Drivetrain Hai Done! Pic
Old May 31, 2008 | 03:26 PM
funracer's Avatar
funracer
Hai Done! Pic
Easy easy. 30 minutes and 15 if you have done it before. Car drives way better, but that might be because previous filter was filthy. Looks cool and cost $43 from Autozone. Filter even comes with its own clamp. Easiest mod I have done. Ready to autox tomorrow!
Old May 31, 2008 | 04:28 PM
grillhands's Avatar
grillhands
I give it a few months then you'll be looking to do more mods to the ride
Old May 31, 2008 | 07:40 PM
silversmoke06's Avatar
silversmoke06
why?
Old May 31, 2008 | 07:51 PM
jhiggs26's Avatar
jhiggs26
Because shorter straws are easier to suck through.
Jeremy
Old May 31, 2008 | 08:07 PM
silversmoke06
Even if its hot?
Old May 31, 2008 | 09:49 PM
Some Guy's Avatar
Some Guy
At rest it is indeed hotter than a CAI, but once the car starts moving though it starts to suck in cool air again.
What was the part number of the filter you used? I want to do this, like right now.
Old May 31, 2008 | 09:56 PM
kapps's Avatar
kapps
I'm pretty sure there was some testing a while back (by Andy, if I remember correctly) regarding this. He found that more air was better than less even if it was warmer. Up to a degree, I'm sure this is correct. As Some Guy stated, once you get moving, things cool down pretty quickly.
Old May 31, 2008 | 10:11 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Originally Posted by silversmoke06
Even if its hot?
Also, keep in mind that most "cold air intakes" arn't even that, so this mod is valid.
Old Jun 1, 2008 | 04:50 AM
funracer's Avatar
funracer
K&N ru1540
Old Jun 1, 2008 | 05:30 AM
Bahamabart's Avatar
Bahamabart
Several years back there was a lot of talk HAI vs CAI. The shorter straw theory has applicability like you say to a point verses AIT. The HAI is a fun, easy and inexpensive mod, allowing many to experiment and get first hand cause and effect experiences.
The M7 AGS incorporates part of the HAI theories.
The original aftermarket CAI design was an open box and opened to cowel vent. The final consensus however is that the original CAI design is overall the best of all worlds. From there the aftermarket made a lid for most of their CAIs. Toady virtually all aftermarket CAIs have a lid of sorts.
Another example of how the original factory design is tough to beat but can be tweaked. Also bear in mind that most of the gains from any of these aftermarket CAIs is the FILTER.
Old Jun 1, 2008 | 07:41 AM
AliceCooperWA's Avatar
AliceCooperWA
IMO, figuring out how to mount a cone filter inside of the stock airbox is the best (cheapest) solution. But it makes sense that above school zone speeds, you will have air moving around a lot and will suck in some hot, but mostly cool air with a hai mounted up front like that. If it was in the back, I think the benefits would be less.
Old Jun 1, 2008 | 03:59 PM
herbie hind's Avatar
herbie hind
ahhh; welcome to the hai fold as it were . this is a very cool mod . just look at all the air flow now . get rid of that bottom piece to the stocker though . just cut it off . and then more air flow through the bay .
Old Jun 1, 2008 | 04:27 PM
Haggardsk8er's Avatar
Haggardsk8er
Yup!!! Agreed!!!
Just unplug the ECU, remove the filter box bottom half, (it has one 10mm hex bolt in the front right corner attached to the trans mount), and use a jigsaw on that motha'!!!
Last edited by Haggardsk8er; Jun 1, 2008 at 04:28 PM. Reason: Bolt size correction
Old Jun 1, 2008 | 04:29 PM
Haggardsk8er
You know, this would be a great place for a carbon fiber ECU box & cover!!!
Old Jun 1, 2008 | 05:14 PM
revray's Avatar
revray
If this sounds like a dumb question, that's probably because it is, but here goes ...
I noticed you have a Works configuration, would this mod be only for a JCW setup, or could you put it on Justa Cooper?
Old Jun 1, 2008 | 05:16 PM
Haggardsk8er
You can do it to a "just-a-cooper"... The JCW intake uses the same base, the only difference on the top is the infamous "FLAP" in the back
Old Jun 1, 2008 | 06:38 PM
revray's Avatar
revray
Thanks for that quick reponse. Now for one more question. Does making this simple mod improve gas mileage, or lessen gas mileage, or is it one of those kind of things where there's divided opinion on the answer?
Old Jun 1, 2008 | 06:44 PM
Some Guy's Avatar
Some Guy
The second one, it is divided.
Old Jun 1, 2008 | 06:49 PM
Haggardsk8er
That's what happen's when you live on the forums... haha... talk about a bomb a$$ Sunday night!!!
As far as the gas mileage? I'm not sure... Never been concerned with that... But it sound's wicked awesome with an aftermarket filter and no top!!!
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
OldElvis
Oct 5, 2015 07:31 PM
NYXF56JCW
Oct 3, 2015 04:27 AM
MINI Stupor
Oct 1, 2015 11:36 AM
aldito2
Sep 30, 2015 10:44 AM
