Drivetrain do these numbers make sense???
Old Jul 16, 2010 | 05:33 PM
dutch2081's Avatar
dutch2081
ok so i got back from the dyno and the numbers are a little disapointing...
these are the mods i have...
header high flow cat
17% pulley
cooler plugs
mini mania foam filter
the number read (weather corrected and with the weight of the car with my weight and full tank of gas inputted...
144 hp
127 lbs of torque
12 lbs of boost
a/f 12.00
somethings not right...i dunno
the heat was high so the timing retarded knock sensor maybe...
i just ordered the snow performance meth injection stage 2 progressive kit...just for cooling not gonna tune with it (YET!!) when i do decide i would like to run 2 maps one regular without the meth and one without...are there handheld tuners for our cars??? what is the best way to go|?
thanks
Old Jul 16, 2010 | 05:49 PM
CRoth's Avatar
CRoth
For starters you should be running about 4 lbs. more boost with that pulley. Stock boost is between 11 and 12 psi.. Did you change your belt with the pulley? If your belt is too long it could be slipping on the SC.
Old Jul 16, 2010 | 05:53 PM
dutch2081's Avatar
dutch2081
it feels tight
it was on the car when i bought it
maybe thats a good starting point..what is the belt size for that pulley?
its an alta 17 %
Old Jul 16, 2010 | 07:12 PM
CRoth's Avatar
CRoth
Here is a link to a chart for the proper belt sizing.
https://www.northamericanmotoring.co...ize-chart.html
You should be able to see all or most of the top hole on your tensioner stop when the tensioner is in it's normal operating position. If you can't see the top hole, your belt is either too long or worn out.
Old Jul 16, 2010 | 07:31 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes you definetly need to find out what's up with the boost.
Old Jul 16, 2010 | 07:44 PM
dutch2081's Avatar
dutch2081
i am not sure where to look so here r some pics maybe you could tel me
Old Jul 16, 2010 | 08:24 PM
dutch2081's Avatar
dutch2081
i can barely see the tension stop at all
Old Jul 17, 2010 | 01:33 AM
CRoth's Avatar
CRoth
On the third picture you posted you can see it a little bit. I'm not sure if that's a shadow or a hole. You need to retake the pictures and focus more to the left, on top of that spring in your pictures.
Old Jul 18, 2010 | 11:02 AM
CRoth's Avatar
CRoth
I just had another thought for you to check. Make sure the set bolts/screws are tight on the SC pulley. The pulley could be slipping on the shaft.
Teh
Aug 22, 2022 04:37 AM
HaveATank
Sep 4, 2015 08:04 AM
wind715
Aug 11, 2015 07:56 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
