Drivetrain occ benefits
Old Oct 18, 2008 | 02:08 PM
tommy_zito's Avatar
tommy_zito
occ benefits
just wondering what the benefits of the occ sorry may be an obvious answer but just dont know...
Old Oct 18, 2008 | 10:46 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Oil catch can? Have you ever taken your intercooler off? Try it, then feel and smell the oil in there. Then spray in some throttle body cleaner and watch all the oil wash away. Oil film is an insulator and prevents the intercooler from working at it's best. The catch can keeps this film of oil from forming on the inside of your intercooler.
Old Oct 19, 2008 | 02:35 AM
tommy_zito's Avatar
tommy_zito
ya i have taken it off just never knew it was hurting it at all...thanks for the info
Old Oct 19, 2008 | 07:39 AM
OldRick's Avatar
OldRick
However, the insulating effect is small - you might get another 1% of HP from an OCC on a hot day....
Old Oct 19, 2008 | 07:46 AM
james f's Avatar
james f
some minis need them some dont, always clean your i/c once in a while best way imo
Old Oct 19, 2008 | 12:24 PM
johnf36's Avatar
johnf36
Might find this interesting
http://www.importtuner.com/reviews/i...ans/index.html
Old Oct 19, 2008 | 01:44 PM
TRuTH's Avatar
TRuTH
Originally Posted by johnf36
Very interesting, I always wondered about that.
Old Oct 19, 2008 | 02:36 PM
second to none's Avatar
second to none
I just hate how I lose 1 quart per oil change (5-10k) to the PCV system. I know at least my rotors are lubed!
Old Oct 19, 2008 | 03:13 PM
ScottRiqui's Avatar
ScottRiqui
Interesting, but not really meaningful as far as power gains go. First, the difference between 242.8 and 244.3 horsepower on a dyno is nothing - you'd probably get a bigger difference between consecutive runs even if you didn't change *anything* on the car. ALWAYS be wary when someone reports dyno horsepower to four significant digits, as if it's a piece of precise lab equipment.
More importantly, look at the two configurations they tested - it wasn't a comparison between a stock PCV system and an oil catch can, it was a comparison between a catch can and a simple push-on breather filter. Like the article says, a push-on breather filter loses the benefit of drawing a vacuum under the valve cover, while a stock PCV system *does* draw a vacuum under the valve cover, just like a catch can system.
As for losing oil between changes to the PCV system, I haven't lost near that much ever, in either of our MINIs. In fact, except for the first 5,000 miles when the cars were new, I haven't had to add any "top-off" oil at all, and the oil level's never gotten close to the lower dipstick mark, even with 10k+ drain intervals.
Regardless, if you're having that problem, a catch can isn't going to help you. Any oil that's drawn out of the valve cover under vacuum is lost forever, whether you have a PCV system or a catch can (unless you empty the catch can by pouring it back into the engine oil, which I *don't* recommend).
Old Oct 19, 2008 | 11:23 PM
MINICHEF's Avatar
MINICHEF
I catch more water (condensation) in mine than oil
Old Dec 13, 2008 | 06:55 AM
keeyu's Avatar
keeyu
my oil catch can don't have any oil.
Old Dec 13, 2008 | 12:23 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
There is a second way of routing the hoses that is not really listed on the instruction sheets for these cans. I forget how it is, but there is a thread about it somewhere on here.
At any rate, this method is more effective at catching oil.
Old Dec 14, 2008 | 09:11 AM
soccerbummer1104's Avatar
soccerbummer1104
lol, i set it up the way nabeshin suggested and i still dont have any oil collecting in my catch can, now its just coated like the intercooler. lol. anyone here have any suggestions on how to folter out the air better? I hae the alta and the air doesnt go through any of the foam to filter it really. it just skims across the top and out the other hole.
Old Dec 14, 2008 | 09:24 AM
not-so-rednwhitecooper
No matter what you will still have to take the intercooler off once in a while to clean it.
Water in the catch can is a good thing. Its better off there, than in the pan. If you do alot of short trips, you will notice alot of water in the catch can.
You should have stainless steel wool in the catch can to make it filter better. If its just an empty can, its not going to do much.
Old Dec 14, 2008 | 12:43 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Well, it's not going to catch pools of oil. If it did, something would be seriously wrong with your engine.
As suggested by not-so-rednwhitecooper, steel wool in the can helps more than the foam.
IQRaceworks
53
Jun 28, 2024 07:29 AM
micromini234
Sep 30, 2015 07:36 PM
donniedarko
Sep 29, 2015 01:16 PM
Emnotek
Sep 29, 2015 07:37 AM
