Drivetrain Revolution Mini Works goes 291.7whp!!!!
Old May 21, 2008 | 08:49 PM
  #201
Guest's Avatar
Guest
Originally Posted by PGT
not to mention gearing
Yea, I don't understand people and their "Take it to the drag strip! That's how you REALLY tell the HP" thing. I guarantee you if I ran my car on the dyno strip each run would be off by a second.
There are SO many variables to establish times on the drag strip. Simply having a different kind of tires makes the results completely null and void. I fail to see how it's more accurate than a dyno that just measures how much power the engine puts out...
Old May 21, 2008 | 09:50 PM
  #202
ClintTheMiniOwner's Avatar
ClintTheMiniOwner
I can't wait to hear it. I'm very excited. Im getting one if everything works out. How is the throttle responce?
Old May 22, 2008 | 01:11 AM
  #203
Paul Webster's Avatar
Paul Webster
Originally Posted by Revolution Mini Works
I dropped off the 550cc. Injectors today
WOOOOOOHHOOOOOOOOOOOOOOOOOOOOO
Old May 22, 2008 | 01:25 AM
  #204
Paul Webster
Most people even experienced racers get hooked on the ET, which when comes to winning racers counts.
But when it comes to measuring horsepower its your mph and the weight of your car as you are on the line which tells the truth, last year I run 115 mph 3 times but my et ranged from 11.77 to 12.59 the biggest difference was in the first 60ft by .6540 which effects the et but not the mph, the rest of the difference was in the 60-330ft because the 1-2nd gear change was later.
Look at runs 50 66 and 77 http://www.eurodragster.com/timing/2...r%20Street.xls
If you get enough laps on the dragstrip its good to experiment with shift points because you might find that your car likes something totally different to what you think just like a woman
Old May 22, 2008 | 02:32 AM
  #205
Vernon29RW's Avatar
Vernon29RW
Originally Posted by SPDinNY
When I had my car dyno'd I didn't have the hood up or have someone holding a leaf blower and a mini shop fan over my intercooler!! All I had was a large fan pointed at the front of my car. Is that how Jan does his dyno's and if so how much of a difference does it make??
Old May 22, 2008 | 06:01 AM
  #206
RedSkunk's Avatar
RedSkunk
Well if you were determined to prove a point, then sure. If you were trying to get low ETs, the times would be pretty repeatable once you found the right groove... (Besides Paul's point about trap speeds = power.)
There are as many variables with the drag strip as there are with a dyno, the only "true" measure of HP being an engine dyno measuring at the crank which I don't see many people using.
I would like to see more of these cars going down the strip because the difference between 250hp and 291.7hp is pretty abstract to me. And I'm not a drag racer at all. I went once last year and will be going once this year, tops.
There was a rotrex Subie at the last autocross, and it sounded... A lot different... than any other Subie I've heard.
And on the topic of the Rotrex and power delivery.. I'm sure it's perfectly streetable and fun on a daily driver, but...
- I find myself under 3k rpm 90% of the time trying to stretch gas while commuting,
- and I want as much low end grunt as possible for autox.
But then I'm not the targeted market for a rotrex either I guess.
The popcorn smilie has to have been the best addition to NAM in years. I bet if it was a premium feature they'd get a lot more people paying.
Old May 22, 2008 | 06:19 AM
  #207
checkmate2006's Avatar
checkmate2006
For me anything between 3k-4k rpm i get better gas milage
Old May 22, 2008 | 06:34 AM
  #208
PGT's Avatar
PGT
if it sounded Honda-like, those were equal length headers you heard. the boxer rumble is due to unequal length headers (many like the sound even though equal length has show to make more power...expensive to do though given the layout of the motor and turbo)
Old May 22, 2008 | 07:06 AM
  #209
ScottinBend's Avatar
ScottinBend
Originally Posted by Paul Webster
Yup lets move on guys because the whole community knows there is only one real world horspower calculator, mph / weight at the end of the 1/4 mile
Old May 22, 2008 | 08:45 AM
  #210
SPDinNY's Avatar
SPDinNY
I honestly have no idea how much difference it would make. It may also help with heat soak during runs.
Old May 22, 2008 | 09:37 AM
  #211
Dr Obnxs's Avatar
Dr Obnxs
Till Jan has his own shop...
he's at the mercy of the equipment at the shop that he's using for the dyno work.
Matt
Old May 22, 2008 | 10:12 AM
  #212
curv872's Avatar
curv872
Ran a 103mph with a passenger, doing the math confirmed DynoHP, ~238hp
Old May 22, 2008 | 12:31 PM
  #213
Guest's Avatar
Guest
Yes, but a given distance, weight, and HP can't be the only variables. Traction is huge, also gearing. A car with a much higher final drive will accelerate faster in a given distance than one with a lower final drive. I understand we're comparing the same car here, but still, 04 compared to 05, different tire sizes, etc.
You can't just say that both cars weight the same (Which they won't, the drivers are different weights), and got up to 105 mph in 1/4 of a mile, therefore they have the same HP . Driver skill is also huge. An experienced drag racer is going to go faster down the strip than I will, even given the same car with both drivers.
Old May 22, 2008 | 01:03 PM
  #214
ingsoc's Avatar
ingsoc
Heh, but wouldn't it be awesome if you took your car with the special rmw air-sucky thingy down the strip and without the benefit of drag racing experience you smash the "fastest M45" record?
Of course, once my special air-sucky thingy arrives and I get a chance to go out to Englishtown, I will do just that (but working 80 hours a week with only 15 days off per year kind of kills your social life). Oh and I will post evidence of the unpossible .
Old May 22, 2008 | 01:49 PM
  #215
Longboard Mini's Avatar
Longboard Mini
The "fastest M45" record car has an RMW air-sucky thingy (head) on it .
Longboard
Old May 22, 2008 | 01:57 PM
  #216
ingsoc's Avatar
ingsoc
Longboard
no no the other air-sucky thingy...
Old May 22, 2008 | 03:00 PM
  #217
Paul Webster
I believe if my memory is right the later JCW cars were 2/10ths quicker with the new box but same mph
The heavier car wll have more bhp if they both went 105.00 mph
Yup your et might differ but your mph will proberly be the same. Dont under estimate your own skill, once you've broken your virginity an practise your launch technique you'll be laughing, just feel sorry for those others in the next lane to you
Old May 22, 2008 | 04:31 PM
  #218
Guest's Avatar
Guest
Longboard
Yes, this is a different air sucky thing...
Old May 22, 2008 | 04:44 PM
  #219
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
What is it?
Old May 22, 2008 | 04:48 PM
  #220
jhiggs26's Avatar
jhiggs26
The rotrex behind the throttle body sucking air....
Jeremy
Old May 22, 2008 | 04:54 PM
  #221
ingsoc's Avatar
ingsoc
Jeremy
No, not that one either. This air-sucky thingy will use the stock M45 supercharger and therefore will challenge for the "fastest M45 car" honors. And, it's being installed/tuned at a Helix near you! Err...yeah, something like that . Eric will be giving me free dyno time for sure, because we're going way over 200 whp on the "heart-breaker" dyno.
Old May 22, 2008 | 04:56 PM
  #222
jhiggs26's Avatar
jhiggs26
Mmmmk Ingsoc good luck with that air-sucky thingy then!
Jeremy
Old May 22, 2008 | 05:01 PM
  #223
ingsoc's Avatar
ingsoc
Jeremy
Thanks! All will be posted here for the world to see, rest assured! I have business to settle with "a certain alphanumeric tuner" (thanks isellem....you made me LOL) who I paid to royally ***** my car, when all is installed.
ps: I'm not keen on playing games/secrets... I just want to post with substance, in depth, and that means I will hold off until I actually have data to share. This is one of the most important things that I have learned along the way in this tuning community.
pps: I don't want to misdirect this thread about one of RMW's many accomplishments. The Rotrex produces REAL results. RMW produces real results, with none of the BS. That is truly special, and that is why I am along for the ride!
Old May 22, 2008 | 05:31 PM
  #224
Guest's Avatar
Guest
Old May 22, 2008 | 05:32 PM
  #225
godspd's Avatar
godspd
I would like to see a pic of this air sucky thing, bcuz if it's all that I would like to get 1 too. Goodluck with your dyno time & tune. I will be waiting with anticipation of the results.
