Drivetrain 19lbs of boost!
19lbs of boost!
Just an update. I just installed the ALTA boost guage. I am hitting 19lbs max boost. I am happy since I just installed the ALTA FMIC.
Adam, what were you getting?
man those gauges are hot!! is there anyway you can mount 4 of them? i want to eventually get boost, oil pressure, water temp, and oil temp.
I think there was a mount made for the r53 but i dont remember seeing one for the r56.
WOW all that boost at idle! thats one fast spooling turbo!
j/kChris.
Looks good Mike! I can't wait till I get my new R56. Does anyone know the max boost of the JCW tunning R56 package?
Thats a good question. anyone? Mario are you considering the JCW tuning package?
Mario
I'm planning on just buying a gauge and trying to put something together to mount an oil temp sensor in with the OE oil pressure switch.
I'm headed to the ALTA Showroom Grand Opening tomorrow so I may end up getting a normal boost gauge and water temp gauge pods.
Hmm....or I'm sure someone up there will have a boost gauge installed and we can hook up my ScanGaugeII to see if the values match up.
Not sure on the setup but if you read the boost via the OBDII that reading is from the ECU!
But is it from the PnP ECU or the OEM ECU? I'm thinking it is reading from the PnP ECU. I'd have to see wiring diagrams on how everything is spliced together to say for sure though.
The OBDII port reading has to be from the ECU. Are you sure the OBDII software reads in PSI? Maybe its 23 of something else?
