Drivetrain Just installed Shark Injector
Old Oct 14, 2003 | 02:46 PM
  #126
greatgro's Avatar
greatgro
Rear wheel HP on a front wheel drive car That must be some mod.
i've been wondering about that too! Figured it was a miss print but if you go back and look, every time numbers are quoted they mention rear horsepower. I wonder if they dynoed the right car!
Old Oct 14, 2003 | 05:01 PM
  #127
cristo's Avatar
cristo
Alliance Member
actually, if you measure horsepower by monitoring the rear wheels on a fwd car,
you don't get spurious blips from front tire wheel spin.
(or am I f.o.s?)
Old Oct 15, 2003 | 05:14 AM
  #128
fueledbymetal's Avatar
fueledbymetal
>>(or am I f.o.s?)
f.o.s.
Old Oct 15, 2003 | 05:28 AM
  #129
Super_MINI's Avatar
Super_MINI
>>I have seen that, but that doesn't address the question of how much of the gain the Shark is actually responsible for. In fact, that chart doesn't indicate which runs (if any) had the Shark installed.
>>Added to that, I am EXTREMELY skeptical of any dyno charts showing signifcant low-end torque gains from intakes. Here's what my boost curves look like with the stock airbox compared to the Alta intake:
>>Note how the curves are almost identical to 4500 rpm.
>>_________________
>>1/4 Mile Database
Andy,
I totaly agree there, you should see the most improvements from a free flow air filter at the top of the curve where the stock filter begins to fall off because of airflow restriction. Low end torque and High end "FWHP" are always a trade off.
The Dyno chart from Turner is Stock, Pulley/Shark, Pulley/Shark/Intake. Turner doesn't install pulley's without the ECU because they say it run's too lean without it.
Old Oct 15, 2003 | 06:17 AM
  #130
Veni_Vidi_Vici's Avatar
Veni_Vidi_Vici
I love this thread!
I'm seriously considering ordering the Shark when I get a pulley. I'd also like to get a set of headers and, in the future, a larger throttle body.
Should I, a.) just get the pulley and the Shark and forget about the rest? b.) get the headers and take my chances?
Old Oct 15, 2003 | 06:34 AM
  #131
formini's Avatar
formini
I have the Shark, pulley, and Air Box and very happy with.
Maybe a nice exhaust will be next.
I don't think than we need more for an everyday car...
Old Oct 15, 2003 | 06:54 AM
  #132
andy@ross-tech.com's Avatar
andy@ross-tech.com
That's funny - Turner USED to say the car runs too RICH without the software.
Will Turner from Turner Motorsport, a knowledgeable and level headed fellow, reports that his cars run rich unless they do an ecu mod
https://www.northamericanmotoring.co...amp;topic=8305
Until I see an actual dyno chart showing the change from JUST the shark (and even better, an A/F chart comparing the shark to stock) I don't believe the hype.
Old Oct 15, 2003 | 07:37 AM
  #133
200mph's Avatar
200mph
This is a great thread... Jim, thanks for your time.
My big complaint with the MCS is the "run-on" I get when I completely lift the throttle.
I'd like the car to decelerate from compression braking when I lift (like pre-emissions cars and purpose-built race cars do), instead of the ECU adding in fuel to reduce emissions during decel, making the car slow at a leisurely rate.
Jim, does the Shark Injector address/correct this situation?
Thanks,
Mike
Old Oct 15, 2003 | 08:07 AM
  #134
ubercooper's Avatar
ubercooper
Dual mass flywheel is the likely culprit for the run on. It weighs like 20-30 pounds. I picked up one when I was in the shop at Peabody mini (great place by the way) and was stupified by how heavy it was.
Old Oct 15, 2003 | 08:11 AM
  #135
andy@ross-tech.com
Don't forget that the supercharger acts as a flywheel as well (spinning 2.06 times engine speed or faster ).
Old Oct 15, 2003 | 08:13 AM
  #136
ColoradoMark's Avatar
ColoradoMark
I think the "run on" is also a symptom of forced induction. I see the same thing of my turbocharged Audi.
Old Oct 15, 2003 | 08:22 AM
  #137
MSFITOY's Avatar
MSFITOY
Randy, it would be great if you could give your opinion on the Shark. How does it compare with your Powerchip?
Old Oct 15, 2003 | 09:19 AM
  #138
Antranik's Avatar
Antranik
After driving the car everyday for over half a year, this is something we get used to and adapt, like most other things. I remember the first 1000 miles with the car, the engine delayed drastically. The Quicksilver exhaust has helped make things a lot more snappier though as far as that throttle lift off response but the same exact change may not have been felt if it was the first mod I did. I say this because I put the exhaust after the intake and pulley, and those modifications with a stock exhaust make the engine feel very restricted for that part of the equation, making things feel a lot more in balance when you get a system that reduces the backpressure. When I drive other cars, the response is still generally very different than the (laggy) MINI but regardless of that, it's easy to get used to and forget about it with enough use and fun.
Old Oct 15, 2003 | 10:34 AM
  #139
lit1's Avatar
lit1
just installed the Shark tonight and here a notable differance in the power of the car now. it feel a little slower then hartge i drove last week.
current car Mods
Shark
M7 Plasma booster
MINI Mania header with cat
free flow exhaust
IK22 plugs
future mods
Pulley "next week"
rear sway bar "next week"
Alta intake
Old Oct 15, 2003 | 10:55 AM
  #140
fueledbymetal
>>future mods
>>Pulley "next week"
Old Oct 15, 2003 | 11:12 AM
  #141
Stratmosphere's Avatar
Stratmosphere
Speaking of headers. The "original" Milltek will be back in stock late this week or early next week at only $895 (aka Quicksilver or London Stainless). And don't forget we also stock the Shark for immediate shipment. -Pete, Stratmosphere
Milltek Mini Header
Old Oct 15, 2003 | 11:41 AM
  #142
Stratmosphere
OK, some dyno charts. What you are looking at are two charts. One is our Mini S with Stock software, Rogue airbox, Milltek catback and 15% pulley. Two pulls shown on that chart. The second chart is all the same EXCEPT the SHARK software is installed (93 Octane). Once pull is displayed.
What you can see. Earlier torque with the Shark and 9-10hp at the wheels gain. Earlier in this thread I explained we are running more rich than the OEM software. If the Shark ran lean, more power would be here. -Pete, Stratmosphere.
BEFORE - NO SHARK
AFTER - SHARK SOFTWARE UPLOADED
Old Oct 15, 2003 | 11:51 AM
  #143
andy@ross-tech.com
Those plots aren't technically at the wheels since the Dynapack bolts to the hubs. What is the difference between the two runs in the first plot? Do you have a run showing the shark and non-shark on the same plot? Do you have any runs showing the car bolted to the Dynapack stock?
For those who don't know, a Dynapack is a type of dyno where an electric motor is bolted to each hub of the car (in place of the wheels) and power is measured through the motors.
Old Oct 15, 2003 | 11:59 AM
  #144
Stratmosphere
The first chart simply has two pulls printed on it. Later on that day, the Sharked pulls occured. The chart shown represents a typical pull with the Shark. In general, the first pulls were "flyers" with higher numbers which we would discard, but I'm showing that in the stock pull (you can see the second pull there was lower but I'm showing the "flyer". The Sharked pull is not the flyer run, we had even higher numbers, especially torque. But I have to show what YOU can expect to get, not what I hope you could/might get. I guess I need an education about "at the wheels". I've seen everyone quoting this method as power at the "wheels" but what do I know! -Pete, Strat
Old Oct 15, 2003 | 12:19 PM
  #145
andy@ross-tech.com
Here's the higher of the two stock pulls compared with the shark pull, in a little more easily viewable format:
Old Oct 15, 2003 | 12:34 PM
  #146
Stratmosphere
Damn! You need a job?
Old Oct 15, 2003 | 12:45 PM
  #147
andy@ross-tech.com
I play with graphs all day for a living. One more doesn't make a dent in my productivity.
Old Oct 15, 2003 | 12:57 PM
  #148
greatgro's Avatar
greatgro
If I am reading them correctly, it looks like 8.5 horses and only 2 lbs of torque. And the torque doesn't really seperate from stock until approaching 5k RPMs.
Old Oct 16, 2003 | 01:13 PM
  #149
Stratmosphere
The torque also hits ealier and stays later as well. Plus, don't forget that the Fuel-Air is now corrected to run less lean (more lean would = even more power) -Pete, Strat
Old Oct 16, 2003 | 01:14 PM
  #150
Stratmosphere
