Drivetrain LSD swap - is it fairly straightforward?
Old Jun 11, 2008 | 09:04 AM
70spop's Avatar
70spop
I just got off the phone with my local shop, and had asked about a rough estimate for a clutch/flywheel/LSD install. The guy I spoke with wasn't sure about the LSD install because he didn't know if there are any special tricks involved. He said that the LSDs that they put into BMWs have required disassembly of the differential and shimming of gears/bearings and such.
Other than the expected disassembly to get to the diff, is it a pretty straightforward r&r or is there "black magic" involved?
Old Jun 11, 2008 | 09:09 AM
minimusprime's Avatar
minimusprime
if you buy a quaif it's as simple as taking the tranny off and putting the lsd in it and re-installing the tranny. If you buy an obx it should be the same process but a couple of people here have found it's a good idea to take the obx apart before throwing it in to check the spacing washers and shims and such... otherwise it's the same as the quaif in theory.
a phantom grip requires that you take the diff apart and do some mumbo jumbo.
Old Jun 11, 2008 | 09:55 AM
spdfreak's Avatar
spdfreak
The OBX is a straight remove and replace the same as the quaife.
Old Jun 11, 2008 | 04:46 PM
jhiggs26's Avatar
jhiggs26
This is from a recent thread I posted to 70spop. No 'black magic' involved!
"Here's a fabulous how-to by K-huevo:
https://www.northamericanmotoring.com...52#post1451152
Here's my experience with the install:
https://www.northamericanmotoring.com...t=obx+atb+diff
Here's one more fun read:
http://engr.smu.edu/rcam/cpm3v/minic...niclutch01.htm
Jeremy"
Here's my phantom grip install from last month. It's for sale in the marketplace too!
https://www.northamericanmotoring.co...d.php?t=140093
Jeremy
Old Jun 11, 2008 | 05:05 PM
70spop's Avatar
70spop
Thanks, guys! Jeremy - great links thanks!
Like I said, I won't be doing this myself. A shop will be doing it. After reading through a lot of that, though, I'd feel better about a shop with lots of MINI clutch experience. Seems REALLY involved, if not especially tricky. We'll see.
Old Jun 11, 2008 | 05:41 PM
COR BLMY's Avatar
COR BLMY
My son and I did 2 clutches, OBX LSD and flywheels in our "spare" time (Not working our real jobs) in a week ... not a big issue but the right tools ...including some swivels and extensions make the job easy(er)
Both really happy with our systems & especially the OBX LSD ...
We did disassemble both and one had bad torque specs and the other had the famous cup washers backwords. also some machining shortcuts (flashing left on through holes)
I think the design and materials are good but perhaps cheap labor is the reasion for the assembly ... take the 15 min and check it out...
Old Jun 12, 2008 | 07:21 AM
70spop's Avatar
70spop
Hmmm, there may be another one in your future... I'll get in touch with you when I get all the parts.
Old Jun 12, 2008 | 09:37 AM
COR BLMY's Avatar
COR BLMY
I am so happy I did this
it is worth it.
OutMotoring
Nov 16, 2015 07:04 AM
vulkandino
Oct 31, 2015 08:29 PM
Doc Pain
Oct 28, 2015 07:09 PM
bahman
Sep 30, 2015 01:59 PM
Sep 28, 2015 09:13 AM
