Drivetrain flat spot developing.
Old Feb 14, 2008 | 08:07 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
After I got my 15% pulley, there was the normal flat spot down low. However, 25k miles later I don't notice that spot anymore, but there is a new flat spot from about 5,000 rpm to 6,800 rpm. Could this be caused by a boost leak in the intercooler bellows? The lack of power at this range was never this much. I know it doesn't pull all the way to redline, it never has. This is just less pull than normal. The pulley is not slipping, there is no change in pitch or any belt/metal noise. Would it be prudent to get a set of uprated bellows?
Old Feb 14, 2008 | 08:11 AM
minimusprime's Avatar
minimusprime
start with belt. measure your boost as well. and go from there.
Old Feb 14, 2008 | 11:54 AM
the platform's Avatar
the platform
I put on a Gatorback belt on,and I'd swear someone tuned the car while I was'nt looking.Sounds freakin amazing too!
Old Feb 14, 2008 | 12:27 PM
Maxicooper's Avatar
Maxicooper
Belt it is.
Old Feb 14, 2008 | 01:48 PM
2002redMCS's Avatar
2002redMCS
when mine was stock (02 s) it pulled to redline, and now with a alta intake and 15% pulley it pulls all the way to redline much faster....sounds like you may have a boost leak.
Old Feb 14, 2008 | 01:57 PM
minimusprime
i'd bet a decent amount of money on it being the belt. They will slip and will do so ever so slightly without making a peep. Only way you'll really be able to tell since it's such a slow transition to slipping is on a dyno or by replacing it.
Old Feb 14, 2008 | 02:42 PM
Intense's Avatar
Intense
252whp 200trq RMW style
what size Gatorback belt is needed for a 17% pulley? Anyone know off hand?
Old Feb 14, 2008 | 02:48 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
My belt only has 10,000 miles on it, could it be bad already?
Old Feb 14, 2008 | 05:06 PM
minimusprime
what part # belt is it?
Old Feb 15, 2008 | 09:53 AM
tennis_man's Avatar
tennis_man
The part number for a Goodyear Gatorback POLY-V belt for a 17% pulley is GTR-4060537 from Summit Racing.
Old Feb 15, 2008 | 12:30 PM
Intense's Avatar
Intense
Thank YOU!
Old Feb 15, 2008 | 03:30 PM
latte hiatus's Avatar
latte hiatus
Intense, I would be interested to know if replacing with the Gatorback 537 helps to at least partially resolve your issues.
Old Feb 15, 2008 | 04:48 PM
thë_cöpi's Avatar
thë_cöpi
If not the belt, check your tensioner.
Old Feb 15, 2008 | 04:50 PM
Intense's Avatar
Intense
Thats why I'm going to change it I'm interested as well. I have a appointment to get my car on a dyno the 26th. I want to get this belt on before that so I can tell if there's a difference. I'll keep you posted Latte. After talking with Jan tho he agrees with your assessment. I've done more than my injectors and ecu can handle mixed with this cold
Old Feb 15, 2008 | 10:13 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I had oil contamination on the belt, but I cannot fix where I think the leak is coming from. My oil pressure guage sender and the stock dummy light sender are hooked to a brass T fitting. That has drips of oil and a spray pattern around it, but the fittings are tight. To fix this all, Im going to get the Madness oil cooler plate with the sender fittings build into it. Right now I'm going to have to keep it under 5k so the belt doesn't slip untill I get that part.
Old Mar 27, 2008 | 10:23 PM
silversmoke06's Avatar
silversmoke06
Check belt tensioner, everyones on the right track for the belt its self
how ever the bellows are likely to go bad if they are improperly installed or removed.
If i were you i would seriously look into getting your car tuned by jan.
when i had mine done we found it was lean in the top end quite a bit.
so this could be part of it.
after mine pulls straight to the redline with fury and runs great all over
Old Apr 14, 2008 | 10:26 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
So my belt tensioner's damper is leaking and that soiled the belt in addition to the oil from my leaking aeroquip lines (which are now fixed)
Anyone know where to get just the little damper/shock from the tensioner? I don't want to buy the whole stupid thing if I don't have to.
Old Apr 15, 2008 | 08:08 AM
ScottinBend's Avatar
ScottinBend
Nothing is currently available. Someone was looking into getting a source for just the damper, but nothing has been announced yet. I had to bite the bullet and put in a new tensioner ($130 from dealer) and belt on for the same reasons.
Old Apr 15, 2008 | 02:03 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
The dealer quoted me $158 for a tensioner today... I'll be getting the GTT tensioner and idler pulley in a while.
Old Apr 15, 2008 | 04:29 PM
ScottinBend
Don't bother with the GTT tensioner. The only difference is with the pulley.....same damper and short life. Check with Classic MINI or Morristown for a better price on the OEM unit. The life of the damper will be better when the correct sized belt is used for the pulley you have.
Old Apr 15, 2008 | 05:21 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I do have the smaller than stock size belt. It was the size Alta recomended when I put the 15% pulley on. Is there a better size to use? I've already bought the spare belt. Good thing I have not ordered the tensioner yet.
Old Apr 15, 2008 | 05:31 PM
ScottinBend
If you are using either the 537 or 535 belt you should be good to go. I use a 535 belt with my 15% pulley.
vetsvette
Oct 11, 2015 06:05 PM
Ovrclck
Oct 5, 2015 09:45 AM
Colt45Magnus
Oct 1, 2015 04:08 PM
MINI Stupor
Oct 1, 2015 11:36 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
