the dimensions.
The OEM drop-in filter for the R53 is the Mann C 25 114/1, right? If so, dimensions look to be: 243mm x 178mm x 65.6 mm.
I'm not seeing a direct comp from Amsoil; the closest would seem to be the EaA127 @ 9.518" x 7.03" x 1.499"
K&N 33-2270 (comes up as direct replacement on their site) is 6.375" (162mm) x 10.688" (271mm) x 1.063" (27mm)
Old Jul 29, 2010 | 11:09 AM
Dinan604's Avatar
Dinan604
Do you have a part # for the Amsoil JCW filter? Would love to replace my existing one with it.
Old Jul 29, 2010 | 11:13 AM
BlimeyCabrio
EAau3570 - it's about 1/4" shorter than the JCW, so you have to use something as a shim to hold it in place or use a clamp to do so - but otherwise it's perfect.
Nicefeet
Oct 1, 2015 05:08 PM
knbond1
Sep 22, 2015 06:20 AM
ShadyCoop
Sep 20, 2015 08:57 AM
Empura
Cooper (non S)
Sep 16, 2015 07:35 PM
Alanberto
Sep 16, 2015 07:25 AM
