Hey Guys, i just ordered an Alta 17% S/C Pulley, and I wanna know if it is highly recommended that I should get another belt? what will happen if i uses the stock belt for it? Thanks for you guys' help.
I believe that yes it will fit but is not recommended. Alot of people have issues with belts braking when going to a 17% and a 19% pulley. Alta also recommends a smaller belt. THIS IS TAKEN RIGHT FROM THE ALTA WEBSITE
I know that chart says 060539 belt with 17%... but the 060535 belt seems to be a better fit for me, even on a 15% pulley... the 539 is right at the edge of being too long once it stretches a bit... the 535 fits nice and tight, with proper tensioner tension...
Another question. I live in OC, Cali. does anybody know a place that can install it? Thanks.
If you feel like driving for 45 minutes then head over to MINICORSA in north hollywood. If not, then Revolution Mini works is in Irvine. They could also give you a tune of you really want it . Also, search through the forum in southern california section. It has a list of shops in SOCAL.
Question, I have a 2004 S in the engine compartment next to the coolant expansion tank right side there is a resevior with the cap saying CHF11S only can someone tell me what this is .Can't find it in the owners info.
Thank you Charlie
