Drivetrain R56 Turbo Inlet Hard Tube?
Old May 13, 2010 | 07:48 AM
Dwight Walhood's Avatar
Dwight Walhood
Is anyone making a turbo inlet hard tube? Alta was offering one on their site, but it disappeared. NM is rumored to have one in the mill. Currently have Alta's silicone tube, but it doesn't clear the overflow tank and will eventually crack. I've heard the JCW has a hard tube. Will fit the "S"? HELP!
Old May 13, 2010 | 07:51 AM
iwashmycar's Avatar
iwashmycar
The K&N typhoon intake comes with one
Old May 13, 2010 | 08:16 AM
chakraj's Avatar
chakraj
Get the factory JCW hard pipe I think that one is the best.
Old May 13, 2010 | 08:18 AM
Revolution Mini Works's Avatar
winna
Old May 13, 2010 | 09:56 AM
Dwight Walhood
Thanks guys . The JCW it is!
Old May 14, 2010 | 01:34 AM
Kev_KB's Avatar
Kev_KB
Just so you guys know there have been a few issues fitting the JCW pipe to UK cars. One slipped off whilst driving and sucked stuff into the turbo with rumours of another doing the same.
The factory JCWs inlet is a tiny bit bigger than the stock S. Alta sold two different versions of their hard pipe to accomodate this.
See here for an example:
http://www.minitorque.com/forum/f15/...75/index3.html
Old May 14, 2010 | 02:03 AM
ndylam's Avatar
ndylam
The fitting issues can be fixed by getting a T-bolt clamp from Clint @ DoS
http://defendersofspeed.com/store/pr...?id_product=19
Old May 14, 2010 | 02:00 PM
Dwight Walhood
Thanks loads for the tip! Just ordered the clamp from DoS.
Old May 14, 2010 | 09:03 PM
08cooperSblack's Avatar
08cooperSblack
where can you get the JCW hard pipe?
Old May 14, 2010 | 09:39 PM
ndylam's Avatar
ndylam
You're very welcome
I'm surprise the shipping is cost more than the clamp
Old May 14, 2010 | 09:49 PM
ndylam's Avatar
ndylam
You can get it at your local Mini dealership. Part # 13717582453. Tell them you're a member at NAM and they might give you a 10% discount
http://www.realoem.com/bmw/showparts...12&hg=13&fg=20
Old May 14, 2010 | 11:44 PM
Mini'mon's Avatar
Mini'mon
You're very welcome
Thanks for the heads-up, Andy. There was an error in the shipping price field for the clamp. I just fixed that and refunded folks that ordered the clamp only $2.00 each. Other orders placed today are OK.
Best,
-Clint
Old May 15, 2010 | 12:28 AM
ndylam's Avatar
ndylam
Best,
-Clint
You're one of the most stand up businessman in the NAM community. Not only do you create great products, but you also take great care of your consumers . And for this reason, you have so many loyal customers . I really hope you can finish where Riss Racing left off with the o2 sensor. I'd love to get one for the downpipe
Old May 15, 2010 | 07:23 AM
Dwight Walhood
Only have one comment on doing business with Clint:
Old May 17, 2010 | 03:45 AM
mlg2ca's Avatar
mlg2ca
Does anyone have a picture to show the difference between stock MCS unit and JCW ?
Old May 17, 2010 | 12:03 PM
Mini'mon's Avatar
Mini'mon
Here you go
Stock R56 MCS Inlet Tube on left --&-- JCW Inlet Tube on right
Old May 17, 2010 | 12:06 PM
mlg2ca's Avatar
mlg2ca
A picture is worth a thousand words !
Thanks.
Old May 17, 2010 | 07:19 PM
Dwight Walhood
Thousand words indeed. Picked up the JCW inlet tube today. Got home and discovered there's no way to connect it to my '08 MCS's MAS sensor! Checked RealOEM and found that the latest (1-2009!) JCW inlet tube was no different than the S. What gives? Might be able to connect with a silicone sleave. Thought this was supposed to be a straight swap.
BTW, ordered that clamp Fri. and got it today! Clint at DoS must be putting the torch to the USPS, LoL.
Old May 18, 2010 | 01:54 AM
Mini'mon's Avatar
Mini'mon
Hi Dwight,
It's a straight swap. We've done it on '07 and '08 MCS's with no problem.
Please snap a pic or two and drop some comments to this thread so that we can see what you're up against. There's probably an easy solution to this.
-Clint
Old May 18, 2010 | 07:17 AM
Dwight Walhood
Hi Dwight,
-Clint
Thanks Clint, but I think I figured it out. The hardness of the JCW tube scared me off. Didn't think the OEM clamp could make it seal to the MAS. It does, right? I tend to be the cautious type, LoL. - DW
Old May 18, 2010 | 10:06 AM
david in germany's Avatar
david in germany
Is there any hard numbers for the improvement with the JCW pipe? The stock pipe seems pretty stiff as it is.
Old May 18, 2010 | 11:26 AM
Mini'mon's Avatar
Mini'mon
Yup, the OEM clamp will seal the MAF/MAS to the tube (despite its harder durometer) just fine.
Old May 18, 2010 | 12:47 PM
thevelourfog's Avatar
thevelourfog
I may have to order one of these clamps, there's a little bit of oil residue around the turbo/JCW pipe connection on my car and I can smell a bit of burning oil when I'm running the car hard. Been running the JCW inlet tube for 14k miles with no problems otherwise!
Old May 18, 2010 | 11:13 PM
Dwight Walhood
YO Clint, you were right. The JCW tube went right on with a little modding for the OCC. BTW, this engine bay might look familiar. It's the one you put your noise maker delete into at AMVIV. Does that Super AGS ring a bell LoL. The CF STB is gone 'cause it couldn't handle the extra torque of the RMW tune. The new NM bar took care of that just fine. Thanks again for your help.
Old May 19, 2010 | 12:40 AM
Mini'mon's Avatar
Mini'mon
YO Clint, you were right. The JCW tube went right on with a little modding for the OCC. . . . Thanks again for your help.
No problem, Dwight. Any time! I totally remember your car from AMVIV. If you can make it, I hope to see you at MITM or MTTS this year.
