Drivetrain Jan-tune nets 50hp! (Well actually 49.9)
Old Feb 19, 2008 | 12:47 PM
  #151
Deviant's Avatar
Deviant
Originally Posted by charger
So if you tune a car to 11.5 then why is there such a huge range in your A/F ratio chart. 15.5 down to 11.5.
You say 13:1 is to lean and will damage the engine. But every OEM car that was tuned in a million dollar labs is around 14:1. Every motorcyle I've tuned was around 13:1 Almost every stock engine I've seen dyno tested has at least 13:1 during WOT. Which is why on the above dyno chart the A/F ratio chart has a red line for 13:1
you say 13:1 is too lean - yet the majority of that tuning job is above 13:1. Your only less than 13:1 for about 500rpms 6000rpms-6500rpms.
Because you don't need 11.5 throughout the entire RPM range. As intake temps rise, you want the richer mixture to help cool, but you won't need it at lower RPMs and it would actually be detremintal to the overall power production and longevity of the motor. 13:1 is fine below a certain threshold where intake temps are still reasonable, but spin an M45 with a 15 or 17% pulley above that threshold and you're going to see the intake temps skyrocket, hence the richer mixture at higher rpms. You seem eager to criticize Jan without knowing any of his credentials. I have no idea of your background, nor you mine, but Jans record speaks for itself on this site. The very links you posted seem to back up Jans tuning technique and all the tuning I've seen done on F/I applications looking for a reliable streetable setup have had similar curves to the A/F ratio.
Old Feb 19, 2008 | 03:35 PM
  #152
charger's Avatar
charger
I agree perfect for a dyno queen. In that you only make one high powered run.
In the real world If I hammer down from a redlight and jam through all the gears and then slow down and hammer back down. The intake temps will be high and not based soley on RPMs. So you could need a richer mixture at lower RPMs.
Nothing to do with any person. Just engine talk. The links posted show that A/F ratios need to be a certain range for power or MPG. They do not say that the A/F ratio can be very lean at low RPMs.
Old Feb 19, 2008 | 04:03 PM
  #153
Deviant's Avatar
Deviant
True, the intercooler and intake tract can heat soak, but at the same time as the supercharger moves less air and compresses it less it's efficiency increases and the intake temps will still drop, relative to where they were at higher RPMS.
Old Feb 19, 2008 | 04:06 PM
  #154
charger's Avatar
charger
Originally Posted by Revolution Mini Works
on that dyno the a/f is 1 pt richer than what it shows.
[REMEMBER:::::: THIS IS THE DYNO THAT SHOWS 1 A/F LEANER THAN IT IS
I still don't get this dyno A/F reading. If the results are 1 point to lena and the actual results are 1 point richer. 15.5:1 reading verse 14.5:1 actual Big Difference.
I'd change my thoughts on the tune job if the leanest point was 14.5:1 verse the really lean 15.5:1.
Old Feb 19, 2008 | 04:10 PM
  #155
charger's Avatar
charger
Sure I get that. The intercooler will heatsoak and that takes some time. But the combustion chamber and piston surface will hold the heat. That's the danger. You can run through gears in seconds and your engine will see a huge range of RPMS on the street.
The point of running rich is to cool down the chambers. And at the lean ratio under WOT the combustion chamber could just as hot. EGT would need to be measured to confirm.
Old Feb 20, 2008 | 07:15 AM
  #156
pberry51mini's Avatar
pberry51mini
No Fear Gear
If you want to tune your car to 13:1 go ahead... I will gladly sell you rebuild parts
Old Feb 20, 2008 | 07:36 AM
  #157
charger's Avatar
charger
Old Feb 20, 2008 | 07:38 AM
  #158
Revolution Mini Works's Avatar
you really don't get it .... do you?
nice photo shop though
I do have CP pistons in stock along with other high quality parts
Old Feb 20, 2008 | 08:13 AM
  #159
charger's Avatar
charger
Guess not.
I'm used to seeing a much flatter A/F ratio coming from n/a engines.
I get that you use a rich A/F ratio to cool things down and for saftey. I do the same on my high compression Harley -just change plgs often. Just don't understand or agree with the lean ratio's under 4k. Or why from 6200+ rpms you lean out the ratio. If 12:1 (lean) is good at 7k why not at 6k?
Nothing personal. Just like to learn about engines. Do you moniter EGT, IAT and water temps during your testing/tunings?
Old Feb 20, 2008 | 08:35 AM
  #160
Guess not.
this IS NOT a N/A motor....
Old Feb 20, 2008 | 08:48 AM
  #161
curv872's Avatar
curv872
Guess not.
Wake up and smell the coffee, even your DINAN tune varies from 15 to 11!
http://www.dragtimes.com/2005-Mini-C...phs-11754.html
Old Feb 20, 2008 | 09:26 AM
  #162
charger's Avatar
charger
That is a much smoother A/F curve than the one in question. From 6k to redline it stays even. The tune in question begins to lean out past 6k. Which is bad or at least that whats been said in this thread.
also the link you provided has the green program making the best power which it very quickly changes from lean mixtures to a nice smooth A/F ratio.
Compare the two A/F ratios. Then think about how much testing and years of tuning Dinan has.
Old Feb 20, 2008 | 09:38 AM
  #163
checkmate2006's Avatar
checkmate2006
Dinan is out for your money
Old Feb 20, 2008 | 09:39 AM
  #164
for some reason you don't understand what I told you.... the a/f at redline is really 11.5 NOT 12.5 .......... if you are trying to say something in all this repeated hogwash... JUST SAY IT....
we are patiently waiting
Old Feb 20, 2008 | 09:43 AM
  #165
JIMINNI's Avatar
JIMINNI
Dinan I agree has been around for awhile, but that don't mean anything. When I have called there the guy I talked didn't know anything and he said he would let someone else know and they never called me back, great customer service . Not to cheap either for what you get.
Old Feb 20, 2008 | 10:03 AM
  #166
charger's Avatar
charger
That A/F charts shows that your only under 11.5:1 for a short RPM range. At the end of the run your at 12.2:1
Don't understand the reason for the V shaped A/F ratios. When every other S/C dyno I've looked at start lean and ends richer. No W or V curves to them. Be it the Mini, cobalt SS, or Ford SVT truck.
http://home.earthlink.net/~aquez57/s...yno_sheet1.jpg
http://www.nwgmtuners.com/_images/Dyno1.jpg
http://cobaltss.net/gallery/files/3/1/9/0/scan0072.jpg
All good A/F ratios on S/C engines.
Old Feb 20, 2008 | 10:07 AM
  #167
You seem to be the only person in this thread who doesn't understand what I told you.
Old Feb 20, 2008 | 10:11 AM
  #168
Tüls's Avatar
Tüls
Turbius Maximus
The AF UNDER 4000 is ok to be leaner, the compression ratio at those points is significantly low.
As for your smooth AF lines. Different Dyno software view differently. Make sure when you buy your Dyno you get a Dyno jet since you want it to look smoother.
here, I ahve AF graph for you
11.5 _________________________________________ 11.5
/\ nice and smooth huh? It's from a one million HP NA honda with Pistons, Rods, Calamari, and Dinan tune.
Old Feb 20, 2008 | 10:17 AM
  #169
PGT's Avatar
PGT
unpossible!
Old Feb 20, 2008 | 10:20 AM
  #170
charger's Avatar
charger
So how does the Mini alter compression ratios based on RPM's?
The reason for richer mixtures on a S/C engine it to cool things down and prevent detonation. Engine saftey. I just question the V shaped A/F ratio beyond 6200rpms. Why go leaner beyond 6200rpms.
Old Feb 20, 2008 | 10:23 AM
  #171
Tüls's Avatar
Tüls
Turbius Maximus
If you dont know, I guess you should do more reading and less blah blah blah, we have enough internet experts.
Old Feb 20, 2008 | 11:57 AM
  #172
cmt52663's Avatar
cmt52663
Last edited by cmt52663; Feb 20, 2008 at 02:54 PM. Reason: bs filter applied retroactively
Old Feb 20, 2008 | 01:21 PM
  #173
pberry51mini
No Fear Gear
Old Feb 20, 2008 | 01:29 PM
  #174
R7425TOUR's Avatar
R7425TOUR
RMW is a class act
All I can say is that I had almost the same type of experience with my RMW tune. My car initially dynoed 215 with MTH software. This with most of the usual performance modifications one can put on their car. My car ran great for almost a year without any problems. After the dealer flashed my ECU without my consent with stock software to supposedly solve a SES light issue, I had a custom tune put on the car which was not done on the dyno. For six months my car ran inconsistently hot and cold, continued to throw codes, had supercharger, coolant and exhaust leaks, and was becoming a big pain in the ****. After getting fed up with all this nonsense, I gave Jan a call to have a look at my tune. He immediately could see why the tune was causing me a lot of problems. The next week we met at the dyno and right off the bat I had another supercharger leak. He sent me to Danny at Minicorsa and he fixed the problem in about 30 minutes. He's another class act and one of the best at working on the mini. Needless to say after racing back to the dyno, and several test runs later, the car finally put down 227HP and 188TQ. With the other custom tune, these numbers were significantly fless. Without getting caught up in all the numbers, graphs, and hyperbole that surrounds tuning, I can say that my car drives stronger across the entire spectrum, doesn't have constant idle problems like before, doesn't have a lag between shifting, and definitely puts out more power especially across the top end. I now cannot comfortably get into 6th gear now unless I'm going at least 100MPH. I never had this problem before.
Throughout all of this, I was fortunate enough to hang out with Jan at his fabricator and see the quality of the RMW parts. It really made me envious that I didn't know him a year earlier because quite honestly after seeing how beautifully made they look in person I would not hesitate to put all of his stuff on my car. For me, the mini has become an obsession. It is the funnest car I have owned and have driven. I would not hesitate to recommend Jan and Danny. They are very good at what they do and I'm lucky to be in the area to utilize their services.
Next stop-RMW turbo mini!
Old Feb 20, 2008 | 01:41 PM
  #175
JIMINNI's Avatar
JIMINNI
