Drivetrain is this a good deal, or too expensive?
Old Jun 2, 2010 | 09:24 PM
gulewamkulu's Avatar
gulewamkulu
am planning to have a shop do a 15 % reduction pulley, brisk spark plugs, upper and lower motor mounts. he's gonna charge me 820.00 for parts and labor is this a good deal or its too expensive?
Old Jun 2, 2010 | 09:48 PM
MrCooperS's Avatar
MrCooperS
Moderator
The 15% reduction pulley and spark plugs should run you $200 to $300 at most for parts and labor. As for the upper and lower motor mounts for parts and installation for $520 to $620 sounds reasonable...
Old Jun 2, 2010 | 09:51 PM
gulewamkulu
thank you so much, just wanted to make sure that i wasnt getting ripped off, before going for it, the guy sounded pretty honest when i talked to him.
Old Jun 2, 2010 | 09:57 PM
MrCooperS's Avatar
MrCooperS
Moderator
Here is my estimated breakdown:
Reduction Pulley + Belt + Labor should be $250 at the most.
Spark plugs + Labor should be $50 at the most. (Doesn't take a genius to change spark plugs)
Upper motor mount can be anywhere from $150 to $200 for OEM or aftermarket without labor. (my guess)
Lower motor mount is probably the same, anywhere from $150 to $200 without labor. (guess)
So all in all, it sounds like a fair deal to me. You don't happen to know which parts he's using do you?
Old Jun 2, 2010 | 10:03 PM
gulewamkulu
thanks! am not sure which parts he's using, i'll probably call him up tomorrow and ask him.
Old Jun 2, 2010 | 10:30 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
You should ask how much it would be if you provided the parts. That way you can decide how much his labor charge is.
And typically the going rate for a pulley and belt installed is about $400, we also then install the plugs and tensioner stop for the price of the part no extra labor.
Upper OEM mount $95
Lower OEM mount $44
Pulley Kit: pulley,belt,plugs,tensioner stop $199
Also ask how many pulleys they've done???? I just had a guy spend $1500 for a pulley install and they screwed up his supercharger, so even though they way over charged him, they still lost money, but was without his car for a month.
2011cooperSconvertible
R57 :: Cabrio Talk (2009+)
Apr 1, 2019 06:03 AM
Getrieben
Aug 17, 2016 06:32 AM
caiken
Aug 27, 2015 06:55 AM
StuRat
Aug 24, 2015 06:24 PM
PrimePower
Aug 11, 2015 12:51 PM
