Drivetrain quieting aftermarket exhaust
Old Feb 8, 2008 | 10:02 AM
freeskier's Avatar
freeskier
i recently bought a magnaflow rear section for my 02 MCS. i did not buy the resenator so the rear section is mated to the stock mid pipe. I think it sounds great but because i live at home, i have been told that it has to be a little quieter. i need to make it noticibly quieter at idle, what would be the best way to do that?? thanks
Old Feb 8, 2008 | 11:19 AM
Longboard Mini's Avatar
Longboard Mini
You need to add a resonator at the end of the center tube just before the Y.
Longboard
Old Feb 8, 2008 | 01:34 PM
freeskier's Avatar
freeskier
how much will adding a resenator do for the sound and idle? thanks
Old Feb 8, 2008 | 02:33 PM
Longboard Mini
It depends on the length. Should do the trick for what you want.
Do you start it and let it warm up before leaving? My parents hated me for that because I had a sport bike with race pipes.
Longboard
Old Feb 8, 2008 | 06:29 PM
Chase's Avatar
Chase
Dont go cheap on the resonator. I would look at the flowmaster hushpuppy or whatever its called resonator. I think Misfitoy has/ had one on his you might wanna pm about it
Old Feb 8, 2008 | 06:31 PM
PGT's Avatar
PGT
hushpuppy
Hushpower.
Old Feb 8, 2008 | 06:35 PM
Chase's Avatar
Chase
hahaha i was close
Old Feb 8, 2008 | 06:48 PM
miminut's Avatar
miminut
From: Half Moon Bay California, 25 miles south of SF on the coast
JCW resonator
If you live in the Bay Area I have a JCW resonator,free! All you have to do is pick it up.
Old Feb 8, 2008 | 07:30 PM
CooperSS's Avatar
CooperSS
When I had a Magnaflow I added a second 36" resonator just before the "T".
That finally made it bearable for long trips.
How I long for those sort of quiet days.
Bill
Old Feb 9, 2008 | 05:10 AM
a610's Avatar
a610
I recently replaced a traditional resonator (the baffle was loose and rattling) with a moroso spiralmax muffler. 2.5 in/out with a 4 inch OD body. This change made the car alot quieter. The idle is good, cruise is very quiet, and full throttle opens up. Another option to make your decision more difficult.
Old Feb 9, 2008 | 05:21 AM
Bahamabart's Avatar
Bahamabart
I'd simply park two blocks away from my parents house.
Old Feb 9, 2008 | 05:33 AM
roofaS's Avatar
roofaS
I took the simplest option and sold it
Absolutley hated the Magnaflow, way way too loud for me.
Old Feb 10, 2008 | 05:52 AM
Bahamabart's Avatar
Bahamabart
try a 1-ball
Old Feb 10, 2008 | 05:50 PM
freeskier's Avatar
freeskier
i love the sound, im 18 and loud is still good for now. i just need it to be quiet enough at idle for my parrents not to fliip out again. has anyone packed a resenator with anything?
Old Feb 11, 2008 | 04:07 AM
Fatherdeth's Avatar
Fatherdeth
I personally wouldn't recommend packing your own resonator. You'd be better off buying a quality resonator. It'd be cheaper in the long run.
Old Feb 11, 2008 | 06:42 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
is moving out an option?
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Feb 11, 2008 | 07:13 AM
freeskier's Avatar
freeskier
i leave in august for college and the car comes with me but until then, their house, their rules. looks like a good resenator is the best option. any suggestions on the best at a reasoable price? thanks
Old Feb 11, 2008 | 07:21 AM
AstroBlackS's Avatar
AstroBlackS
http://www.aeroexhaust.com/performan...ator_ar20.html
Old Feb 11, 2008 | 07:22 AM
AstroBlackS
some more:
http://www.verociousmotorsports.com/...ory/Resonators
abd a few more:
http://www.sfxperformance.com/catalo...ors/page_1.htm
Old Feb 11, 2008 | 07:49 AM
k-huevo's Avatar
k-huevo
First, what is the diameter of pipe after the header/cat? That will determine the inlet and outlet diameter. A 2 inch ID core (like the later model stock Magnaflow) will be effective but will also cause power robbing drag. Longer is better than short but there is only 20 inches between the forward flange and the middle hangers. An 18 inch long 4 inch round diameter will fit, but it is tight; a resonator body greater than 5.5 inches in diameter (14 inch length) will not have enough room above or on the sides to avoid contact with the heat shield. As mentioned earlier the 12 inch long Spiral Flow is effective and will fit in the available space post-cat, it is 2.5 inch inlet & outlet. Also, a 5 inch round body, 14 inch long Magnaflow is another good choice.
For the space behind the middle bracket, unless a custom bend is made, 3.5 inch diameter (round body) is about the limit of what will fit in the rear channel. A work around would be to use a long Hushpower and spread the heat shield but once again without going custom bends there might be contact. If you go custom bends, a larger diameter can be used but the risk of scrapping speed bumps is greater.
Old Feb 11, 2008 | 08:39 AM
freeskier's Avatar
freeskier
i want to mount after the middle bracket as the pipe has already been cut there. i have no problem widening the heat shield to incorperate a 4.5-5inch diamerter resenator and have herd good things about the ultra quiet and the hushpower but cant find the hushpower for sale..... any idea how long the pipe is between the middle bracket and the split in the magnaflow exhaust? thanks
Old Feb 11, 2008 | 03:06 PM
k-huevo's Avatar
k-huevo
The reason I said the heat shield could be widened was for the Hushpower which is wider on the transverse plane. There is a limit to how wide it can spread and the roof can not be extended, so depending on the bends, a 4 inch round might not have enough room. Keep in mind the Magnalfow is already limited in how far the tips can be tilted upwards so if you try to dip the Y-pipe downwards it will cause harder contact with tips against the rear trim piece.
In this photo I have a 3.5 inch diameter resonator body on 2.25 OD pipe, there is only about 3/8ths clearance above it.
Old Feb 11, 2008 | 05:45 PM
freeskier's Avatar
freeskier
ok, does the resenator in the picture have enough size to quiet the exhaust? that looks like a fine size for clearance. i have also done some youtube research and a hushpower 18inch does the trick but i cant seem to find one, any ideas?
Old Feb 12, 2008 | 01:40 AM
BFG9000's Avatar
BFG9000
Someone asked this exact same question before. If you have a stock length header, the most sound attenuation will be from a large 6" diameter, 14" long muffler right after the cat before the hangers, where there is room for something this wide.
The reason for this is because reduction in amplitude is largely from the diameter (expansion ratio), while length mostly affects the frequency where maximum attenuation occurs. That's the reason short catalytic converters are so effective at reducing volume (plus if they are large enough, they can even make fine "termination boxes"). The main reason it's so hard to quiet a 3" exhaust is because there's just not enough room to make the cans relatively large enough to make it quiet--while a stock 3" exhaust on a huge truck isn't necessarily loud... because there is room there.
Quiet requires either big cans or high backpressure. If you want to filter out unpleasant high frequencies while keeping a loud low rumble, you want fat, short cans.
Old Feb 12, 2008 | 09:40 AM
freeskier's Avatar
freeskier
that pervious thred was a huge help. one question about the magnaflow 6" diamater resenator. did you mount it after the cat and before the center hanger? thanks
