Drivetrain NEW ALTA R56 Plug-n-Play ECU Q&A Thread
Old Feb 21, 2008 | 09:19 AM
  #176
amazingrando's Avatar
amazingrando
Auto on Sport Button guy
Originally Posted by chili_red07
Damn you Alta! I was perfectly happy with my stock R56 before I found you guys!!! I'm willing to bet $20 I end up with the ECU before summer is over
True Dat!
Old Feb 21, 2008 | 10:06 AM
  #177
snkbte's Avatar
snkbte
Your close enough for one hell-ride in mine(once I get the new "improved" harness installed) to put the final nail in the coffin...
Old Feb 21, 2008 | 10:13 AM
  #178
chili_red07's Avatar
chili_red07
Yeah, I noticed your location a while ago. I actually work in Beverly. A ride may be the deciding factor...
Old Feb 22, 2008 | 03:32 AM
  #179
ENGINE 58's Avatar
ENGINE 58
got my call from the sweet girls from alta and my pnp will be coming home soon.
Old Feb 22, 2008 | 08:34 AM
  #180
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
NICE!
Old Feb 22, 2008 | 04:06 PM
  #181
KNTRKTOR's Avatar
KNTRKTOR
+1
Old Feb 22, 2008 | 04:20 PM
  #182
ACooperS's Avatar
ACooperS
+2
Old Feb 22, 2008 | 06:51 PM
  #183
lxjose9xl's Avatar
lxjose9xl
I haven't gotten a call from the sweet girls at Alta!
Old Feb 24, 2008 | 12:10 PM
  #184
papadimitriou's Avatar
papadimitriou
Hi there,
here is a question from Greece about Alta PnP.
It is now released in Greece.
The average R56s in Greece in Maha dynos, is about 188-192 hp with 260-280 nm of torque.
I plan to install a package that is offered by a vendor here that contains the ALTA PnP, the Alta FMIC and the ALTA CAI.
The expected horsepower that is announced is about 216 hp.
I would like to ask you if you consider this number logic, because to me it seems a little bit small, here is why.
The R56s is running with 0,8 psi current pressure and 1,0 overboost.
The pressure will be increased to 1,2 psi cr with 1,4 overboost.
Is this pressure "acceptable" by the engine?
I plan to install this package, so I would really appreciate you opinion.
Old Feb 24, 2008 | 03:29 PM
  #185
MotorMouth's Avatar
MotorMouth
The expected horsepower that is announced is about 216 hp..
you won't get 216hp.
I have those exact three mods. PnP, FMIC and CAI. You'll have plenty power to have alot of fun though!
here is my dyno (uncorrected - sea level, at the wheels):
Old Feb 24, 2008 | 04:01 PM
  #186
mikeg4572's Avatar
mikeg4572
I think he could get pretty close. I hit 210 without the FMIC. I just installed tne FMIC and it is definately faster.
Old Feb 24, 2008 | 04:16 PM
  #187
papadimitriou
Sorry, my mistake.
All numbers that I mention are at the crank, not at the wheels.
Old Feb 24, 2008 | 04:30 PM
  #188
mikeg4572's Avatar
mikeg4572
I hit 210 at the wheels. I think its totally possible to get 216 at the wheels.
Old Feb 24, 2008 | 04:39 PM
  #189
unsalada's Avatar
unsalada
So pretty much you need all alta stuff to get to 215 whp??
Old Feb 24, 2008 | 04:40 PM
  #190
lxjose9xl's Avatar
lxjose9xl
Sorry, my mistake.
With the mods you listed, you definitely should get more than 216 at the crank. Also depending on what tune it comes from Alta. MikeyG is was probably maknig around 235 at the crank with the same mods you listed.
Old Feb 24, 2008 | 05:31 PM
  #191
MotorMouth's Avatar
MotorMouth
you have more than just the three mods he listed. I have exactly the same mods he listed and got 203 at the wheels. What is that at the crank? Depends on what loss you use. I'm probably well over 216 at the crank. Since nobody reallys knows what correction to use for the crank, ATW is a better measurement. Besides, the crank doesn't touch the road.
Old Feb 24, 2008 | 06:26 PM
  #192
mikeg4572's Avatar
mikeg4572
True. But I did not do the intercooler until after I dyno'd the car. It definately feels faster
Old Feb 24, 2008 | 10:18 PM
  #193
scott48's Avatar
scott48
Whoever's received their tune, with the new improved harness, is everything working okay with NO issues?????
Old Feb 25, 2008 | 06:51 AM
  #194
ukaussi's Avatar
ukaussi
for most FWD cars it is between 10-15%
I would probably stick closer to 10% than 15% on the mini
power = 223-234hp
torque = 260-273lbft
Old Feb 25, 2008 | 07:10 AM
  #195
ENGINE 58's Avatar
ENGINE 58
mike g did you have to retune the pnp after you put on the intercooler?
Old Feb 25, 2008 | 07:19 AM
  #196
mikeg4572's Avatar
mikeg4572
I did not send it back for a retune. The car runs so good right now, I kinda dont want to mess with it. If I get the downpipe I will have it re tuned.
Old Feb 25, 2008 | 07:33 AM
  #197
ENGINE 58's Avatar
ENGINE 58
thanks mike just pm d you.
Old Feb 25, 2008 | 07:34 AM
  #198
ENGINE 58's Avatar
ENGINE 58
did you go with a alta cai
Old Feb 25, 2008 | 07:39 AM
  #199
ENGINE 58's Avatar
ENGINE 58
the alta girls said i would have my pnp shipped out this week. i have a homemade cai and was just wondering about your setup because we are close to the same mods less the full boost tubes. would like to up it to the dp and the intercooler later on. still wondering if i should take off my big true flow cai and go with the alta cai . i like the way its built. just dont want to send back the pnp very time i change a mod or add one unless its something big like the dp.
Old Feb 25, 2008 | 07:58 AM
  #200
chili_red07
If there are 2 maps on each PnP there's no reason I couldn't get one programmed for the parts I have and the parts I will get later (since I won't be routing the toggle to the inside and have no need for a "valet" or stock setting)
