Drivetrain Finally got pullied!
I was hoping for a bigger grin when you got back from the first drive
. Now you just need some Alta control arms ! LOL ! congrat's Roger !
Yes. Always reset the ECU after a change to the engine.
Or through an ECU reset:
http://www.mini2.com/forum/faq.php?f..._obc_functions
DISCLAIMER:
The information below is based on the account of a MINI2 member. Although MINI2 and the author of this thread believe this information is accurate, using it as a DIY guide is done at your own risk. MINI2 and the author are not responsible for any damage, personal injury, or warranty issues that may arise from the use of this information. Some information below may be specific to model specifications that are unique to certain countries, and may not apply to your model of MINI One, Cooper, or Cooper S.
Do not undertake any DIY project that you are not qualified to perform. If you have questions about this project, you should consult with experienced professionals and/or your MINI dealer before undertaking it. Always follow standard safety guidelines for car repair in performing DIY projects.
Seeing as I mentioned this in another thread elsewhere on MINI2, here's a quick how-to on getting a bit more information from your MINI's computer.
The information displays in place of your mileometer, so you DO NOT have to have the MINI OBC/Trip Computer option to see this.
A complete list of functions is below, this example is how to get into the menu number '7'.
With the key in the ignition, but in the off position, press and hold down the odometer reset button, while holding the button down, switch the key in the ignition to position 1.
The screen will say 'Test' and a number.
Scroll through, (pressing reset button) through to test 19 and wait a moment.
Wait and the message will say "log i-off" then "log i-on" and back to "log i-off" again. When "log i-off" appears, press again. You are now in the system. (Woooo)
You can (if you wish) start the ignition any time from now.
Scroll through to test 7.0 (or whichever from the list below) and wait a moment, after a pause you will enter the test 7.* range of information.
You can scroll through now (7.1,7.2,7.3 etc.) using the reset button.
You can exit each menu by pressing, holding for a few seconds, then releasing the reset button.
To leave the system scroll to 19 and leave it for a few moments.
Switching off the ignition also exits the system.
Test:
1.0 Chassis number
1.1 Kilometer count
1.2 Parts number
1.3 Coding-, Diagnostic- and Bus-index
1.4 Production Date (Calender week/year)
1.5 Hard- and Software status
1.6 Injectorstatus, Cylinder count, Engine factor.
2.0 Combisystem Test
3.0 Service intervall counter
4.0 Actual fuel consumption in l/100km. eg.0154 = 15,4 liters/100kms.
4.1 Consumption in liters/100kms.
5.0 Distance consumption in l/100kms.
5.1 Actual rest distance with available fuel in Kms.
6.0 Actual amount of fuel in tank. eg. 123321 =12,3liters left 32,1 liters right
6.1 Total amount of fuel in tank.
6.2 Show value of Fuel guage. 1= both senders OK, 2= sender failure, 3=ti signal unplausible (no reading)
7.0 Actual coolant temp.
7.1 Actual outside temp.
7.2 Actual engine revs.
7.3 Actual speed
8.0 Hexadecimal readings of menu 7.0 to 7.3
9.0 Actual on board voltage (Battery)
10.0 Land codes
11.0 Unit codes
12.0 No funktion
13.0 Gong test
14.0 - 14.4 On board diagnostic codes. eg 000000 = no failures
15.0 - 18.0 No funktion
19.0 On/Off for Test menu.
20.0 Correction factor for Fuel consumption
Formula for correction:
Shown consumption x 1000 / user defined consumption
Push the trip reset button to begin the correction. Numbers count up from 0-9, when correct number shows push trip reset button.
20.1 Sets 10ths. for consumption factor
20.2 Sets 100ths. and 1000ths. for consumption factor
20.3 Saves the new consumption factor and shows new value
21.0 Software reset. (Same as disconnecting battery)
Your MINI's computer may give more or less information than stated above.
DISCLAIMER:
Test:
1.0 Chassis number
1.1 Kilometer count
1.2 Parts number
7.3 Actual speed
10.0 Land codes
11.0 Unit codes
12.0 No funktion
13.0 Gong test
on a side note....ordered the items to do the auto meter boost guage set up and i got the top part of my aero grill conversion done...had to sacrifice the driving lights for awhile...who ever isntalled them decided to rivet the damn thing to the grill
....so after some carefull drilling it finally came out
Where in San Diego are you? I am in Escondido. My Girl friend lives in Ramona and her sister and husband live in Julian. I have a killer time on the grades. Just installing my Alta intake made a big difference. Was the pully hard to put on yourself?
oh it wasnt something i did on my own...its a good idea to have someone who knows the installation process do the install
you will notice with the pulley the power comes quicker and in parts of the rpm band that once werent there when u are on the grades....actually i live in east san diego near lemon grove
as wendy and paulie can attest...there are a few things about bumbles that makes it stand out lol
I actually did the pulley for him. I have several MINI Friends in San Diego and knew Roger since he use to live in Indy. We met up and and did the install, If you need something let me know I could arrange it on my next visit.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
My dad's in the San Diego Miata Club, and I think he's mentioned a "Way" in the SD Miata tuning community. Any relation to Way Motorworks?
I am Way Motor Works. I also do all the Maint work like the inspection services, and so on.
Alpha Motoring
Nov 10, 2015 07:08 AM
pahg
Oct 5, 2015 11:50 AM
eliseo1981
Sep 30, 2015 07:57 PM
dutchhome
Sep 30, 2015 07:17 AM
