Drivetrain Changed plugs and wires, whats next!!!???
Old Jun 6, 2008 | 04:18 PM
zmanrz's Avatar
zmanrz
okay, so my R53 has been acting up a bit as of late, has trouble turning over, miss firing at WOT. So i changed plugs and wires, and while changing them i noticed that my intercooler couplers were dry rotted and cracked, so got some new ALTA ones.
so after installing all the new parts, NOT A DAMN DIFFERENCE!!!!!
so my question is do i need a new coil?? or what???
thanks....
Ryan
Old Jun 6, 2008 | 06:05 PM
hemiheaded18's Avatar
hemiheaded18
Has the car been modded? Has it been properly maintained? Do you have a CEL on? More details would be a big help....
Old Jun 6, 2008 | 07:49 PM
Jhud's Avatar
Jhud
as hemiheaded said, more details. sounds like a fuel problem, but with such limited info its a 100% guess.
Old Jun 6, 2008 | 07:54 PM
hemiheaded18
Possible high RPM lean out is a choice, but again, 100% guess.
Old Jun 6, 2008 | 08:15 PM
Guest's Avatar
Guest
thanks....
Ryan
Trouble starting = compression usually. Run a compression/leakdown test.
How many miles do you have on your car?
Old Jun 6, 2008 | 09:02 PM
zmanrz's Avatar
zmanrz
i've got 71k on the car. CEL light has been on since i put my header on (no cat) also has 17% pully, alta exhaust, CAI, walbro 255 fuel pump.
the car is well maintained by myself.
when driving it tonight i noticed that if you don't just mash it to the floor, it's fine, but 3/4 to WOT it skipps and hic-ups, as soon as you let out it shoots flames out the back. idle is not rough, nor does it miss when revved with no load.
Old Jun 6, 2008 | 09:03 PM
hemiheaded18
A lot of mods and no tune? That could be your culprit right there. With those mods and no tune, it could be in safe mode.
Guest's Avatar
Guest
Run a compression check and leakdown...
Old Jun 6, 2008 | 09:06 PM
zmanrz's Avatar
zmanrz
will do sir.....thank you for the help
Old Jun 6, 2008 | 09:40 PM
El_Griton's Avatar
El_Griton
header on (no cat)
are you running a 02 simulator?
Old Jun 7, 2008 | 04:02 PM
UKSUV's Avatar
UKSUV
You all are silly....Its an injector....
Old Jun 7, 2008 | 04:15 PM
minimusprime's Avatar
minimusprime
things i'd check;
compression
header install rather for exhaust leaks
map sensor (either get a new one or hit the current with carb cleaner)
injectors gummed up? (not sure about this one... highly unlikely)
Old Jun 7, 2008 | 04:42 PM
MINI_pocket_rocket's Avatar
MINI_pocket_rocket
Perhaps it's your belt slipping on the supercharger pully? I have a 17% reduction also and was having a similar problem with boost spikes at WOT. Went to see Chad at Detroit Tuned, installed new/shorter Belt, no more spikes!
Old Jun 7, 2008 | 05:00 PM
bthayer23's Avatar
bthayer23
Wait, so flames aren't supposed to shoot out the back?
Old Jun 8, 2008 | 05:36 AM
poskey's Avatar
poskey
Do you have the part# of that belt? Thanks
Old Jun 8, 2008 | 07:06 AM
MINI_pocket_rocket
I don't have a part number but here is a link to the belt
http://www.detroittuned.com/products...20061102225055
Old Jun 8, 2008 | 03:45 PM
zmanrz's Avatar
zmanrz
UPDATE::: ruled it down to a fuel problem..... whenever i take LEFT turns my car falls on it's face and bucks hard. if i make a LEFT u-turn, it completly shuts down! once i straighten back up, it kicks back in. so i think i'm gonna take out the walbro255 and put the stock pump back in. and hope for the best
Old Jun 8, 2008 | 03:58 PM
minimarks's Avatar
minimarks
Gonna say it sounds fuel starved, while your in there (may already have) change the fuel filter...
Old Jun 12, 2008 | 01:58 PM
zmanrz's Avatar
zmanrz
UPDATE!
so i pulled the fuel pump to inspect any problems.....nothing. so i popped off the fuel line to the tank (passenger side) and there was no pressure in the line!!!!! where am i losing it??? stuck injector possibly?????
UKSUV i think i might get an "i told you so"
tr3y003
Oct 22, 2015 10:48 AM
sprp85
Aug 22, 2015 06:16 AM
Super Coop
Aug 17, 2015 05:09 PM
FLYM1N1
Aug 16, 2015 01:17 PM
Getrieben
Aug 15, 2015 09:09 PM
