Drivetrain now thats a cold air intake
Old Apr 25, 2009 | 08:09 AM
mtuning3's Avatar
mtuning3
[IMG][/IMG][IMG][/IMG][IMG][/IMG]
Old Apr 25, 2009 | 08:32 AM
PoktRokt's Avatar
PoktRokt
That is some serious modifying!
Old Apr 25, 2009 | 08:38 AM
JAceMin's Avatar
JAceMin
Damn, exactly, now just enclose the intake to isolate it from the engine compartment...
sweet! Very nice work!
Old Apr 25, 2009 | 08:42 AM
Warped1966's Avatar
Warped1966
That's an intake alright. Cold, however, it is not.
dtsoccer6's Avatar
dtsoccer6
Mtuning's Butcher Shop wow...too bad little to no air gets there and heatsoak will kill that...I guess we can't hate on the effort...
Old Apr 25, 2009 | 08:43 AM
Oxybluecoop's Avatar
Oxybluecoop
Unfortunately that vent hole sits behind the hood and isn't open to the outside.Nice setup though.I ran mine out behind the engine where there's plenty of consistent cooler air of course the MC has more room without all the boost tubes.
Old Apr 25, 2009 | 08:49 AM
Oxybluecoop
Yep!
Old Apr 25, 2009 | 09:19 AM
mtuning3's Avatar
mtuning3
today in that hot weather im runing only 9 degrees celcius more than the outside temp compare to 20 degrees more with the old set up
Old Apr 25, 2009 | 09:29 AM
dtsoccer6's Avatar
dtsoccer6
how u measure that? show us?
Old Apr 25, 2009 | 09:34 AM
mtuning3's Avatar
mtuning3
vag com ,ambiant temp vs air intake temp
Old Apr 25, 2009 | 11:29 AM
a96bimmerm3's Avatar
a96bimmerm3
Is it almost done being tuned?
Old Apr 25, 2009 | 11:37 AM
mtuning3's Avatar
mtuning3
i dont think the maf likes bean to close around the turbo
Old Apr 25, 2009 | 12:00 PM
coopman7's Avatar
coopman7
I like the work you have done there. Looks good. However it would probably have been better to put your standard airbox back on connected to the cold air feed and that way you have a CAI that is positioned well out of the way of the turbo and thus heat soak wont be an issue. You could put a box around your current setup to make it a CAI however heat soak will still be an issue because of the close proximity of the filter to the turbo.
Old Apr 25, 2009 | 01:15 PM
Gilboyto's Avatar
Gilboyto
I was going to say. From my previous experience I had to put the MAF as far as possible from the turbo inlet as possible. It causes some weird turbulance issues when you let off the throttle etc and the MAF reads incorrectly.
I know mine caused a lot of stalling issues.
Old Apr 25, 2009 | 03:30 PM
Straius's Avatar
Straius
Interesting setup Oxy! How are you piping that air to the turbo?
Old Apr 25, 2009 | 03:45 PM
Porthos's Avatar
Porthos
Its an awesome idea. But IMO you have run the tubing into that hole and gotten a HKS mushroom looking filter and put it in there. I would also look at wrapping the tubro so that it doesn't bleed heat all over the place and you would be good. But awesome job on the intake looks really good. Don't really see many MINIs moddified this way. +1 for the work.
Old Apr 25, 2009 | 06:06 PM
Oxybluecoop
What turbo I was just showing another way to get cooler air. It requires removing the intake manifold and throttle body though.
Old Apr 25, 2009 | 07:03 PM
chakraj's Avatar
chakraj
Here is a real Cold Air Intake, and I have the factory air duct going into the bottom of it. It is a copy of the Defenders of Speed intake, using the K&N Apollo just like they did..
Old Apr 25, 2009 | 07:45 PM
Oxybluecoop
Damn! It ain't pretty but it serves it's purpose.
Old Apr 25, 2009 | 08:58 PM
mtuning3's Avatar
mtuning3
well i need to make a new disign very bad location for the maf car runs like ****
Old Apr 25, 2009 | 09:07 PM
Oxybluecoop
You could move the battery and run it through the firewall. There would be plenty of room for a cone filter to the outside air similar to chakraj's setup just not directly under the open grill.
Old Apr 25, 2009 | 09:14 PM
Straius's Avatar
Straius
Well... that answers my questions then! hahaha
I like that your modification doesn't have any sharp bends in the piping mtuning.
Too bad you have to re-think it. You gonna try something else, or go back to stock location?
Old Apr 26, 2009 | 07:05 AM
jcap287's Avatar
jcap287
School away from MINI
What happened to your tune?
Old Apr 26, 2009 | 07:13 AM
ngweibing's Avatar
ngweibing
so many ....
chrisx18240
26
Mar 16, 2022 09:56 AM
W0TM8
Dec 19, 2019 07:50 AM
cawwwtun
May 3, 2016 08:03 AM
Aug 27, 2015 03:18 PM
theblackfalcon
Aug 26, 2015 09:18 AM
