Drivetrain R56 S PCV System ?
Old Jan 12, 2010 | 09:03 PM
Dwight Walhood's Avatar
Dwight Walhood
R56 S PCV System ?
Got a question about the dual PCV system on the R56 turbo. Can the left side tube be blocked or is there too much crankcase pressure from the turbo for a single tube (rt. side) to handle. Putting a OCC on the right side to cure the oil fouling of the turbo and IC, but want to do something to stop/slowdown the carbon fouling of intake valves caused by the left side PCV system. BTW, checked the Gen2 site for this problem and found nothing but Gen1 posts! What gives?
Old Jan 13, 2010 | 04:27 PM
JamesHunt's Avatar
JamesHunt
attach a catch can to the line or get water/meth injection.
Old Jan 13, 2010 | 05:11 PM
countryboyshane's Avatar
countryboyshane
I distinctly remember someone on NAM finding that more CC vapor passes through the PCV tube before the throttle body. Like James said, a catch can will slow it down, but if you don't want to invest in a mod like water/meth injection, you'll have to treat the intake tract buildup with Seafoam.
If you're really hardcore you'll take off your intercooler to clean it and make an attemp to clean the compressor blades on the turbo!
Old Jan 14, 2010 | 10:45 AM
minipete07's Avatar
minipete07
Just took my forge IC off and cleaned it with brake parts cleaner, also gonna seafoam and install 2 catch cans one for each vent pipe coming off the valve cover. Got 44,200 miles on my 07 r56s. i'll try and post pics.
Old Jan 14, 2010 | 11:34 AM
PaulCIssa's Avatar
PaulCIssa
When you refer to "left & right", you refer to them as sitting in the car, correct? That's industry standard. No harm or foul but that's how the following is written.
The right PCV tube operates under manifold vacuum conditions and closes when manifold pressures go positive from turbo spool. During positive manifold pressure situations (boost), the "left" PCV vent to the turbo inlet is where vacuum is present and that is why there are two crankcase vents in intake tract.
The "right" vent definitely pushes more vapors. Ultimately, you want to catch all the crap with two catch cans.
Good luck, it's a worth-while investment.
Old Jan 14, 2010 | 11:36 AM
Paleo's Avatar
Paleo
How many miles did you have the Forge IC on for and how dirty was it?
Old Jan 14, 2010 | 12:59 PM
Dwight Walhood
Thanks Paul, kinda figured it would take 2 OCCs. Would really like to see a pic of how/where to squeeze in the left side can. Anybody?
Old Jan 14, 2010 | 02:00 PM
JamesHunt's Avatar
JamesHunt
Put both cans up by the battery box.
Old Jan 14, 2010 | 02:57 PM
minipete07's Avatar
minipete07
i had the forge IC at least 30,000 miles and when i look it off it had a nice size puddle of oil on the hot side of the intercooler end tank as well as the boost tube.
Old Jan 14, 2010 | 03:08 PM
minipete07's Avatar
minipete07
http://cgi.ebay.com/ebaymotors/UNIVE...Q5fAccessories
picked up this catch can, very good quality for the right side PCV and bought a M7 r56 catch can for the left side from WMW. should be installing on saturday after seafoam treatment. keep u updated.
Old Jan 14, 2010 | 03:44 PM
JamesHunt's Avatar
JamesHunt
2 m7 catch cans $260
AEM Water/meth kit $300ish
Close in cost
Water/Meth FTW
Dwight Walhood
You must be talking R53. You ain't putting two catch cans on the left side of an R56 S!
Old Jan 14, 2010 | 03:50 PM
JamesHunt's Avatar
JamesHunt
If you have a REAL Cai you can .
Defenders of Speed CAI FTW
If you don't have a Dos you should
I mounted my Meth pump in the cavity behind the plastic soundsheild on the passenger side.Should have room for a occ/sneaky pete nos bottle/nitrous block or what have you.
Old Jan 14, 2010 | 04:07 PM
ENGINE 58's Avatar
ENGINE 58
Mr hunt how hard is it to install the w/m injection. Any pics of the tank and who or where did you purchase your kit.
Old Jan 14, 2010 | 04:12 PM
Dwight Walhood
Please do! What are the dimensions (height & diameter) on that eBay OCC? Very interested to see that left side mount when done. Might use it on the left side, but will stick with the 42 Draft Design can on the right as it's baffled. Thanks much.
Old Jan 14, 2010 | 04:17 PM
JamesHunt's Avatar
JamesHunt
Takes a little over 2 hours if you are a pro and all day if you are all thumbs.
Easy install,if you can hard wire a radar detecter you can install a meth kit.
get the RMW aquamist(tell Jan I sent you) if you want the best and can afford it,if not buy the aem with the small tank.You need meth in the tropical climate the we have in the Sunshine state.
Look around on the net for a deal
I have a direct contact so mine was FREE .
The system in my car is a overkill in a cooper ,it is a kit for hdi diesels with a 5 gallon tank .
Are you coming up to orlando for the RMW tune party at Macedo Motorsports ?
Old Jan 14, 2010 | 04:19 PM
minipete07's Avatar
minipete07
definitely! its about the same with as the m7 one put about an inch longer. i'll give u exact specs when i measure it.
Old Jan 14, 2010 | 04:29 PM
ENGINE 58's Avatar
ENGINE 58
Thank you mr hunt . I see you have the aem . Where do you mount the spray nozzle?
Old Jan 14, 2010 | 04:38 PM
ENGINE 58's Avatar
ENGINE 58
I would love a rmw tune. But I would like a dp first. And I think I will be on duty werkin. It would be awesome though.
Old Jan 14, 2010 | 04:46 PM
JamesHunt's Avatar
JamesHunt
Mount it on the coldside in the hard connection pipe that the noisemakes is attached to.
Old Jan 14, 2010 | 04:56 PM
etalj's Avatar
etalj
AEM meth kit: how does it operate? I have no experience with them. I'm assuming it doesn't splice into any wires, so it must run off vacuum? Are there any cons or risks with running a meth+water kit?
Old Jan 14, 2010 | 05:03 PM
JamesHunt's Avatar
JamesHunt
water meth is a win win only drawback is you need to refill the 1 gallon tank every few thousand miles
It is wired and runs off a boost sensor .
Old Jan 14, 2010 | 05:24 PM
minipete07's Avatar
minipete07
decent prices http://www.jscspeed.com/universal/pr..._injection.htm
Old Jan 18, 2010 | 02:18 PM
minipete07's Avatar
minipete07
Well install went well....installed both CC...did the seafoam twice and cleaned out all boost tubes, intake tube and MAF with MAF cleaner...also cleaned the IC with brake parts cleaner.... car feels smoother....just ordered new plugs from AutoZone... if i knew how to easily up load pics they would up.....still trying....
Old Jan 18, 2010 | 02:25 PM
minipete07's Avatar
minipete07
the dimension of the OCC are 6" tall and 3" wide.
