Always have, always will, always will reccomend it. It's cheap insurance for whatever reason they may need to be pulled in the future whether it's replacement or something more involved. If I can save a massive headache for 99 cents ahead of time, I will. And as far as torque specs, follow whatever is reccomended. I just went off the Bentley manual for the MINI. Most places use just a number as a spec. I don't think I've seen a rotational or degree setting for plugs. That's usually saved for something with a higher torque value.
= 1111111111111111111
hemihead you are showing your history, you must be into bikes (motorcycles)
Torque it at 20 ft.lbs.
I have always used the hand tight + 1/4 turn with NA engines but I guess not for boosted engines. During the RMW tuning session, my plugs came loose.
25ft lbs using anti seize always. used to use 22 ft lbs until i was corrected by a mini tech... there is no way to tq the plugs correctly w/out antiseize.
Not really. I find some stuff neat but not really hardcore into it. If anything, I see how kids on crotchrockets ride in my area and it makes me hate bikes. I just had some awesome teachers in school. Although, this would be fun....
Not really. I find some stuff neat but not really hardcore into it. If anything, I see how kids on crotchrockets ride in my area.
How do you know they are kids with the helmet on Nice thing about helmets is no one know how old you are so if you want to be stupid...
CBR F2, 750 Magna, XT500,KX80 and my special toy RG500Gamma 133whp@ 356lbs wet.
And I always use anti-seize on the spark plugs !
But the funny things is I chase after crotchrockets in the twisties with my Mini
Anti-seize and torque to 22ft.lbs.
Always!! Never had a problem with plugs loosening up.
Me too. And I check em every 5000 miles when I change the oil. 22ft./lbs and mine have never been loose. I also don't check, tighten or install plugs except when the heads are stone cold.
