Drivetrain removal of the speed governer
Old Nov 5, 2003 | 08:34 PM
minicoop78's Avatar
minicoop78
i know in *** cars you can un do it with radio shack parts is it posible on the mini?
Old Nov 6, 2003 | 08:57 AM
Yeagy's Avatar
Yeagy
im pretty sure the govn. is flashed into the ecu. so there is no way to change it without a re-flashing
Old Nov 6, 2003 | 09:02 AM
dave's Avatar
dave
pug poo picker-upper
Are you seriously saying you have a need to go faster than 135 mph in Phoenix?
Old Nov 6, 2003 | 09:10 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
One thing to do that is legal if you want to be slick to the air and reduce your coefficient of drag is to tape up your front bumper and bonnet seams and openings other than for the places you need it for air intake, radiator and intercooler cooling. All the extra light openings can be taped up. Maybe that will help a little as will if you have lowered your MINI. Reduce air drag- remove the antenna and maybe the side mirror on the passenger's side.
Old Nov 6, 2003 | 10:29 AM
minicoop78's Avatar
minicoop78
no i dont drive that fast ever
but if i ever get the chance on a closed course to top it out for real i would love to do so.
Old Nov 6, 2003 | 12:07 PM
GordonD's Avatar
GordonD
The Shark Injector, and possibly most other, ECU reflashes do away with the limiter
Old Nov 6, 2003 | 12:55 PM
Thechandler81's Avatar
Thechandler81
Serious?!? Rev limiter or speed limiter? sounds promising.
Old Nov 6, 2003 | 01:03 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
The rev limiter (engine speed) and the governor (vehicle speed) are values programmed into the ECU. Change the values, and you change the limits.
Old Nov 6, 2003 | 01:13 PM
orbhot's Avatar
orbhot
I have not had anything done to my ECU and with the reduction pulley I was able to get my MCS to about 140 and that was with the windows open too! Now I don't know if my speedo is that far off or what, but I could not get it that fast before the pulley was swapped. I'm still running factory tires.
Old Nov 6, 2003 | 01:16 PM
Thechandler81
the speedo is about 5 mph fast. when i topped mine out it was reading 137-138.
Old Nov 6, 2003 | 01:20 PM
Antranik's Avatar
Antranik
Windows Open!?!?! .. but I guess at those speeds, seat belts dont even matter. Tried a speed that high in a mercedes one late night a long time ago and the crave to reach some top-speed was and still is eliminated. It's very intense if anything.
Old Nov 6, 2003 | 01:21 PM
dominicminicoopers's Avatar
dominicminicoopers
There are three paved roadcouse race tracks around the valley. They are:
Phoenix Int'l Raceway
Firebird International Raceway
Airzona Motorsports Park
PIR also has the 1 mile oval in addition to the roadcourse
FIR has dragstrips and three roadcourse tracks
Since I haven't had the opportunity to go crazy fast on any of these, I'm assuming that speeds over 140 MPH can be reached with a ungoverned MINI on at least one of these tracks.
Old Nov 6, 2003 | 02:55 PM
minicoop78's Avatar
minicoop78
i hav e the evotech and it raises both rev and speed gov. but the speed gov still tops around 140 which i hit in 5th gear. not that i ever speed
"preformed by professional driver on closed course"
Old Nov 7, 2003 | 07:42 AM
GordonD's Avatar
GordonD
Sorry I've been away from the site for a couple of days.
The rev limiter goes to 7250 and the speed is (I believe) totally gone - in any case way higher than I'm likely to drive.
Old Nov 7, 2003 | 09:18 AM
MrWhoa's Avatar
MrWhoa
You think 140 with the windows open is bad, try 160ish on a motorcycle. That is the most intense sound I have ever heard. Not to mention the extreme forces of the wind
Old Nov 7, 2003 | 09:22 AM
Thechandler81
thats the best news of the day so far
maestro39
Oct 27, 2015 02:38 PM
Cutelildevil666
Sep 12, 2015 09:36 PM
bjcarter2
Aug 31, 2015 04:03 PM
