Drivetrain Serpentine belt w/M7 16% pulley
Anyone now which NAPA part I should use with the M7 pulley, just the supercharger pulley reduction, no 2% crank.
Also any find a good way to release the belt tensioner without getting the tool? Kinda in a bind, don't want to wait to get one from an online vendor.
I just did my belt last week. I found some guy's solution on here for not using the tool, after a while of searching. Can't remember his name or where to find the post, but the credit goes to him for this. It works quite well. I just found some old iron rod in my garage, it was about 3ft long, and just picked random screw out of my toolbox that looked about right.
So a long rod or pry bar
a 5/8 hex socket for a fulcrum point
a 1" to 1.5" screw
and a little allen key to place in the hole to hold the tensioner back.
Here's a quick diagram of the set up.
a 1" to 1.5" screw
Here's what you want. Use it on my M7....no squeal on cold start, no other problems.
http://www.napaonline.com/NOLPPSE/(S...535_0227723267
Si, I got a 2nd set of hands in there and it's all good. Thanks for the help everyone.
I think collapsing the tensioner more would have helped, but had it as far as I could get it while having my hand in there too..had a pin in the 2nd hole holding it, is there third hole for future reference?
Yeah it's a very tight fit, I have a Helix 15% pulley. I used the pin in the second tensioner hole as well. I looking at far the spring was compressed, I don't think it would be possible to get to the third hole if there is one. I think the key is work the belt around all the pulleys and leave the smooth idler pulley for the last one. Since it's smooth you can work the belt around it from the top of the engine. Just get it started, and then pull up and push it on.
elverado
Jan 18, 2022 02:51 AM
daviday
Sep 25, 2015 01:31 AM
