Drivetrain Oil Cooler Question
Old Apr 13, 2009 | 02:31 AM
  #26
scolburn79's Avatar
scolburn79
This is my Oil Cooler, it is an Automatic cooler with bigger lines on it. Fits in the stock location if you don't have an Automatic. I have a thermostat on it as well coming out of the Mini Madness adaptor plate.
Old Apr 13, 2009 | 05:48 AM
  #27
newbs49's Avatar
newbs49
I'll see if I can get some pics later this week when I have the car on a lift. Cooler fills whole lower grille area. Tight fit. Large cooler.
Old Apr 13, 2009 | 08:04 AM
  #28
Bigshot's Avatar
Bigshot
Waiting for price, spec's and pic's.
Old Apr 13, 2009 | 08:31 AM
  #29
Revolution Mini Works's Avatar
You guys are asking a lot out of me
I think people will pass out once they see the updated website as there are so many products to put on there.....
  #30
//MZero's Avatar
//MZero
I like this...the cooler itself is bolted down and secure. The others don't seem to be bolted to anything.
Old Apr 13, 2009 | 08:50 AM
  #31
the big downside to that application is it doesn't get good airflow over it.... I had to put my TVS there because I didn't have any other room for it anywhere else
Old Apr 13, 2009 | 10:49 AM
  #32
minimarks's Avatar
minimarks
Does the factory oil temp gauge still work or is there additional mods to do?
New site Jan, and take the mystery away!!!! LOL
Old Apr 13, 2009 | 12:07 PM
  #33
newbs49's Avatar
newbs49
Factory sender is on oil filter housing. Yes it still works.
Old Apr 13, 2009 | 12:15 PM
  #34
herbie hind's Avatar
herbie hind
ahh summer comes and oil coolers to follow. i've got madness cooler adapter plate going to a bigger strab than madness offers . why? just cause. i'm going thru a mocal thermostat too . right to the bumper is a good place to install. just add rubber washers for dampers. the thermostat fits good on passenger side crush tube . some cutting to plastic bits a must to get hoses thru without collapse . madness adapter has temp and pressure ports right on it . just use 90 or 45 degree fittings npt. btw the bottom hole out of the block is out bound flow . pull main ign. relay and bump over the starterr just to be sure, the oil should pump out the bottom hole .
Old Apr 13, 2009 | 04:29 PM
  #35
minimarks's Avatar
minimarks
Thanks!
Old Apr 14, 2009 | 05:08 AM
  #36
this is the heavy duty system for the TVS it could be used on a regular track car for those wanting the ultimate in cooling. The core used is extremely expensive so it's not for the weak of heart
5" tall X 23" long x 1.5" thick
Old Apr 14, 2009 | 06:48 AM
  #37
mdbsat's Avatar
mdbsat
Seeing as how it is going to be 98+ degrees soon in Texas would I benefit from one of these? Pardon my ignorance on the subject just looking for some info. ANYthing to keep anything cooler in/on my car would be nice.
Old Apr 14, 2009 | 07:04 AM
  #38
anytime you take heat out of the engine it's only going to last longer. We have seen 300deg F out on the track with cars even running a stock pulley
Old Apr 14, 2009 | 07:32 AM
  #39
Bahamabart's Avatar
Bahamabart
Beautiful, nice design and welds, congrats.
how much more oil does the car take with this installed?
Old Apr 14, 2009 | 07:35 AM
  #40
the regular one is about an extra 1.4 qts
this one I would imagine 2qts
Old Apr 14, 2009 | 09:00 AM
  #41
mbcoops's Avatar
mbcoops
I believe that. I've gotten up to 280 on track and my temp sensor is at the BOTTOM of the oil pan (stock oil temp gauge add-on).
A working oil cooler is near the top of my list...
mb
Old Apr 14, 2009 | 09:10 AM
  #42
newbs49's Avatar
newbs49
Fix your damn brakes first. Wheel maybe not. No engine.....................
Don't need brakes
See ya at a track some time this year.........
Old Apr 14, 2009 | 09:17 AM
  #43
yellowbritishrocket's Avatar
yellowbritishrocket
lol come on tax return...daddy needs a new oil cooler
Old Apr 14, 2009 | 09:38 AM
  #44
mbcoops's Avatar
mbcoops
Don't need brakes
haha
ah the brake saga...cliff's notes: rotors were on backwards (thus not cooling themselves) but are being installed correctly along with a duct kit (WMW). Your advice will probably end up being what I need to do: bigger wheels, thicker rotors. I'll get there. I learn slowly.
Will you be at LRP with the NJ chapter on 5/15? I'll be at NJMP on 5/2.
mb
Old Apr 14, 2009 | 09:42 AM
  #45
newbs49's Avatar
newbs49
The ducts will make a huge difference.
Old Apr 14, 2009 | 12:54 PM
  #46
Alan's Avatar
Alan
Actually, with the testing we did using temp. paint, brake ducts made no difference. One car with ducts and TSW BDM BBK. Other car without ducts and TSW BDM BBK. Brake killer track (Eagles Canyon) - I think it was a May or June event so temps weren't killer 80s/90s.
Both BBKs registered same temp as rear rotors, which is great.
Alan
Old Apr 14, 2009 | 01:05 PM
  #47
newbs49's Avatar
newbs49
OK ..... LET'S GET BACK ON TOPIC.
Yes, I was the one who mentioned brakes.
Old Apr 16, 2009 | 10:03 PM
  #48
McKwrench's Avatar
McKwrench
I was planning to install oil pressure and temp gauges for my R-53, any suggestions on where to mount the sending units?
Old Apr 16, 2009 | 10:17 PM
  #49
//MZero's Avatar
//MZero
Oil pressure is easy if you get this: http://www.detroittuned.com/shop/?productID=228
oil temp...I was thinking that I would drill and tap a hole in the oil pan. I'd assume that the oil pan temps are the most accurate temps of what the oil is actually at since it is the greatest volume of oil in the engine, thus also the most stable oil temp.
Old Apr 17, 2009 | 04:27 AM
  #50
newbs49's Avatar
newbs49
If your goin to uae Jan's oil cooler you'll have to get fittings with lines. Jan can supply those with his cooler. If you use the Madness cooler, the adapter plate has a boss on it for pressure line and temp switch.
