Drivetrain R56 Oil Temp or Oil Pressure Gauge
Been trying to get information on where to tap in for either one of these gauges?
The sending unit for oil temp can not be fitted to the drain plug since the drain plug is on the bottom of the pan, not a good idea!
The OEM oil pressure sender (trigger's the idiot light) is located on the drivers side front of the block. A local shop got an adaptor and T fitting to try to get both sending units to fit (OEM must be used or the ECU get's mad) but there isn't enough room to tighten down the fittings.
Anyone find a place to tap into the motor for oil temp or oil pressure?
There's a thread that talked about this but it went dead before a solution was found.
Any help here would be greatly appreciated.
Has to be a way to do one of these gauges installed!
Cheers!
Cheers!
Who mentioned anything about the oil feed line. The pressure sending unit is on the block? There not enough room to get a fitting and both sending units fitted.
If you have a possible solution, please be more forthcoming with your solution.
Cheers!
I metioned the oil feed line. The turbos oil feed line comes off the block. Soooo put your T on the turbos oil feed line and wala you have oil pressure reading.
While like anything on a R56, you have to remove several things to get the task done but it is doable. It depends on the adapter used and the secondary sensor.
A really good dual purpose tap point is the area at the oil cooler at the filter area. I was looking at machining a plate that fits between the two so the stock unit bolts back on and then you have two tap points (pressure and temp). Seen here: http://www.realoem.com/bmw/showparts...30&hg=11&fg=30
I have not tackled this issue yet on mine but its next on the list since the ECU/OBDII does see oil pressure signal just its in the extended code set that no one will decode out yet and my shop is offline for overhaul and remodeling ...
Does not really help you out all that much but its some info.
Cheers.
Cheers.
If you can get to the oil fiter setup, that for sure will be easier than the turbo pressure line i could imagine!
Good suggestion. I though the sending unit on this car was on the oilfilter housing, guess not?
Cheers.
Cheers.
Would be very interested if you come up with something. More interested in Oil Pressure but I'll take anything oil related at this point.
Cheers and thanks!
Moribius, thanks. In your write up you state oil cooler, but on the link it shows a heat exchanger item # 4. Is that the point that you are referencing?
Cheers and thanks!
Cheers and thanks!
Cheers.
I know some turbo setups have oil restricters in the oil feed line but its usually towards the turbo end of the line, not sure if the mini has this case? ON the neon srt4 block there is plenty of space to tap a T to the oil feedline and it reads on point and it has no oil restrictor on it. Its a feed not a return and its a good ways from the turbo so its running regular engine temps on it.
Craven now makes a Tapeless adapter to accoplish this task. It fits between the block and the factory sender.
http://www.cravenspeed.com/index.php...less-adapter-2
Most gauge manufacturers sell electronic units also -- they use a sending unit in the engine compartment and wire to the gauge.
Here are two:
http://prosportgauges.com/amber_whit...ce_gauges.aspx
http://www.nordskogperformance.net/index.php
Here are two:
Reviving an old thread...
Man... been searching oil temp sending units for a few hours now and it's looking a bit dismal.
R56 drain plug oil temp adapter seemed like a bust since the plug is located at the bottom of the oil pan and one little speed bump can rip that sucker off and open the signal... or worse... you create an oil leak.
http://new.minimania.com/web/Item/G2.../InvDetail.cfm
I've heard these tapless adapters aren't exactly an ideal location for temperature.
So far... it seems to be the only tapless solution if you want oil temperature readings.
Should I just drill into the oil pan?
Is this the best option so far?
BTW... Prosport gauges are AWESOME!
I got some Prosport Halo 52mm gauges on my MR2 and I love 'em!
Cheap, quality, looks very similar to double/triple the price Defi gauges, and Prosport has some excellent customer service and quick shipping.
Also, the back is supposed to be very short and not deep (like the Autometer gauges) so you shouldn't have a problem with install if you used Alta gauge pods. I can't verify that until I get the stuff in though.
Getting another set of Prosport for the MCS.
I just installed an oil pressure and water temperature gauge setup from Craven. They also offer an oil temperature gauge and sending unit.
Here is a link to a thread that talks gauges https://www.northamericanmotoring.co...ml#post2971432
and a link for the Craven gauges http://www.cravenspeed.com/products/...Gauge-Kit.html
I think their a little pricey but they work and look great!
here's a link to the one I used and managed to get a pressure and temp guage fitted to it although it was very difficult to install both. It does work and has passed the Dealership test! I've had mine installed for about 12 months now no troubles.
Kimolaoha
Jul 5, 2023 01:04 PM
PelicanParts.com
Aug 14, 2015 11:07 AM
