Drivetrain Help! My belt schredding?
Old Feb 22, 2008 | 12:12 PM
nikoamok's Avatar
nikoamok
Ime riding with an alta 1 series kompressor pulley 17% and after mounting my crank pulley (alta 3%) it is tearing my bealt to pieces after hard acceleration in 1. and 2. gear.... This my 4. belt? Now ime parked on the street without any belt ... I turned on the key 20 sec without the belt and i could hear that the crank pulley was making a wistle sound like it was touching the engine slightly... It is wherry could here now like 36 F and iwe only tried the engine when it was warm
Old Feb 22, 2008 | 12:15 PM
nikoamok's Avatar
nikoamok
I have only tried the crank pulley when the engine was warm
Old Feb 22, 2008 | 12:41 PM
onasled's Avatar
onasled
These aluminum crank pullies have been know to loosen up and pull away from the block. I had this issue a few times.
Old Feb 22, 2008 | 01:00 PM
nikoamok's Avatar
nikoamok
it did that actully even thought i used the oem mounting tool... what do i use. lock tite ?
Old Feb 22, 2008 | 01:19 PM
Modshack's Avatar
Modshack
Your puleys are outta line...Take a look again at the crank pulley. Something is farked..
Old Feb 22, 2008 | 04:22 PM
onasled's Avatar
onasled
I ended up using a heavy lock washer. Never had an issue after that.
Old Feb 22, 2008 | 04:48 PM
nikoamok's Avatar
nikoamok
what does farked mean?
Old Feb 22, 2008 | 04:52 PM
early_apex
Knep-ed
Old Feb 22, 2008 | 04:58 PM
nikoamok's Avatar
nikoamok
Originally Posted by early_apex
Knep-ed
he he ... come on guys your talking to a foregner... knep-ed... he he funny "knepped" in danish means ****ing... So yar sure
Old Feb 22, 2008 | 04:59 PM
nikoamok's Avatar
nikoamok
what i mean is i dont undertsand...?
Old Feb 22, 2008 | 05:00 PM
early_apex
Seriously, farked = f**ked. He means it's screwed up or broken.
Something is not right with the pulley install
den hevet måtte være ikke opstillet ?
Old Feb 22, 2008 | 05:13 PM
nikoamok's Avatar
nikoamok
i remowed it with oem tools and assembled the alta 3% with oem tools as well... so i dont think i installed it wrong? talked to Jef from alta and he never heard of such a problem anyways i will mpeg it tomorrow in daylight and send it to him... And seriously, ??? pis a din lile bøsse...
Old Feb 22, 2008 | 05:18 PM
early_apex
bøsse? Hvem tror du egentlig du er?
Old Feb 22, 2008 | 05:36 PM
nikoamok's Avatar
nikoamok
he he you got me... thats good... i surrender spadser? blink!
Old Feb 22, 2008 | 05:56 PM
Guest's Avatar
Guest
The first thing I would do is pull off the crank pulley. If that doesn't solve your problem, swap the 17 out for a 15.
Old Feb 22, 2008 | 06:05 PM
nikoamok's Avatar
nikoamok
thanks ill rip it of after ill take some mpegs... Rustyboy how is your mini riding on the track with the light oz and yoko spec 2?
Old Feb 22, 2008 | 06:51 PM
onasled's Avatar
onasled
Wait, are you saying that Alta has never heard of the "crank" pulley working it's way loose? It happened a lot.
I may have gotten lost on this thread. Am I even on the right subject?
Old Feb 22, 2008 | 09:33 PM
Guest's Avatar
Guest
I don't run the Spec-2's on the track, I have a set of Avon Tech RA's that I use on the track. Rides pretty well, as can be expected the ride is a bit stiff .
Lightened wheels are nice, hard to find tires for 16's though on the street, I hate running 205 width tires, and the spec 2's are horrible for traction.
Old Feb 22, 2008 | 09:34 PM
Guest's Avatar
Guest
If you're talking to me I have no idea? My post didn't say anything about Alta knowing or not knowing.
Old Feb 22, 2008 | 11:50 PM
nikoamok's Avatar
nikoamok
it came loose yes... what kinde of washer did you use... And alta never heard about it hitting the engine block sligtly. ime making an mpeg so you guys kan se what i mean.
Old Feb 23, 2008 | 04:42 AM
onasled's Avatar
onasled
Hitting the block? Oh, that way ? Yea, I never heard or that either. I thought it was pulling away from the block.
Old Feb 23, 2008 | 04:43 AM
onasled's Avatar
onasled
I know. The OP did.
Old Feb 23, 2008 | 07:50 AM
nikoamok's Avatar
nikoamok
That really helped mee alot... it had come lose as you guys predicted... that sound was the pulley bouncing up an down on the screw... so i tieghtend it with locktite blue and a lock washer... Thanks again ... happy days and eaton m45 sounds....
VanisleRyan
Sep 30, 2015 08:35 PM
eliseo1981
Sep 30, 2015 07:57 PM
fkrowland
Sep 30, 2015 10:30 AM
dragonby
Sep 25, 2015 08:10 PM
daviday
Sep 25, 2015 01:31 AM
