Drivetrain when will the RMW 2.0ltr engine be avaliable???
Old Mar 4, 2008 | 05:21 AM
chuntington101's Avatar
chuntington101
i know the guys there have alot of work on at the min but i was wondering when this kit is going to be coming out??
thanks Chris.
Old Mar 4, 2008 | 05:52 AM
PGT's Avatar
PGT
I bet if you send Jan the $$, he'll figure it out sooner than later
Old Mar 4, 2008 | 05:53 AM
greengobln's Avatar
greengobln
when the new r59 comes out... j/k maybe you should pm Jan
Old Mar 4, 2008 | 11:28 AM
simplekid15's Avatar
simplekid15
I wanna know when that rotrex kits going to be out.
I want that!
Old Mar 4, 2008 | 12:55 PM
herbie hind's Avatar
herbie hind
that my friend is ALL i'm saving my money for . it's the end be all for me . lots of torque for real world driving . it's everything the mini should've been from jump off .
Old Mar 5, 2008 | 12:07 AM
chuntington101
im not having a go at Jan! just wondering when the release date is.
i know they have a lot on there. what with the rotex and the new engine and problaby countless other things.
thanks
Chris.
Old Mar 5, 2008 | 10:10 AM
UKSUV's Avatar
UKSUV
I know I'm waiting for a response! I've been starring at his Red Devil for months now and I want a ballpark figure so I know how much it will cost for my build! Plus, a GT35R would compliment it nicely.
Old Mar 5, 2008 | 11:17 AM
simplekid15
GT35R OMG! thats 2 big!:O
Old Mar 5, 2008 | 11:43 AM
UKSUV's Avatar
UKSUV
Shhh..It's just fine on a 2.0L....
Old Mar 5, 2008 | 06:08 PM
hemiheaded18's Avatar
hemiheaded18
Nah, Subie guys make it work all the time with either the 2.0 or the 2.5
Old Mar 5, 2008 | 06:11 PM
simplekid15
No I know it would work but that would be so much lag.
Old Mar 5, 2008 | 06:17 PM
PGT's Avatar
PGT
on a 2.5L, yes. GT30 or GT32 on the 2.0L. The GT35/2.5L is good for 400+whp and 3500rpm spool.
Old Mar 5, 2008 | 06:40 PM
UKSUV's Avatar
UKSUV
My sources say it's good to up to 600HP. Might be just a hair big for the 2.0L. I might scale it down. I was gonna go with a GT3071R but I am gonna go inbetween those two in the end. I wonder what turbo Jan went with on his red car...
Old Mar 5, 2008 | 06:43 PM
simplekid15
Well that sounds sweet! Yea that car is sick!
Old Mar 5, 2008 | 06:46 PM
PGT's Avatar
PGT
I did say '400+whp' didn't I? That means more than 400BHP, a lot more. Normally on a Subaru, 20% losses on the drivetrain vs. 12% on the MINI, so 500+HP at the crank (depends on mods...meth of water injection, FMIC, etc).
Old Mar 5, 2008 | 08:25 PM
Longboard Mini's Avatar
Longboard Mini
How about the loss of tire tread every time you step on it .
Longboard
Old Mar 5, 2008 | 08:42 PM
PGT's Avatar
PGT
my buddy has a full Cosworth 2.5L longblock that will do 10k rpm and 800hp sitting in his basement. <drool>
Old Mar 5, 2008 | 08:55 PM
MiniStupidfun's Avatar
MiniStupidfun
Jan better have it available by the time I get done with basic training!
Old Mar 6, 2008 | 05:17 AM
chuntington101
the scooby guys have NOTHING on the EVo guys! 800bhp is childs play to them. 1000bhp 2.0 or 2.3s is where its at for them!
also you can have a HTA conversion done to the 35's which makes them spool pretty quick on a 2.0. thats what Buschur uses and he is getting full boost (30+psi) under 5K.
i think the 2.0 conversion will really open up the turbo market for the MINI. a GT30R al of a sudden is the normal sized turbo to be running.
also with the Rotex kit they are coming out with, big power and driveability should be on the cards....
thanks Chris.
Old Mar 6, 2008 | 06:20 AM
gnatster's Avatar
gnatster
But does it move the foundation?
Old Mar 6, 2008 | 12:54 PM
UKSUV's Avatar
UKSUV
It wouldn't be the $15K Cosworth 2.5L that T-Rex Motorsport built is it? Pushing like 850HP.
Old Mar 6, 2008 | 01:00 PM
PGT's Avatar
PGT
I believe it was built by Cosworth for that guy, but then TRex sponsored him, so, he sold it to my buddy. It's still in a crate. I can post pics later when I log back into my profile on this machine (running an install at the moment)
Old Mar 6, 2008 | 02:05 PM
UKSUV's Avatar
UKSUV
I know what motor it is then. That thing is sick.
Old Mar 6, 2008 | 02:17 PM
PGT's Avatar
PGT
Heres the Specs:
All New from Subaru Stock Long-Block (2005 2.5 STI MOTOR)
Darton Sleeves/Liners For 100mm Pistons
79mm Billet Cosworth Crankshaft
High performance Main and Big End Bearing
Cometic Head Gasket
Xtra Heavy Duty Forged Connecting Rods (Cosworth Spec) With ARP Heavy Duty Bolts
Cosworth Spec EJ25 Light Weight Forged 100mm Pistons
Cosworth Spec H.P. Rings
Cosworth CNC Ported Big Valve-Max Flow Race Cylinder Heads
ARP Heavy Duty 11mm Head Studs
272/262 June Cams and June Adj. Cam Sprockets
Power Enterprise heavy duty cam/timing belt
1mm oversized Stainless Steel intake valves
1mm oversized Inconel-high temp exhaust valves
Hi Rev (Max 10,500rpm) Valve Spring Package
Billet timing belt tensioner
8.25 to 1 Compression
Balanced and Blue Printed
Old Mar 6, 2008 | 02:21 PM
PGT's Avatar
PGT
car is currently stored.....PPG dogbox or straight cut gears going in as well. APS SR55 with EWG and FMIC
