Drivetrain First Build Gearbox (02 - 04)
Old Oct 2, 2009 | 01:20 AM
R53's Avatar
R53
I understand they are significantly longer than the late 04 - 06 models, but is there any advantage of this gearbox? I have noted that off pull away, it can be a bit bad, as first and second gears are very long, but immediately once i engage third, its where the car starts opening up. Ive noted this happening against many cars too. Is a car with the longer box quicker ontop than shorter gearbox?
I am mostly for straight line speed, dont do tracks. So should I upgrade the box or is it better to just leave it as it is?
Old Oct 2, 2009 | 06:45 AM
firenewt's Avatar
firenewt
Good question. I've wondered about that myself. I've reached the conclusion to stay with the 02-04 transmission due to my latest round of mods. The increase in power and the Quiafe LSD whips through 1st and 2nd in a big hurry. Any shorter ratio would limit the usefulness of 1st and 2nd.
Just my opinion,
Kevin
Old Oct 2, 2009 | 07:17 AM
checkmate2006's Avatar
checkmate2006
Totally right I have an 06 with the shorter 1st and 2nd gear. WOW with the mods and power I am making 1st gear is over in no time. Second is just about the same.
Old Oct 2, 2009 | 08:07 AM
epanarese's Avatar
epanarese
Obviously this is like comparing apples and oranges, but there is a reason that supercars can hit 50-60 in 1st.
In my opinion the stock mcs doesn't have enough power for the long ratios, but with basic mods it does.
Old Oct 2, 2009 | 08:58 AM
Eric_Rowland's Avatar
Eric_Rowland
Seems like a much better investment to up the torque than swap the gearbox.
Old Oct 2, 2009 | 10:01 AM
Mike S's Avatar
Mike S
After my mods, I think the original gearbox is perfect!
I punished a standard Focus ST on a rolling start.
http://www.youtube.com/watch?v=5Jo7eHAQhrk
Old Oct 2, 2009 | 11:14 AM
jhiggs26's Avatar
jhiggs26
Uh Mike you should probably go to the strip. Zipping along an undivided highway street racing is not cool.
Jeremy
Old Oct 2, 2009 | 12:33 PM
cooper99's Avatar
cooper99
Jeremy
He lives in South Africa. There probably aren't many if any drag strips there. Let the boy have fun.
Old Oct 2, 2009 | 04:33 PM
ElPolloDiablo's Avatar
ElPolloDiablo
So the 02-04 has longer 1st and 2nd gears. How do the highway gears compare? Any difference in durability?
About where does the 02-04 hit redline (7k rpm) in 1st and 2nd? (It seems like it's 30 and 60 for the 05+)
Old Oct 2, 2009 | 04:36 PM
epanarese's Avatar
epanarese
If I recall, 1st takes me to 45, 2nd takes me to 70, 3rd takes me to 90+
Old Oct 2, 2009 | 10:03 PM
Mike S's Avatar
Mike S
Jeremy
Hi Jeremy, I get that a lot on international forums This is not really out of the norm in Africa We hardly have any functional street lights in the evenings - the service from the municipality is non-existent.
Old Oct 2, 2009 | 10:49 PM
jhiggs26's Avatar
jhiggs26
Ok Mike. Please drive safe for you and the vehicles around you.
Jeremy
Old Oct 3, 2009 | 12:58 AM
Mike S's Avatar
Mike S
Jeremy
Definitely! Thanks for the concern Jeremy We always take a drive up the road to make sure there are no potholes or obstructions in advance. All the wheels etc. are checked prior as well
Old Oct 3, 2009 | 07:19 AM
k_h_d's Avatar
k_h_d
In my 03 MCS with 15% pulley and Intake first gear can't be fully used as the tires would spin throughout most of the gear. I am sure its crappy all season tires and a performance summer tire would help but I would think 1st would be even more unusable to full power if it was a lower ratio...
gar56
Nov 15, 2016 06:41 AM
Oct 1, 2015 12:13 PM
Emnotek
Sep 29, 2015 07:37 AM
EVMini
Sep 28, 2015 10:20 AM
