Drivetrain Easy fix for rubbing boost tubes.
Old Mar 6, 2010 | 06:57 PM
09MellowJCW's Avatar
09MellowJCW
First: this is NOT a post to complain about a vendor, and I hope it does not become that. I did not contact the vendor, I do not want anything from them. I just want to share this with NAM members and I hope it can help. I think by now if you have a silicone tube, you're not surprised if it rubs.
Second: We all know about hard pipes. We don't need to be told AGAIN that we should have them
Third: I found a use for the noise maker!!!
I noticed today that my hot side tube was rubbing on my coolant tank. It didn't touch sitting still. Must have hit when the engine rocked. After a little thought I decided I would put a piece of rubber hose on it to take the abuse.
Then I remembered that I still had the noisemaker up in the Attic. When I looked at it I was happy to see the factory anti-chafe wrap on it.
I cut a piece of the hose long enough to cover the spot it was rubbing and then cut it in half. Effectively making a rectangle piece to put over the rubbed spot. Next I cut a piece of the anti-chafe stuff the same size and wire tied the two over the rubbed spots.
I'm going to get some of that silicone tape that is self effusing and replace the wire ties soon.
What do you think?
l
Old Mar 6, 2010 | 07:45 PM
dunphyj's Avatar
dunphyj
wow... that's actually quite brilliant! wonder if that'd be a good way to fix that rub issue on the Alta cold side tube as well... i'll check some autoparts stores to see if they sell sheets of that anti-chafe stuff.
You could seriously be on to something not that there should be rubbing problems in the first place, but a fix is a fix right!
Old Mar 6, 2010 | 07:53 PM
09MellowJCW
The hose, on a hose, is an old trick I learned from my Dad. I don't see why it wouldn't work on the Alta tube as well. Do you still have the noisemaker on your car? If so, by the time you buy the material (i'm sure it's not cheap) and a hose, you could probably get the NMD kit from DoS and kill two birds with one stone!
Old Mar 7, 2010 | 03:08 AM
ENGINE 58's Avatar
ENGINE 58
the hose clip is a two part clip i just removed half of it and it doesnt hurt anything. but it still rubs up on the coolent tank under the edge of it. i think i will try your mod though to stop that spot from rubbing there. i still have the noisemaker from my 07 .
Old Mar 7, 2010 | 09:38 AM
countryboyshane's Avatar
countryboyshane
That's a pretty good idea!
Old Mar 7, 2010 | 04:48 PM
mikemc's Avatar
mikemc
+1 and it make sense
Old Mar 7, 2010 | 05:04 PM
tintman718's Avatar
tintman718
I used some thick felt on all the rub spots a while ago. Still holding strong. Don't ask me where to buy it though. I "get it" from work.
Old Mar 7, 2010 | 10:47 PM
Mini'mon's Avatar
Mini'mon
This is the stuff.
http://www.mcmaster.com/#catalog/116/802/=64gw0i
McMaster-Carr carries abrasion resistant nylon fabric sleeving in whatever diameter that you need. Check out the link above and look at the sleeving shown at the bottom of the catalog page.
As you'll also see, they make a wrap around version that uses hook and loop. However, the type shown at the left of the page has a higher temperature rating.
-Clint
Old Mar 8, 2010 | 05:57 AM
orangecrush's Avatar
orangecrush
That's a good idea but shouldn't be necc.... especially with the M7.
At very worst, you can cut the edge of the hose to make it change angles. I realize that the inconsistencies between hoses and cars are different but I think you should be able to adjust the angle of how it's fitting to make it fit correctly.
I use an M7 hose and did the exact same thing. I little bit of tweaking and it fits correctly. (Now, I'm pretty sure I just jinxed myself and will probably wear a hole in it this week... lol)
But if tweaking doesn't work, still a great fix.
Mark
Old Mar 14, 2010 | 07:19 PM
tominizer's Avatar
tominizer
It sounds like it works and fitting the intended purpose ................. but it LOOKS kinda ghetto.
Old Mar 14, 2010 | 07:50 PM
09MellowJCW
I know it doesn't LOOK good. It looks a lot better than a $135 hose sitting in the garbage with rub holes in it though. I should have gotten a hard pipe. Until I do this will work. Whataya you gonna do?
Old Mar 19, 2010 | 06:21 PM
09MellowJCW
-Clint
Thanks Clint,
I ordered some of this stuff for my OCC hoses. I like it. I'm going to order some for the boost tube now.
Old Mar 19, 2010 | 06:24 PM
Mini'mon's Avatar
Mini'mon
Very slick!
Nice work!
I like how it matches the loom for the wiring harnesses nearby.
Old Mar 19, 2010 | 06:29 PM
Porthos's Avatar
Porthos
Nice idea adds some refinement but, I just wen ahead and bought the nm engineering piping.
Old Mar 19, 2010 | 06:38 PM
09MellowJCW
Nice work!
Thank you. Dare I say that it looks almost factory?
Old Mar 19, 2010 | 06:42 PM
09MellowJCW
I'll do the same eventually. I've spent too much already for a little while though...
It's a SICKNESS!
Old Mar 19, 2010 | 06:44 PM
Porthos's Avatar
Porthos
Oh I know its like a crack addiction
Old Mar 19, 2010 | 06:50 PM
JamesHunt's Avatar
JamesHunt
I always thought something was wrong with you
sevin
May 2, 2026 06:11 AM
AdrenaliNate
Nov 4, 2015 07:26 PM
Aug 27, 2015 12:25 PM
SheldonCooperS
Aug 25, 2015 11:57 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
