Drivetrain 380 injectors, JCW Re-Flash or a Different Tune
Old Sep 17, 2009 | 09:58 PM
jollyroger927's Avatar
jollyroger927
Ive read some threads on people wanting the Re-Flash with my mods (intake, alta 17%, alta cat back, colder plugs). Then some people say get the injectors. Others say it just wont work.
My question is if i get the injectors, would the re-flash tune them well enough to run better then stock, or would it not help at all becuase i dont have the JCW head. Because i heard around 190-200whp is where the stock injectors seem to give up. And i belive im around that horsepower (never dynoed). If not the JCW Re-Flash, what other programs are there that are good and can be installed by me.
I want to wait to get an RMW tune after i have a cam, head and header also. So im wondering if this will help at all till then.
Old Sep 18, 2009 | 02:00 AM
M!N!-ME's Avatar
M!N!-ME
You can run the JCW injectors without a tune. Get the JCW flash if you want to actually benefit from having them and you don't need the JCW head to benefit from the JCW flash.
-OR-
Go for a custom dyno tune from any of the tuners(Mynes, RMW, etc...) and you will really feel the difference. If you plan on getting those mods(head, header, cam) just wait till you get them then get tuned...hope that helps
Old Sep 18, 2009 | 07:18 AM
jollyroger927
The injectors arnt going to do much, if anything without a tune as i've heard so i would want to do somthing. Im going to get a dyno tune but later down the road when i have the other mods done. Right now im looking for somthing cheaper (around $300 or less) that would work with what i have.
The JCW is around $100 but ive seen so many different veiws on it that im skeptical.
Old Sep 18, 2009 | 07:27 AM
Bigshot's Avatar
Bigshot
Who is going to do the JCW flash?
Only thing the tune will do for the injectors is to modify the duty cycles, especially at WOT and if you have the rev limit raised. Otherwise the stock tune will handle the mods fine.
Old Sep 18, 2009 | 09:41 AM
tazio's Avatar
tazio
I would bet that if you got an RMW tune now (which you definitely should) you might be able to cut a deal with Jan on a second tune after buying $3k worth of RMW parts...
Old Sep 18, 2009 | 12:51 PM
Thumper460's Avatar
Thumper460
Actually the guys that run the Autobahn.. use the JCW tune on most everything they do.. just a thought!!
Just me..................................
Thumper
Old Sep 18, 2009 | 01:43 PM
MiniMacPR's Avatar
MiniMacPR
I used to run a JCW tune on stock injectors (15% / header / intake / catback) and only pulled peak 173whp. A dyno tune yielded 195whp peak without a rev limit increase. This all with the stock injectors. I'm not a believer in the JCW tune with stock head.
I would suggest to monitor your car's readings to see if the stock injectors are fine or not before you spend the $$$ on new injectors and a flash. I doubt they are at their limit at this point. Spend that money on the cam or save it up for the head and or header. Once you replace the head you will probably need to upgrade the injectors again anyways.
Old Sep 18, 2009 | 03:27 PM
Bigshot's Avatar
Bigshot
Thumper
Where and who are they?
Old Sep 20, 2009 | 12:34 PM
jollyroger927
Okay so no JCW tune, no injectors till a head? Or can they give more power with my mods anyway?
Any other tunning programs you guys recomend, ive heard of MTH or somthing? Just somthing that will boost the power untill the RMW tune. Jan might give me a deal but ill have to ask that when i order the head and cam and thats not for awhile as of now.
Old Sep 20, 2009 | 01:30 PM
minimarks's Avatar
minimarks
Installed and ran the JCW injectors for a week and then got the JCW flash, yes the car did run better!! BUT that was to carry me to the real thing, a Jan tune which is the BEST!
Old Sep 21, 2009 | 08:20 AM
RedSkunk's Avatar
RedSkunk
Injectors by themselves won't do anything but decrease your mileage.. (you're not over the stocker's limits with your mods)
..and the jcw flash is pretty marginal itself. I'd say hold off until you're ready for the dyno tune - do the injectors then.
Old Sep 21, 2009 | 08:55 AM
Thumper460's Avatar
Thumper460
Gotta agree this that!! At least on my stock ECU 06. I was so fat it went OFF the scale on the Dyno this weekend!! LOL, went back to stock inj. and I am back to being where I need. ( and that is with a CAM!!)
Thumper
I use water/meth also
Aug 12, 2015 01:24 PM
papawhiskey
Aug 10, 2015 09:31 PM
