Drivetrain quick question: rmw tune + pulley size
Old Oct 26, 2008 | 04:56 PM
jerjer's Avatar
jerjer
im ordering a pulley, and wondering.. will 15% or 17% be better for a RMW tune.. so far i mostly only see 15% pulley, i guess it's a all rounder pulley, better for tune? i rmb some 17% problems with like boost issues or w/e problems it had to make 15% more desirable?
or should i just go with the 17% anyways, cause who doesn't like more power?
can someone guide me a little through this?
thanks
jeremy!
Old Oct 26, 2008 | 05:26 PM
batrugger's Avatar
batrugger
Jan always recommends a 15% on a stock head. You can get some higher revs if you go to the JCW injectors with it. The best person to talk to about it though is Jan.
Old Oct 26, 2008 | 06:46 PM
jerjer's Avatar
jerjer
yea, i guess hving a 15% is better.
i rather hv a better/fun setup then just pure numbers~
Old Oct 26, 2008 | 11:29 PM
mkskchun85's Avatar
mkskchun85
I'm in the same position as you. Spoke to jan, he recommends 15% helix.
Old Oct 27, 2008 | 10:58 AM
MidnightDave's Avatar
MidnightDave
I had a 16% M7 'cause that's what Dan at GrassRoots Garage had laying around when I was there one time ;-) and had him put the JCW 380s in the day of our Jan tune, and performance is great.
Paul/BlimeyCabrio just got the RMW header and now "we" all want one, too! Get that too, if you can afford it!
Old Oct 28, 2008 | 03:25 AM
jerjer's Avatar
jerjer
hopefully the header will be my next mod if santa thinks i'm a good boy~ and since school and the economy isn't exactly helping anyone at this time
now that i hv some mods.. hopefully i can lay out a good setup to run with:
invidia exhaust, alta intake > pulley, sparks (1 step colder) > injectors + headers> and more hopefully~
Old Oct 28, 2008 | 02:55 PM
melvyn's Avatar
melvyn
i have the helix 19%, jcw intake, jcw 380cc injectors, and rmw tune.
Old Oct 28, 2008 | 06:50 PM
second to none's Avatar
second to none
19% and GIAC
How much difference would a RMW tune make opposed to GIAC?
Old Oct 28, 2008 | 09:29 PM
batrugger's Avatar
batrugger
It will make a big difference. This is a before and after dyno of our car going from the RMW Head, GIAC flash, stock injectors, and 15% pulley to the RMW tune and 440cc injectors:
Basically 23 whp and 8ft/lbs of torque. Jan will tune your car with whatever you have or want on it. I talked to him about a 19%, but he strongly discouraged it because of cooling the intake and only thought the 17% that we added later was good because we got a GP intercooler. He did reduce the max RPM from 8k to 7500 k because of the increased pulley rpm's.
Old Oct 31, 2008 | 03:29 PM
jerjer's Avatar
jerjer
good infos to know guys..
i think i will be happy with a 15%..
and i see most ppl running 380 injectors only, any reason to run up to 440?
Old Oct 31, 2008 | 03:48 PM
batrugger's Avatar
batrugger
440cc injectors were for the RMW head, so if you have a stock head, then the max with the 15% would be 380cc
Teh
Aug 22, 2022 04:37 AM
W0TM8
Dec 19, 2019 07:50 AM
blackie
Sep 2, 2015 09:16 PM
Aug 7, 2015 09:51 AM
